* gccnewlib/gccnewlib.add: Rename src.rpm to *-gcc.src.rpm.
* gccnewlib/target-gcc.add: Reflect changes above.
* gccnewlib/Makefile.am: Re-sort sub-package fragments.
* gccnewlib/gccnewlib.add: Pass CC="%__cc $RPM_OPT_FLAGS" to
configure.
* gccnewlib/gccnewlib.add, gdb/gdb.add: Append %_bindir to PATH
only if %_prefix != /usr.
* configure.ac: Remove GCC3NEWLIBVERS, BINUTILSVERS, GDBVERS.
* binutils/Makefile.am: Generate unversioned *binutils.spec.
* gccnewlib/Makefile.am: Generate unversioned *gcc-newlib.spec.
* gdb/Makefile.am: Generate unversioned *gdb.spec.
* binutils/target-binutils.add: Don't own %{_mandir}/man1 for
%_prefix == /usr.
* binutils/binutils.add: Remove dlltool, nlmconv, windres man pages.
* common/common.add.in: Remove Vendor:. Remove Distribution:.
* Makefile.am, autotools/Makefile.am, binutils/Makefile.am
cpukit/Makefile.am, gccnewlib/Makefile.am, gdb/Makefile.am
rtems/Makefile.am: Rename *.spec into @rpmprefix@*.spec.
* binutils/base-binutils.add, binutils/binutils.add,
binutils/target-binutils.add, common/common.add.in,
cpukit/rtems-cpukit.add, cpukit/target-cpukit.add,
gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/base-gfortran.add,
gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add,
gccnewlib/target-c++.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
gccnewlib/target-gfortran.add, gccnewlib/target-gnat.add,
gccnewlib/target-libc.add, gccnewlib/target-objc.add,
gdb/base-gdb.add, gdb/gdb.add, gdb/target-gdb.add,
rtemsdoc/rtemsdoc.add, rtemsdoc/supplement.add.in,
rtemsdoc/templ.add.in, rtems/rtems-source.add:
Replace %{rpmprefix} with @rpmprefix@.
* cpukit/mkspec.in, rtems/mkspec.in: Propagate @rpmprefi@.
* gccnewlib/Makefile.am: Use target-libc.add
* gccnewlib/gccnewlib.add, gccnewlib/target-gcc.add,
gccnewlib/target-libc.add: Misc. fixes.
* gdb/gdb.add: Remove Packager:.
* gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/target-c++.add,
gccnewlib/target-g77.add, gccnewlib/target-gcc.add,
gccnewlib/target-gcj.add, gccnewlib/target-gfortran.add,
gccnewlib/target-gnat.add, gccnewlib/target-objc.add:
Switch to using %gcc_version.
* binutils/binutils.add: Remove Packager:.
* binutils/target-binutils.add: Further adaptations to /usr.
* gccnewlib/target-c++.add, gccnewlib/target-g77.add,
Fix directory ownerships.
* gccnewlib/target-gcc.add: Add Requires/Provides *-newlib/*-libc.
* gccnewlib/gccnewlib.add: Add Requires/Provides *-newlib/*-libc.
gccnewlib/gccnewlib.add, gccnewlib/target-c++.add,
gccnewlib/target-g77.add, gccnewlib/target-gcj.add,
gccnewlib/target-objc.add: Use gccnewlib_version.
Cosmetics. Minor cleanups.
* gccnewlib/base-gcc.add: Remove %_includedir.
* gccnewlib/base-g77.add: Remove %_mandir.
Remove %{gcc_target}-g77.1.
* gccnewlib/base-gfortran.add: Remove %_mandir.
Remove %{gcc_target}-gfortran.1.
* gccnewlib/gccnewlib.add: Remove Packager:.
Add %gccnewlib_version.
* gccnewlib/target-c++.add: Remove %_bindir.
* gccnewlib/target-g77.add: Add %{gcc_target}-g77.1.
* gccnewlib/target-gcj.add: Remove %_bindir.
Remove %_mandir.
* gccnewlib/target-gfortran.add: Remove %_bindir.
