* mkbinutilspec.in: Fix PATCH2.
* gcc3newlib/gccnewlib.add: Add -Bgcc/ when collecting multilibs.
* gcc3newlib/gccnewlib.spec.in: Removed from CVS.
* mkbinutilspec.in: Add support for empty patch-version (no patch).
* mkgcc3newlibspec.in: Ditto.
* setup: Fix gcc3*_versions handling.
* setup.def: binutils_patch_version=.
* binutils/binutils.add: Reflect changes to mkbinutilspec.in,
Use "%{_target_os}" != "%{_build_os}" to detect cross-building.
* binutils/target-binutils.add: Comment out c++filt.
* gcc3newlib/base-gcc.add: Remove duplicate libm.info.
* gcc3newlib/gccnewlib.add: Reflect changes to mkgcc3newlibspec.in.
Comment out gcc-2.95.x hacks.
Remove *.la from installed files.
* gcc3newlib/gccnewlib_c_only.spec.in: Remove.
* buildall.in: Correct logic for detecting 0 RTEMS RPMS installed.
* .cvsignore: Added mkgcc3newlib.
* gcc3newlib/.cvsignore: New file.
* Per PR64 added support for gcc 3.x RPMs
* Makefile.am, configure.ac, mkspec, setup, setup.def: Modified.
* mkgcc3newlibspec.in: New file.
* gcc3newlib: New subdirectory.
* base-g77.add, base-gcc.add, base-gcj.add, gccnewlib.add,
gccnewlib_c_only.spec.in, gccnewlib.spec.in, HISTORY, Makefile.am,
README, target-g77.add, target-gcc.add, target-gcj.add,
target-objc.add: New files.
* binutils/binutils.add: Commented out patch since binutils 2.12
does not require one.
* autotools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* binutils/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gccnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gdb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR151
* autotools/automake-rtems.spec.in: New.
* autotools/automake-rtems.spec: Removed.
* configure.ac: Be a little more lenient in matching sparc-solaris.
* mkbinutilspec.in, mkgccnewlibspec.in, gccnewlib/base-chill.add,
gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/gccnewlib.add,
gccnewlib/target-chill.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
gccnewlib/target-objc.add: Added more support for Canadian Cross
building.
* buildall.in: Corrected logic for detecting when no RPMs are installed.
* README: Added Canadian Cross instructions.
* configure.ac: Add AC_PREFIX_DEFAULT([/opt/rtems]).
* mkbinutilsspec.in: Add propagation of @prefix@.
* binutils/base-binutils.add:
Let %post and %unpost apply %{_prefix}.
Apply %{_prefix} instead of /opt/rtems.
* binutils/binutils.add: Update copyright notice.
Add _prefix.
Remove -a 0 in %setup.
Rework hack to SuSE's rpm screwing up %{_target}.
Replace ARGS with CONFIGURE_ARGS.
* binutils/binutils.add: Add initial support for building
Canadian cross RPMs. It should work like this:
cd rtems/scripts
./configure --build=`../config.guess` --host=i386-cygwin
rpm --target=i386-cygwin \
/usr/src/redhat/SPECS/<target>-binutils-..spec.
alien -t /usr/src/redhat/RPMS/....i386.rpm
.. and voila ... your tarball, with rpm-consistency checks etc. applied.
* buildalltar.in: Modified to support Canadian cross builds.
It was testing using a RedHat 7.2 host to build *-rtems tools
that run on an i386-cygwin host.
* configure.ac: Fix typo to allow custom RPM_SPECSdirs.
* setup.def: Bumped the gdb_patch_version to account for a configuration
problem on psim where it could not be enabled for powerpc-RTEMS.
* gdb/Makefile.am: Add i386-RTEMS and powerpc-RTEMS targets.
* mkbinutilsspec.in: Guard sed-pattern against autoconf.
* mkgccnewlibspec.in: Guard sed-pattern against autoconf, remove
Target_alias.
* mkgdbspec.in: Guard sed-pattern against autoconf.
* mkbspspec.in: Guard sed-pattern against autoconf.
* configure.ac: Rework check for RPM_SPECSdir.
* autotools/automake-rtems.spec: Update to automake-1.5.
* configure.in: Remove.
* gdb/Makefile.am, gccnewlib/Makefile.am, binutils/Makefile.am:
Initially setup CLEANFILES using = instead of += to make
automake-1.5 happy.
* setup.def, gccnewlib/gccnewlib.add, gccnewlib/target-gcc.add:
Revert changes because of gcc 2.5.x/3.0 transition and continue
to support gcc 2.95.x as primary version.
* mkgccnewlibspec.in,
Use Target_alias not target_alias to avoid conflicts with new autoconf.
* setup.def: Changed version numbers in attempt at building gcc 3.0.1.
Only sparc and arm built for C/C++ OK. :(
* gccnewlib/base-gcc.add: Modifications to reflect files not in gcc 3.x.
* gccnewlib/gccnewlib.add: gcc 3.x does not have "everything in the name"
* target-gcc.add: Modifications to reflect files not in gcc 3.1
* autotools/.cvsignore: New file.
* autotools/Makefile.am, autotools/autoconf-rtems.spec,
autotools/automake-rtems.spec: New.
* configure.in, Makefile.am: Add autotools/.
* .cvsignore: Add buildalltar.
* buildalltar.in: New file.
* configure.in, Makefile.am: Modified to reflect addition of file.
* mkgdbspec.in: Make list of simulators very complete.
* setup.def: Update versions.
* setup.def, binutils.add, gccnewlib.add: Updated to build
binutils 2.11.2 (rtems patch 20010622), gcc 2.95.3 (rtems
patch a20010622), and newlib 1.9.0 (rtems patch 10020622).
* configure.in: Remove AC_EXEEXT, treat .exe manually.
* gccnewlib/base-gcc.add: Remove cpp.
* gccnewlib/gccnewlib.add: mv cpp $target_alias-cpp, update
copyright.
* setup.def: Modified the binutils version to 2.11 and
RPM revision 3 to reflect experimentation with new binutils release.
* binutils/Makefile.am: Added a29k-rtems.
* binutils/binutils.add: Switch to .bz2 extension to reflect
real way code is compressed on distribution sites now.
* setup.def: Updated version numbers and patches for binutils
and gdb. binutils was to get correct patch in field. gdb
was to add mipstx39-rtems configurery support.
* gdb/Makefile.am, mkgdbspec.in: Added mipstx39-rtems
configuration to gdb since this includes the JMR3904 simulator.
* setup.def, binutils/HISTORY, gccnewlib/HISTORY: Updated
binutils HISTORY to reflect new revision. Updated gcc to fix
i960 C++ problem. Updated newlib to move to newlib 1.9.0.
* gccnewlib/gccnewlib.add: Fix typo in URL.
* configure.in: Adapt m4-quoting to autoconf-2.49b, use $host
instead of $target to setup RPM_CPU, move chmod 755 buildall to
AC_OUTPUT's extra-cmds.
* buildall.in, mkgdbspec.in, setup.def, binutils/Makefile.am,
gccnewlib/HISTORY, gccnewlib/Makefile.am, gdb/Makefile.am:
Added mips-rtems, updated to include new patches and
gcc 2.95.2/newlib 1.8.2 revision 11 RPM.
* configure.in: Remove trailing '/'s from setting up RPM_SPECdir.
* setup.def: Updating version numbers for gcc/newlib RPM release 10.
* setup.def: Updated gcc and newlib patches and bumped RPM revision.
Patches primarily add or16/or32 basic support to newlib and
i386 multilib improvements to gcc from Ralf Corsepius.
