path: root/scripts-ada/gdb (follow)
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-131-14/+14
| | | | | | | | | | | * configure.in: Add RTEMS specific version of EXEEXT test. * mkgdbspec.in, mkgnatnewlibspec.in, gdb/gdb.spec.in, gnatnewlib/gnatnewlib.spec.in: Change to Target_alias to avoid conflicts with new autoconf/automake. * setup, setup.def, mkgnatnewlibspec.in: Add gnat_newlib_patch_version variable. * gnatnewlib/Makefile.am: Add i386-rtemscoff target in attempt to build it.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-181-1/+2
| | | | | * setup.def, gdb/gdb.spec.in,gnatnewlib/gnatnewlib.spec.in: Updated to reflect gnat 3.13p successfully building.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-123-15/+12
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+3
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-0/+4
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* Successfully built some RPMs. There is still a lot of work to do.Joel Sherrill2000-01-311-0/+4
* Put Ada scripts in group gnatrtems.Joel Sherrill2000-01-281-1/+1
* GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combinationJoel Sherrill2000-01-271-8/+15
| | | | and appear to be close for gdb.
* First attempt at debugging.Joel Sherrill2000-01-262-68/+32
* First cut at adding RPM scripts for building GNAT/RTEMS RPMs.Joel Sherrill2000-01-262-0/+203
