* | 2000-10-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-10-18 | 1 | -1/+10 |
| | | | | | * setup.def, gdb/gdb.spec.in,gnatnewlib/gnatnewlib.spec.in: Updated to reflect gnat 3.13p successfully building. | ||||
* | 2000-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-08-30 | 1 | -3/+3 |
| | | | | | | | | * setup.def: Updated to gnat-3.13p and adjusted all versions and revisions. * gnatnewlib/gnatnewlib.spec.in: Include gcov per gnat 3.13p build instructions. * NOTE: GNAT 3.13p was not successfully built when this was committed. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -5/+8 |
* | Successfully built some RPMs. There is still a lot of work to do. | Joel Sherrill | 2000-01-31 | 1 | -21/+24 |
* | GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combination | Joel Sherrill | 2000-01-27 | 1 | -136/+235 |
| | | | | and appear to be close for gdb. | ||||
* | First attempt at debugging. | Joel Sherrill | 2000-01-26 | 1 | -61/+61 |
* | First cut at adding RPM scripts for building GNAT/RTEMS RPMs. | Joel Sherrill | 2000-01-26 | 1 | -0/+296 |
