path: root/scripts-ada/mkgdbspec.in (follow)
* GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combinationJoel Sherrill2000-01-271-0/+2
| | | | and appear to be close for gdb.
* First attempt at debugging.Joel Sherrill2000-01-261-5/+5
* First cut at adding RPM scripts for building GNAT/RTEMS RPMs.Joel Sherrill2000-01-261-0/+88
