This patch addresses a few configuration issues and removes some
duplicate configuration files.
Background:
* some files used in AC_INIT were not unique enough and can lead to
problems if a user plays with configure scripts.
* the Makefile templates are independent of the target/cpu and bsp, so
the bsp dependent versions (c/src/make/Templates) are removed.
patch -p1 < rtems-rc-19990820-3.diff
rm -f c/src/make/Templates
ATTENTION: This patch removes several files and one directory :)
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
After upgrading my linux box to the brand new SuSE 6.2 release, which is
glibc-2.1 based, I came across a bug in RTEMS - IIRC, I even warned you
about it about 1/2 a year ago, but nothing has been done since then :-.
The *.m4 macros to check for SYSV/IPC are broken for linux/glibc2.1,
because they assume that linux always defines union semun, which isn't
true anymore for glibc2.1 (the manpage for semctl states _X_OPEN
specifies it this way). Therefore I have tried to implement a more
general approach for handling SYSV for unix/posix which checks for
presence of struct semun, instead of trying to evaluate OS specific
preprocessor symbols.
This approach is a bit adventureous, because I only tested it with
linux/glibc2.1 and linux/libc5, but not under other Unix variants RTEMS
supports. I am quite confident it will work on other hosts, too, but who
knows :-.
[FYI: I think this might also is the cause of some problems with RedHat
6.X / Mandrake linux recently reported on the rtems list -- rtems-4.0.0
can not be build for posix on any glibc2.1 based host]
Furthermore the patch below contains a couple of minor fixes and
configuration cleanups, which IMO should be applied before releasing a
new snapshot.
To apply this patch:
patch -p1 < rtems-rc-19990709-8.diff
I'm attaching a big patch for the ts_386ex BSP which adds and includes
the following:
1) Conversion to ELF format + minor code cleanups + documentation.
2) An Ada95 binding to FreeBSD sockets, based on Samuel Tardieu's
adasockets-0.1.3 package. This includes some sample applications.
3) Some Ada and C interfaces to add serial-port debugging to
programs. Comes with examples, too; the Ada one shows how
transparent adding the support can be. Note that Rosimildo sent me
the original C code.
The network stuff is not BSP specific, and could be added to your Ada
code collection. The debugging stuff is specific to the i386. Right
now, everything sits in my "tools" directory.
<raguet@crf.canon.fr>:
- the dec21140 driver code has been hardened (various bug fixed) Emmanuel,
- bug in the mcp750 init code have been fixed (interrupt stack/initial
stack initialization), BSS correctly cleared (Eric V)
- remote debugging over TCP/IP is nearly complete (berakpoints,
backtrace, variables,...) (Eric V),
- exception handling code has also been improved in order to fully
support RDBG requirements (Eric V),
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
definitions of CONSOLE_USE_POLLED to be !CONSOLE_USE_INTERRUPTS
instead of ~CONSOLE_USE_INTERRUPTS.
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
+ interrupt masking correction
+ FPU rev.B workaround
+ minor erc32 related fixes
Fixes/Changes:
--target=no_cpu*rtems.
before adding :-)
toplevel/configure.in
files changed to RTEMS_CPU
* Use $(PACKHEX) instead of $(PROJECT_TOOLS)/packhex
* Set HAS_RDBG=no for ts_386ex otherwise building it will attempt to
compile librdbg for pc386
* RTEMS_CPU for score603e should be "powerpc" instead of "ppc" (Should
not have any side-effects, because RTEMS_CPU in make/custom/*.cfg
already is overridden in make/target.cfg.in)
<corsepiu@faw.uni-ulm.de>:
This patch removes MKDIR from RTEMS source tree and fixes another small
bug in the definition of INSTALL_VARIANT (cf. to the patch itself for
details, it should be self-explanatory)
After applying the patch please do:
cvs rm aclocal/mkdir.m4
described in the message following this paragraph. This patch also includes
a mcp750 BSP.
