* | Successfully built some RPMs. There is still a lot of work to do. | Joel Sherrill | 2000-01-31 | 1 | -0/+4 |
* | Put Ada scripts in group gnatrtems. | Joel Sherrill | 2000-01-28 | 1 | -1/+1 |
* | GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combination | Joel Sherrill | 2000-01-27 | 1 | -8/+15 |
| | | | | and appear to be close for gdb. | ||||
* | First attempt at debugging. | Joel Sherrill | 2000-01-26 | 2 | -68/+32 |
* | First cut at adding RPM scripts for building GNAT/RTEMS RPMs. | Joel Sherrill | 2000-01-26 | 2 | -0/+203 |