Add %{gcc_target}-gfortran.1.
* gccnewlib/target-gnat.add: Remove %_bindir.
* setup.def, gdb/gdb.add: Use DESTDIR as override with gdb 6.3.
* gccnewlib/gccnewlib.add: Remove vxaddr2line.
Further minor cleanup.
Special-case _prefix=/usr.
gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add:
* gccnewlib/Makefile.am: Remove h8300-rtemscoff.
* binutils/Makefile.am: Remove h8300-rtemscoff.
* autotools/automake.add: Update to automake-1.9.6.
* brp-rtems-strip.in: New.
* brp-rtems-compress.in: New.
* binutils/binutils.add: Reflect using brp-rtems*.
* gccnewlib/gccnewlib.add: Reflect using brp-rtems*.
* binutils/binutils.add: Take out -D_FORTIFY_SOURCE from CFLAGS
to prevent fortify from rendering ar unusable.
* binutils/mkspec.in, gccnewlib/mkspec.in, gdb/mkspec.in:
Use ',' as sed pattern delimiter.
* autotools/automake.add: Add %{?dist}.
* autotools/autoconf.add: Add %{?dist}.
Replace Copyright: by Licence:.
* gccnewlib/gccnewlib.add: Remove Epoch.
* binutils/base-binutils.add, gccnewlib/base-g77.add,
gccnewlib/base-gcc.add, gccnewlib/base-gcj.add,
gccnewlib/base-gfortran.add, gccnewlib/base-gnat.add,
gdb/base-gdb.add: install-info --info-dir=.
* gccnewlib/mkspec.in: Correct patch handling magic.
* gccnewlib/gccnewlib.add: Reflect changes to mkspec.in.
Use --with/--without, rework logic for building optional languages.
* gccnewlib/header.add: Document --with/--without.
* gccnewlib/Makefile.am: Add h8300-rtemscoff*.
* gccnewlib/gccnewlib.add: Let building gnat require gcc.
Allow building arm-rtems*-gnat.
* gccnewlib/gccnewlib.add: Further clean up of tools not supported
by individual targets. Add %build_libgcj.
* gccnewlib/target-gcc.add: Remove dep to base-gcc.
* gccnewlib/gccnewlib.add: Suppress building tools not supported by
avr, h8300 and mips.
* rtemsdoc/supplement.add.in, rtemsdoc/templ.add.in: Misc.
%infodir/dir handling changes.
* rtemsdoc/rtemsdoc.add: Use BuildRequires instead of BuildPreReq
(rpm anachronism).
* gdb/base-gdb.add, gdb/gdb.add: Misc. %infodir/dir handling
changes.
gccnewlib/base-gnat.add: Misc. %infodir/dir handling changes.
* common/common.add.in: Use FC compliant BuildRoot.
* gccnewlib.add: Remove gnatgcc hacks.
Misc %infodir/dir handling changes.
* target-c++.add, target-g77.add, target-gcj.add,
target-gfortran.add, target-gnat.add, target-objc.add:
Requires: %{rpmprefix}%{gcc_target}-gcc = %{version}-%{release}.
* binutils/base-binutils.add, binutils/binutils.add:
* configure.ac: Reflect changes to autotools/*.
* autotools/Makefile.am: Update.
* autotools/automake-rtems.spec.in, autotools/autoconf-rtems.spec.in:
Remove.
* autotools/automake.add, autotools/autoconf.add,
autotools/header.add: New.
* autotools/Makefile.am: Streamline specs generation with other
tools.
* gccnewlib/gccnewlib.add: Don't build mips-gcj. Further gnat
cleanup.
* rtemsdoc/supplement.add.in, rtemsdoc/templ.add.in: Misc. info
fixes.
* gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add,
gccnewlib/target-gnat.add: Abandon Gnat for gcc < 4.0
* gccnewlib/base-gfortran.add: Fix broken install-info.
* gccnewlib/base-gnat.add, gccnewlib/target-gnat.add: Adaptations
to gcc-4.0.0. Install infos using FC conventions.