From valette@crf.canon.fr Mon Jun 14 10:03:08 1999
Date: Tue, 18 May 1999 01:30:14 +0200 (CEST)
To: joel@oarcorp.com
Cc: raguet@crf.canon.fr, rtems-snapshots@oarcorp.com, valette@crf.canon.fr
Subject: Questions/Suggestion regarding RTEMS PowerPC code (long)
Dear knowledgeable RTEMS powerpc users,
As some of you may know, I'm currently finalizing a port
of RTEMS on a MCP750 Motorola board. I have done most
of it but have some questions to ask before submitting
the port.
In order to understand some of the changes I have made
or would like to make, maybe it is worth describing the
the MCP750 is a COMPACT PCI powerpc board with :
1) a MPC750 233 MHz processor,
2) a raven bus bridge/PCI controller that
implement an OPENPIC compliant interrupt controller,
3) a VIA 82C586 PCI/ISA bridge that offers a PC
compliant IO for keyboard, serial line, IDE, and
the well known PC 8259 cascaded PIC interrupt
architecture model,
4) a DEC 21140 Ethernet controller,
5) the PPCBUG Motorola firmware in flash,
6) A DEC PCI bridge,
This architecture is common to most Motorola 60x/7xx
board except that :
1) on VME board, the DEC PCI bridge is replaced by
a VME chipset,
2) the VIA 82C586 PCI/ISA bridge is replaced by
another bridge that is almost fully compatible
with the via bridge...
So the port should be a rather close basis for many
60x/7xx motorola board...
On this board, I already have ported Linux 2.2.3 and
use it both as a development and target board.
Now the questions/suggestions I have :
1) EXCEPTION CODE
As far as I know exceptions on PPC are handled like
interrupts. I dislike this very much as :
a) Except for the decrementer exception (and
maybe some other on mpc8xx), exceptions are
not recoverable and the handler just need to print
the full context and go to the firmware or debugger...
b) The interrupt switch is only necessary for the
decrementer and external interrupt (at least on
6xx,7xx).
c) The full context for exception is never saved and
thus cannot be used by debugger... I do understand
the most important for interrupts low level code
is to save the minimal context enabling to call C
code for performance reasons. On non recoverable
exception on the other hand, the most important is
to save the maximum information concerning proc status
in order to analyze the reason of the fault. At
least we will need this in order to implement the
port of RGDB on PPC
==> I wrote an API for connecting raw exceptions (and thus
raw interrupts) for mpc750. It should be valid for most
powerpc processors... I hope to find a way to make this coexist
with actual code layout. The code is actually located
in lib/libcpu/powerpc/mpc750 and is thus optional
(provided I write my own version of exec/score/cpu/powerpc/cpu.c ...)
See remark about files/directory layout organization in 4)
2) Current Implementation of ISR low level code
I do not understand why the MSR EE flags is cleared
again in exec/score/cpu/powerpc/irq_stubs.S
#if (PPC_USE_SPRG)
mfmsr r5
mfspr r6, sprg2
#else
lwz r6,msr_initial(r11)
lis r5,~PPC_MSR_DISABLE_MASK@ha
ori r5,r5,~PPC_MSR_DISABLE_MASK@l
and r6,r6,r5
mfmsr r5
#endif
Reading the doc, when a decrementer interrupt or an
external interrupt is active, the MSR EE flag is already
cleared. BTW if exception/interrupt could occur, it would
trash SRR0 and SRR1. In fact the code may be useful to set
MSR[RI] that re-enables exception processing. BTW I will need
to set other value in MSR to handle interrupts :
a) I want the MSR[IR] and MSR[DR] to be set for
performance reasons and also because I need DBAT
support to have access to PCI memory space as the
interrupt controller is in the PCI space.
Reading the code, I see others have the same kind of request :
/* SCE 980217
* We need address translation ON when we call our ISR routine
mtmsr r5
This is just another prof that even the lowest level
IRQ code is fundamentally board dependent and
not simply processor dependent especially when
the processor use external interrupt controller
because it has a single interrupt request line...
