2002-08-20 | 2002-08-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -23/+0 | |
* .cvsignore, ChangeLog, Makefile.am, README, TODO, buildall.in, configure.ac, install-sh, missing, mkbinutilspec.in, mkbspspec.in, mkgdbspec.in, mkgnatnewlibspec.in, mkinstalldirs, mkrpms, mkspec, setup, setup.def, binutils/.cvsignore, binutils/Makefile.am, binutils/binutils.spec.in, gdb/.cvsignore, gdb/Makefile.am, gdb/gdb.spec.in, gnatnewlib/.cvsignore, gnatnewlib/Makefile.am, gnatnewlib/gnatnewlib.spec.in: Per PR238 GNAT support is now included in the main RPM specs which support gcc 3.1 and newer since GNAT is in that source base now. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+0 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * binutils/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * gdb/Makefile.am: Remove AUTOMAKE_OPTIONS. * gnatnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 1 | -11/+8 | |
2000-01-31 | Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+2 | |
that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups | |||||
2000-01-26 | First attempt at debugging. | Joel Sherrill | 1 | -36/+0 | |
2000-01-26 | First cut at adding RPM scripts for building GNAT/RTEMS RPMs. | Joel Sherrill | 1 | -0/+0 | |
1999-10-21 | Added sh-rtemself and m68k-rtemself. | Joel Sherrill | 1 | -17/+25 | |
1999-10-21 | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1 | -10/+13 | |
issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | |||||
1999-10-20 | New version from Ralf. | Joel Sherrill | 1 | -0/+50 | |
