path: root/scripts-ada/mkgdbspec.in (follow)
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-131-1/+1
| | | | | | | | | | | * configure.in: Add RTEMS specific version of EXEEXT test. * mkgdbspec.in, mkgnatnewlibspec.in, gdb/gdb.spec.in, gnatnewlib/gnatnewlib.spec.in: Change to Target_alias to avoid conflicts with new autoconf/automake. * setup, setup.def, mkgnatnewlibspec.in: Add gnat_newlib_patch_version variable. * gnatnewlib/Makefile.am: Add i386-rtemscoff target in attempt to build it.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-2/+2
* GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combinationJoel Sherrill2000-01-271-0/+2
| | | | and appear to be close for gdb.
* First attempt at debugging.Joel Sherrill2000-01-261-5/+5
* First cut at adding RPM scripts for building GNAT/RTEMS RPMs.Joel Sherrill2000-01-261-0/+88
