* Makefile.am: Remove ACLOCAL_AMFLAGS.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
BSP needs to be eliminated.
issue and has mkbspspec in a better state. user.cfg is now
gone.
There are some miscellaneous changes to buildall done by Joel
to clean up the build process.
functioned.
Ralf's end of day version.
