* configure.in: Remove trailing '/' from RPM_SPECSdir.
* Makefile.am: Remove ACLOCAL_AMFLAGS.
* setup.def, gdb/gdb.spec.in,gnatnewlib/gnatnewlib.spec.in:
Updated to reflect gnat 3.13p successfully building.
* setup.def: Updated to gnat-3.13p and adjusted all versions
and revisions.
* gnatnewlib/gnatnewlib.spec.in: Include gcov per gnat 3.13p
build instructions.
* NOTE: GNAT 3.13p was not successfully built when this was committed.
that contains:
* Removes MKLIB
handling)
that contains:
* The fix for the gen68360/network/Makefile.am
* automatically set permissions to 755 to scripts/buildall and
scripts-ada/buildall (I remembered a trick to achieve this :).
* automake support for libbsp/* and libcpu/* (Attn: This part will
finally break old-style configuration for all non-public cpus)
NOTES:
* This patch has only been tested for a random selection of BSPs (I
haven't rebuilt all toolchains yet).
* This patch is against rtem-cvs as of this morning (MET).
patch -p1 <rtems-rc-20000118-5.diff
cvs rm -f ./c/src/lib/libbsp/Makefile.in
cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in
cvs rm -f ./c/src/lib/libcpu/Makefile.in
cvs add ./c/src/lib/libbsp/Makefile.am
cvs add ./c/src/lib/libbsp/shmdr/Makefile.am
cvs add ./c/src/lib/libcpu/Makefile.am
./bootstrap
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
and appear to be close for gdb.