Note that if you look at the PPC code high level interrupt
handling code, as the "set_vector" routine that really connects
the interrupt is in the BSP/startup/genpvec.c,
the fact that IRQ handling is BSP specific is DE-FACTO
acknowledged.
I know I have already expressed this and understand that this
would require some heavy change in the code but believe
me you will reach a point where you will not be able
to find a compatible while optimum implementation for low level
interrupt handling code...) In my case this is already true...
So please consider removing low level IRQ handling from
exec/score/cpu/* and only let there exception handling code...
Exceptions are usually only processor dependent and do
not depend on external hardware mechanism to be masked or
acknowledged or re-enabled (there are probably exception but ...)
I have already done this for pc386 bsp but need to make it again.
This time I will even propose an API.
3) R2/R13 manipulation for EABI implementation
I do not understand the handling of r2 and r13 in the
EABI case. The specification for r2 says pointer to sdata2,
sbss2 section => constant. However I do not see -ffixed-r2
passed to any compilation system in make/custom/*
(for info linux does this on PPC).
So either this is a default compiler option when choosing
powerpc-rtems and thus we do not need to do anything with
this register as all the code is compiled with this compiler
and linked together OR this register may be used by rtems code
and then we do not need any special initialization or
handling.
The specification for r13 says pointer to the small data
area. r13 argumentation is the same except that as far
as I know the usage of the small data area requires
specific compiler support so that access to variables is
compiled via loading the LSB in a register and then
using r13 to get full address... It is like a small
memory model and it was present in IBM C compilers.
=> I propose to suppress any specific code for r2 and
r13 in the EABI case.
4) Code layout organization (yes again :-))
I think there are a number of design flaws in the way
the code is for ppc organized and I will try to point them out.
I have been beaten by this again on this new port, and
was beaten last year while modifying code for pc386.
a) exec/score/cpu/* vs lib/libcpu/cpu/*.
I think that too many things are put in exec/score/cpu that
have nothing to do with RTEMS internals but are rather
related to CPU feature.
This include at least :
a) registers access routine (e.g GET_MSR_Value),
b) interrupt masking/unmasking routines,
c) cache_mngt_routine,
d) mmu_mngt_routine,
e) Routines to connect the raw_exception, raw_interrupt
handler,
b) lib/libcpu/cpu/powerpc/*
With a processor family as exuberant as the powerpc family,
and their well known subtle differences (604 vs 750) or
unfortunately majors (8xx vs 60x) the directory structure
is fine (except maybe the names that are not homogeneous)
powerpc
ppc421 mpc821 ...
I only needed to add mpc750. But the fact that libcpu.a was not
produced was a pain and the fact that this organization may
duplicates code is also problematic.
So, except if the support of automake provides a better solution
I would like to propose something like this :
powerpc
mpc421 mpc821 ... mpc750 shared wrapup
with the following rules :
a) "shared" would act as a source container for sources that may
be shared among processors. Needed files would be compiled inside
the processor specific directory using the vpath Makefile
mechanism. "shared" may also contain compilation code
for routine that are really shared and not worth to inline...
(did not found many things so far as registers access routine
ARE WORTH INLINING)... In the case something is compiled there,
it should create libcpushared.a
b) layout under processor specific directory is free provided
that
1)the result of the compilation process exports :
libcpu/powerpc/"PROC"/*.h in $(PROJECT_INCLUDE)/libcpu
2) each processor specific directory creates
a library called libcpuspecific.a
Note that this organization enables to have a file that
is nearly the same than in shared but that must differ
because of processor differences...
c) "wrapup" should create libcpu.a using libcpushared.a
libcpuspecific.a and export it $(PROJECT_INCLUDE)/libcpu
The only thing I have no ideal solution is the way to put shared
definitions in "shared" and only processor specific definition
in "proc". To give a concrete example, most MSR bit definition
are shared among PPC processors and only some differs. if we create
a single msr.h in shared it will have ifdef. If in msr.h we
include libcpu/msr_c.h we will need to have it in each prowerpc
specific directory (even empty). Opinions are welcomed ...
