* | 2000-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-08-30 | 1 | -7/+7 |
| | | | | | | | | * setup.def: Updated to gnat-3.13p and adjusted all versions and revisions. * gnatnewlib/gnatnewlib.spec.in: Include gcov per gnat 3.13p build instructions. * NOTE: GNAT 3.13p was not successfully built when this was committed. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -9/+9 |
* | Changed versions of newlib patch. | Joel Sherrill | 2000-01-31 | 1 | -1/+1 |
* | Successfully built some RPMs. There is still a lot of work to do. | Joel Sherrill | 2000-01-31 | 1 | -2/+2 |
* | GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combination | Joel Sherrill | 2000-01-27 | 1 | -4/+4 |
| | | | | and appear to be close for gdb. | ||||
* | First cut at adding RPM scripts for building GNAT/RTEMS RPMs. | Joel Sherrill | 2000-01-26 | 1 | -0/+17 |
