path: root/scripts-ada/Makefile.am (follow)
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-311-1/+0
| | | | * Makefile.am: Remove ACLOCAL_AMFLAGS.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-17/+10
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-0/+4
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* First attempt at debugging.Joel Sherrill2000-01-261-1/+1
* First cut at adding RPM scripts for building GNAT/RTEMS RPMs.Joel Sherrill2000-01-261-0/+28
