* | 2001-09-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-09-13 | 1 | -24/+27 |
| | | | | | | | | | | | * configure.in: Add RTEMS specific version of EXEEXT test. * mkgdbspec.in, mkgnatnewlibspec.in, gdb/gdb.spec.in, gnatnewlib/gnatnewlib.spec.in: Change to Target_alias to avoid conflicts with new autoconf/automake. * setup, setup.def, mkgnatnewlibspec.in: Add gnat_newlib_patch_version variable. * gnatnewlib/Makefile.am: Add i386-rtemscoff target in attempt to build it. | ||||
* | GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combination | Joel Sherrill | 2000-01-27 | 1 | -4/+4 |
| | | | | and appear to be close for gdb. | ||||
* | First cut at adding RPM scripts for building GNAT/RTEMS RPMs. | Joel Sherrill | 2000-01-26 | 1 | -0/+104 |
