2009-10-15 | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* custom/avrtest.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | |||||
2009-10-15 | Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | Ralf Corsepius | 15 | -354/+0 | |
2009-10-15 | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+7 | |
* custom/i386ex.cfg, custom/pc486.cfg, custom/ts_386ex.cfg, custom/pc386.cfg, custom/pc586.cfg, custom/pc386dx.cfg, custom/pc686.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | |||||
* custom/gensh1.cfg, custom/gensh2.cfg, custom/gensh4.cfg, custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh2e.cfg, custom/simsh4.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>). | |||||
2009-10-14 | 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* custom/Cygwin-posix.cfg, custom/FreeBSD-posix.cfg, custom/Linux-posix.cfg, custom/Solaris-posix.cfg, custom/posix.cfg: Remove. | |||||
2009-10-14 | Remove. | Ralf Corsepius | 5 | -108/+0 | |
2009-10-05 | add missing files | Thomas Doerfler | 2 | -0/+18 | |
2009-10-05 | renamed config files | Thomas Doerfler | 6 | -32/+20 | |
2009-10-01 | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 7 | -0/+114 | |
* Makefile.am: Add new BSP variants for ARM simulator in GDB. * custom/arm1136jfs.cfg, custom/arm1136js.cfg, custom/arm7tdmi.cfg, custom/arm920.cfg, custom/armcortexa9.cfg: New files. | |||||
2009-09-24 | 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 3 | -0/+31 | |
* Makefile.am: Add qemuppc.cfg. * custom/qemuppc.cfg: New file. | |||||
2009-09-14 | 2009-09-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* custom/gen83xx.cfg: Remove -funit-at-a-time. | |||||
2009-08-27 | 2009-08-27 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 3 | -3/+6 | |
* custom/leon2.cfg, custom/leon3.cfg: Fix typo. | |||||
2009-06-04 | 2009-06-04 Xi Yang <hiyangxi@gmail.com> | Joel Sherrill | 3 | -0/+26 | |
* Makefile.am: New Gumstix BSP. * custom/gumstix.cfg: New file. | |||||
2009-05-28 | 2009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2 | -0/+14 | |
* custom/csb637.cfg: New file. | |||||
2009-02-27 | added missing files | Thomas Doerfler | 3 | -0/+46 | |
2009-02-27 | * README: Added NCS. | Thomas Doerfler | 1 | -15/+8 | |
* Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot. | |||||
2009-02-19 | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+22 | |
* custom/simsh2e.cfg: New file. | |||||
2009-02-17 | 2009-02-17 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2 | -2/+6 | |
PR 1371/bsps * custom/mvme167.cfg: mvme167 needs to convert ELF -> pure binary RALF. | |||||
2009-02-17 | 2009-02-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2 | -0/+6 | |
* custom/uC5282.cfg: Add cvs Id. | |||||
2009-02-11 | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* custom/h8sxsim.cfg: Small H8SX should be optimized for size. | |||||
2009-02-06 | Regenerate list of custom/*.cfg. | Ralf Corsepius | 1 | -16/+111 | |
2009-02-06 | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* Makefile.am: Regenerate list of custom/*.cfg. | |||||
2009-02-06 | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+2 | |
* Makefile.am: Remove custom/HPUX9-posix.cfg. | |||||
2009-02-06 | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* custom/HPUX9-posix.cfg: Remove. | |||||
2009-02-06 | Remove. | Ralf Corsepius | 1 | -19/+0 | |
2009-02-05 | 2009-02-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -13/+4 | |
* custom/pck6.cfg: Remove. | |||||
2008-12-04 | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | 3 | -1/+37 | |
* Makefile.am: Add Lattice Mico32 support. * custom/lm32_evr.cfg: New file. | |||||
2008-11-20 | 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+24 | |
* custom/avrtest.cfg: New file. | |||||
2008-11-20 | 2008-11-20 Daron Chabot <daronchabot@gmail.com> | Joel Sherrill | 2 | -1/+6 | |
PR 1337/bsps * custom/pc386.cfg: Stripping .rodata section produces unusable executables for the i386-rtems target. | |||||
2008-10-14 | 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 3 | -1/+27 | |
* Makefile.am: Add h8sxsim BSP variant. * custom/h8sxsim.cfg: New file. | |||||
2008-10-10 | Added -msoft-float and removed -funit-at-a-time in CPU_CFLAGS | Thomas Doerfler | 2 | -1/+6 | |
2008-10-02 | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+25 | |
* custom/m32rsim.cfg: New file. | |||||
2008-10-02 | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+26 | |
* custom/m32csim.cfg: New file. | |||||
2008-10-02 | 2008-10-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* custom/virtex.cfg: Remove -Dvirtex. | |||||
2008-10-02 | Remove -Dvirtex. | Ralf Corsepius | 1 | -1/+1 | |
2008-10-02 | 2008-10-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* custom/pghplus.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg: Remove RTEMS_TQM_MODEL. | |||||
2008-10-02 | Remove RTEMS_TQM_MODEL. | Ralf Corsepius | 3 | -3/+1 | |
* custom/mpc5566evb.cfg, custom/mpc55xx.cfg: Remove RTEMS_BOARD_MODEL. | |||||
2008-10-02 | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 3 | -5/+2 | |
* custom/pgh360.cfg: Remove RTEMS_BOARD_MODEL. | |||||
2008-10-02 | 2008-10-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* custom/m5484FireEngine.cfg: Remove RTEMS_BOARD_MODEL. Remove RTEMS_54XX_DERIVATE (Unused). * custom/genmcf548x.cfg: Remove RTEMS_BOARD_MODEL. | |||||
2008-10-02 | Remove RTEMS_BOARD_MODEL. Remove RTEMS_54XX_DERIVATE (Unused). | Ralf Corsepius | 1 | -2/+0 | |
2008-10-02 | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 1 | -1/+1 | |
* custom/brs5l.cfg, custom/gen5200.cfg, custom/icecube.cfg, custom/pm520_cr825.cfg, custom/pm520_ze30.cfg: Remove RTEMS_BOARD_MODEL. | |||||
2008-10-02 | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 5 | -6/+1 | |
* custom/gen83xx.cfg, custom/hsc_cm01.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg: Remove RTEMS_BOARD_MODEL, RTEMS_83XX_DERIVATE. | |||||
2008-10-02 | Remove RTEMS_BOARD_MODEL, RTEMS_83XX_DERIVATE. | Ralf Corsepius | 4 | -8/+1 | |
2008-10-01 | 2008-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* custom/erc32.cfg: Revert accidental commit. | |||||
2008-10-01 | 2008-10-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+10 | |
* custom/brs5l.cfg, custom/gen5200.cfg, custom/gen83xx.cfg, custom/genmcf548x.cfg, custom/hsc_cm01.cfg, custom/icecube.cfg, custom/m5484FireEngine.cfg, custom/mpc5566evb.cfg, custom/mpc55xx.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg, custom/pgh360.cfg, custom/pghplus.cfg, custom/pm520_cr825.cfg, custom/pm520_ze30.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg: Back out parts of yesterdays changes. | |||||
2008-10-01 | Back out parts of yesterdays changes. | Ralf Corsepius | 17 | -7/+22 | |
