* | 2000-10-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-10-18 | 1 | -1/+2 |
| | | | | | * setup.def, gdb/gdb.spec.in,gnatnewlib/gnatnewlib.spec.in: Updated to reflect gnat 3.13p successfully building. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 3 | -15/+12 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+3 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -0/+4 |
| | | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups | ||||
* | Successfully built some RPMs. There is still a lot of work to do. | Joel Sherrill | 2000-01-31 | 1 | -0/+4 |
* | Put Ada scripts in group gnatrtems. | Joel Sherrill | 2000-01-28 | 1 | -1/+1 |
* | GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combination | Joel Sherrill | 2000-01-27 | 1 | -8/+15 |
| | | | | and appear to be close for gdb. | ||||
* | First attempt at debugging. | Joel Sherrill | 2000-01-26 | 2 | -68/+32 |
* | First cut at adding RPM scripts for building GNAT/RTEMS RPMs. | Joel Sherrill | 2000-01-26 | 2 | -0/+203 |
