* setup.def: Modified the binutils version to 2.11 and
RPM revision 3 to reflect experimentation with new binutils release.
* binutils/Makefile.am: Added a29k-rtems.
* binutils/binutils.add: Switch to .bz2 extension to reflect
real way code is compressed on distribution sites now.
* setup.def: Updated version numbers and patches for binutils
and gdb. binutils was to get correct patch in field. gdb
was to add mipstx39-rtems configurery support.
* gdb/Makefile.am, mkgdbspec.in: Added mipstx39-rtems
configuration to gdb since this includes the JMR3904 simulator.
* setup.def, binutils/HISTORY, gccnewlib/HISTORY: Updated
binutils HISTORY to reflect new revision. Updated gcc to fix
i960 C++ problem. Updated newlib to move to newlib 1.9.0.
* gccnewlib/gccnewlib.add: Fix typo in URL.
* configure.in: Adapt m4-quoting to autoconf-2.49b, use $host
instead of $target to setup RPM_CPU, move chmod 755 buildall to
AC_OUTPUT's extra-cmds.
* buildall.in, mkgdbspec.in, setup.def, binutils/Makefile.am,
gccnewlib/HISTORY, gccnewlib/Makefile.am, gdb/Makefile.am:
Added mips-rtems, updated to include new patches and
gcc 2.95.2/newlib 1.8.2 revision 11 RPM.
* configure.in: Remove trailing '/'s from setting up RPM_SPECdir.
* setup.def: Updating version numbers for gcc/newlib RPM release 10.
* setup.def: Updated gcc and newlib patches and bumped RPM revision.
Patches primarily add or16/or32 basic support to newlib and
i386 multilib improvements to gcc from Ralf Corsepius.