Note that a similar mechanism exist in libbsp/i386 that also
contains a shared directory that is used by several bsp
like pc386 and i386ex and a similar wrapup mechanism...
NB: I have done this for mpc750 and other processors could just use
similar Makefiles...
c) The exec/score/cpu/powerpc directory layout.
I think the directory layout should be the same than the
libcpu/powerpc. As it is not, there are a lot of ifdefs
inside the code... And of course low level interrupt handling
code should be removed...
Besides that I do not understand why
1) things are compiled in the wrap directory,
2) some includes are moved to rtems/score,
I think the "preinstall" mechanism enables to put
everything in the current directory (or better in a per processor
directory),
5) Interrupt handling API
Again :-). But I think that using all the features the PIC
offers is a MUST for RT system. I already explained in the
prologue of this (long and probably boring) mail that the MCP750
boards offers an OPENPIC compliant architecture and that
the VIA 82586 PCI/ISA bridge offers a PC compatible IO and
PIC mapping. Here is a logical view of the RAVEN/VIA 82586
interrupt mapping :
--------- 0 ------
| OPEN | <-----|8259|
| PIC | | | 2 ------
|(RAVEN)| | | <-----|8259|
| | | | | | 11
| VIA PCI/ISA bridge
| x
-------- PCI interrupts
OPENPIC offers interrupt priorities among PCI interrupts
and interrupt selective masking. The 8259 offers the same kind
of feature. With actual powerpc interrupt code :
1) there is no way to specify priorities among
interrupts handler. This is REALLY a bad thing.
For me it is as importnat as having priorities
for threads...
2) for my implementation, each ISR should
contain the code that acknowledge the RAVEN
and 8259 cascade, modify interrupt mask on both
chips, and reenable interrupt at processor level,
..., restore then on interrupt return,.... This code
is actually similar to code located in some
genpvec.c powerpc files,
3) I must update _ISR_Nesting_level because
irq.inl use it...
4) the libchip code connects the ISR via set_vector
but the libchip handler code does not contain any code to
manipulate external interrupt controller hardware
in order to acknoledge the interrupt or re-enable
them (except for the target hardware of course)
So this code is broken unless set_vector adds an
additionnal prologue/epilogue before calling/returning
from in order to acknoledge/mask the raven and the
8259 PICS... => Anyway already EACH BSP MUST REWRITE
PART OF INTERRUPT HANDLING CODE TO CORRECTLY IMPLEMENT
SET_VECTOR.
I would rather offer an API similar to the one provided
in libbsp/i386/shared/irq/irq.h so that :
1) Once the driver supplied methods is called the
only things the ISR has to do is to worry about the
external hardware that triggered the interrupt.
Everything on openpic/VIA/processor would have been
done by the low levels (same things as set-vector)
2) The caller will need to supply the on/off/isOn
routine that are fundamental to correctly implements
debuggers/performance monitoring is a portable way
3) A globally configurable interrupt priorities
mechanism...
I have nothing against providing a compatible
set_vector just to make libchip happy but
as I have already explained in other
mails (months ago), I really think that the ISR
connection should be handled by the BSP and that no
code containing irq connection should exist the
rtems generic layers... Thus I really dislike
libchip on this aspect because in a long term
it will force to adopt the less reach API
for interrupt handling that exists (set_vector).
Additional note : I think the _ISR_Is_in_progress()
inline routine should be :
1) Put in a processor specific section,
2) Should not rely on a global variable,
As :
a) on symmetric MP, there is one interrupt level
per CPU,
b) On processor that have an ISP (e,g 68040),
this variable is useless (MSR bit testing could
be used)
c) On PPC, instead of using the address of the
variable via __CPU_IRQ_info.Nest_level a dedicated
SPR could be used.
NOTE: most of this is also true for _Thread_Dispatch_disable_level
END NOTE
Please do not take what I said in the mail as a criticism for
anyone who submitted ppc code. Any code present helped me
a lot understanding PPC behavior. I just wanted by this
mail to :
1) try to better understand the actual code,
2) propose concrete ways of enhancing current code
by providing an alternative implementation for MCP750. I
will make my best effort to try to brake nothing but this
is actually hard due to the file layout organisation.
