* configure.in: Add RTEMS specific version of EXEEXT test.
* mkgdbspec.in, mkgnatnewlibspec.in, gdb/gdb.spec.in,
gnatnewlib/gnatnewlib.spec.in: Change to Target_alias to avoid
conflicts with new autoconf/automake.
* setup, setup.def, mkgnatnewlibspec.in: Add gnat_newlib_patch_version
variable.
* gnatnewlib/Makefile.am: Add i386-rtemscoff target in attempt to
build it.
* setup.def, gnatnewlib/gnatnewlib.spec.in: Modified to properly
build gnat 3.13p-2 RPMs. These were used to run the ACATS with
the following results on the powepc-rtems/psim:
acats4gnat results cz 3 / 4
acats4gnat results a 75 / 75
acats4gnat results c2 35 / 35
acats4gnat results c3 347 / 349
acats4gnat results c4 333 / 338
acats4gnat results c5 95 / 95
acats4gnat results c6 81 / 81
acats4gnat results c7 47 / 50
acats4gnat results c8 140 / 140
acats4gnat results c9 246 / 255
acats4gnat results ca 73 / 74
acats4gnat results cb 43 / 43
acats4gnat results cc 117 / 117
acats4gnat results cd 172 / 172
acats4gnat results ce 262 / 268
acats4gnat results cxa 85 / 85
acats4gnat results cxb 29 / 30
acats4gnat results cxc 9 / 16
acats4gnat results cxd 27 / 39
acats4gnat results cxe 1 / 1
acats4gnat results cxf 20 / 20
acats4gnat results cxg 28 / 29
acats4gnat results cxh 4 / 4
acats4gnat results d 4 / 4
acats4gnat results e 11 / 11
acats4gnat results l 26 / 26
This compares favorably with the results on Linux. Laurent
Guerby's <guerby@acm.org> acats4gnat-0.2 scripts were used
with minor modifications to support cross testing.
* setup.def, gnatnewlib/gnatnewlib.in: Modified to pick up
all GNAT components.
* setup.def, gdb/gdb.spec.in,gnatnewlib/gnatnewlib.spec.in:
Updated to reflect gnat 3.13p successfully building.
* setup.def: Updated to gnat-3.13p and adjusted all versions
and revisions.
* gnatnewlib/gnatnewlib.spec.in: Include gcov per gnat 3.13p
build instructions.
* NOTE: GNAT 3.13p was not successfully built when this was committed.
and appear to be close for gdb.
