path: root/release_support (follow)
* 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-08-021-1/+4
| | | | | * Makefile.maint, configure.ac, release_support: Remove RDBG. * aclocal/enable-rdbg.m4: Removed.
* 2006-04-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-04-191-2/+2
| | | | * release_support: Fix typos.
* 2006-03-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-03-071-0/+1
| | | | | PR 694/rtems * release_support: Do not include .cvsignore files in release tarballs.
* 2004-07-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-07-281-0/+6
| | | | * release_support: Have a user name.
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-15/+15
| | | | | * release_support: Correct method used to find ChangeLog associated with the version.m4 files. Keep going until I can get a tarball cut.
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-2/+2
| | | | | * release_support: Use dirname not basedir. Keep going until I can get a tarball cut.
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-0/+92
* release_support: New file -- assistant to new cut_release script.
