path: root/scripts-ada/setup.def (follow)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-9/+9
* Changed versions of newlib patch.Joel Sherrill2000-01-311-1/+1
* Successfully built some RPMs. There is still a lot of work to do.Joel Sherrill2000-01-311-2/+2
* GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combinationJoel Sherrill2000-01-271-4/+4
| | | | and appear to be close for gdb.
* First cut at adding RPM scripts for building GNAT/RTEMS RPMs.Joel Sherrill2000-01-261-0/+17
