path: root/scripts-ada/gnatnewlib (follow)
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+3
| | | | adds .cvsignore.
* Successfully built some RPMs. There is still a lot of work to do.Joel Sherrill2000-01-312-21/+28
* GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combinationJoel Sherrill2000-01-271-136/+235
| | | | and appear to be close for gdb.
* First attempt at debugging.Joel Sherrill2000-01-262-97/+61
* First cut at adding RPM scripts for building GNAT/RTEMS RPMs.Joel Sherrill2000-01-262-0/+357
