* | rtems-bsps: add ability to print architecture/bsp list | Ryan Long | 2020-09-29 | 1 | -3/+40 |
| | | | | Closes #4099. | ||||
* | rtems-bsps: Add markdown support | Chris Johns | 2020-05-01 | 1 | -49/+320 |
| | | | | - Convert to python for better performance | ||||
* | rtems-bsps: Change 4.12 to 5 | Joel Sherrill | 2018-05-14 | 1 | -1/+1 |
* | bsps: Move make/custom/* files to bsps | Sebastian Huber | 2018-04-23 | 1 | -3/+3 |
| | | | | | | | | | Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | Allow rtems-bsps to be run from any path. | Chris Johns | 2018-04-09 | 1 | -1/+2 |
* | Config (.cfg) files are only valid if deeper than 5. | Chris Johns | 2016-07-06 | 1 | -1/+1 |
* | rtems-bsps: Update 4.11 to 4.12 | Joel Sherrill | 2016-07-05 | 1 | -1/+1 |
* | Fix rtems-bsps for GNU find hosts. | Chris Johns | 2015-12-16 | 1 | -2/+1 |
| | | | | | | | | Fixed as reported by Pavel: https://lists.rtems.org/pipermail/devel/2015-December/013189.html Closes #2498. | ||||
* | Display only valid BSPs, ignore other .cfg files. | Chris Johns | 2015-12-14 | 1 | -3/+16 |
| | | | | | | Show the architecture and BSP count. Closes #2491. | ||||
* | FreeBSD standard shell does not support substring expansion. | Chris Johns | 2014-07-10 | 1 | -2/+3 |
| | | | | Switch to using awk to get a string of spaces. | ||||
* | tools: Add rtems-bsp to list BSPs in the source tree. | Chris Johns | 2014-05-24 | 1 | -0/+35 |
This is a shell script that lists the BSPs in the source tree by architecture. The BSP name is given plus the relative path to BSP source files. The script uses the same hack, ie looking for *.cfg files, as the build system so it sees what the build system sees. |
