* .cvsignore, ChangeLog, Makefile.am, README, TODO, buildall.in,
configure.ac, install-sh, missing, mkbinutilspec.in, mkbspspec.in,
mkgdbspec.in, mkgnatnewlibspec.in, mkinstalldirs, mkrpms, mkspec,
setup, setup.def, binutils/.cvsignore, binutils/Makefile.am,
binutils/binutils.spec.in, gdb/.cvsignore, gdb/Makefile.am,
gdb/gdb.spec.in, gnatnewlib/.cvsignore, gnatnewlib/Makefile.am,
gnatnewlib/gnatnewlib.spec.in: Per PR238 GNAT support is now
included in the main RPM specs which support gcc 3.1 and newer
since GNAT is in that source base now.
This is the next step towards automake:
* Two scripts for the toplevel directory:
a) "autogen" (Idea borrowed from libtool and gnome) A helper script to
recursively regenerate autoconf/automake/aclocal generated files
(Still not perfect but sufficient).
b) "missing" (from automake-cvs archive). This file normally is
automatically generated by automake, but we have to manually add
it until we add automake support to the toplevel configure script.
"chmod 755 missing autogen" after applying the patch.
* Changing the toplevel installation directory [ I can hear you
falling off the chair ;-]
Until now rtems installed itself to $(prefix)/rtems. This is in
contradiction to automake and GNU/FSF/Cygnus conventions.
With this patch applied, rtems installs into $(prefix).
To achieve the old behaviour simply configure with
--prefix=<install-dir>/rtems instead of --prefix=<install-dir>
This is a widely visible change and I can understand if you don't
like it at the present point. It enables us to use automake's
default installation paths instead of having to set up installation
paths manually. At the moment this doesn't help much, but in the not
so far future this would enable us to mix cpu-only dependent libraries
into the host's cross-compiler library and header files into
newlib's include directories, tools into the toolchain directories etc.
I would recommend to change the main installation directory, however it's
up to you to draw the final design decision.