3) make understandable some changes I will probably make
if joel let me do them :-)
Any comments/objections are welcomed as usual.
__
/ ` Eric Valette
/-- __ o _. Canon CRF
(___, / (_(_(__ Rue de la touche lambert
35517 Cesson-Sevigne Cedex
FRANCE
Tel: +33 (0)2 99 87 68 91 Fax: +33 (0)2 99 84 11 30
E-mail: valette@crf.canon.fr
exceptions and makes debug stack traces impossible.
University of British Columbia. The BSP is for:
Yes, this is the "entry model" of a series of boards from Technologic
Systems. Costs <$200 I believe. They have a WWW page at www.t-systems.com.
I am letting them know about the availability of this BSP too.
future.
cd <rtems-source-tree>
This is an attempt to work-around a couple of nasty bugs in librdbg's
Makefiles and configuration:
Configure and build RTEMS as below:
configure --enable-networking --enable-rdbg --target=i386-rtems
make RTEMS_BSP=i386ex
After a few minutes you will notice that building aborts in librdbg ....
Analysis:
1) librdbg is tried to be built, though librdbg is not supported and the
required directory hierarchy librdbg/i386/i386ex/ is not existant.
The cause for this is incorrect setting of HAS_RDBG in most
make/custom/*.cfg files (except pc386.cfg). At the moment all
custom/*.cfg files (except pc386.cfg) in general are required to contain
HAS_RDBG=no. However, having HAS_NETWORKING=no in most custom/*.cfg
files and the toplevel configure script suppress building librdbg for
all CPUs except of i386.
=> The i386ex BSP falls though this scheme and librdbg is tried to be
build (CPU=i386 and HAS_NETWORKING=yes).
2) The Makefile.ins below lib/librdbg in general support i386/pc386 only
and are not capable to be used for multiple CPUs or BSPs (RPCGEN
generates it's target and bsp-specific files into librdbg/, therefore no
other CPU or BSP can ever be built afterwards). This problem is hidden
until now, because only a single CPU/BSP pair (i386/pc386) is really
supported.
3) The Makefile.ins below lib/librdbg can delete source files due to
improper handling of source files (make clean removes the *.x files in
the source-tree when configuring inside of the source-tree).
The patch below tries to work-around these problems for the i386ex and
the pc386 BSPs. This work-around is rather fragile (it applies rpcgen
-D, I don't know how portable this is) and incomplete (all custom/*.cfg
except of pc386.cfg should contain HAS_RDBG=no), nevertheless it should
FYI: I am not talking about using "make -C <dir>", which probably
is much faster on M$ hosts than RTEMS's implementation, but about
removing --enable-gmake-print support and to apply a variant of
automake's subdirectory.
Automake's subdirectory rule seems to be a little bit faster, but I
wouldn't bet on this.
Attached to this mail is my proposal.
After applying the patch, please run
cvs rm aclocal/enable-gmake-print.m4
Installing of bsp_specs for aliased bsps is broken. Instead of installing
RTEMS_BSP_FAMILY/bsp_specs, RTEMS_BSP/bsp_specs was tried to be installed.
The patch below should fix this problem (tested with mips64orion p4600 and
p4650).
releasing a snapshot:
1. Cleanup to aclocal/
cvs rm -f aclocal/cygwin.m4
cvs rm -f aclocal/exeext.m4
2. rtems-rc-19990328-0.diff
Some (minor) bug-fixes:
3. rtems-rc-19990328-1.diff
-ac -am -ci.
(reduces size of configure.in
With my most recent automake patch (automake II) we could even simplify more
files below make/, because the host-compiler related parts of those files
aren't used anymore :-.
Whatsoever, the patch below should fix this problem.
Note: This is a mere bug fix, it doesn't move any of the variables involved
to target.cfg nor does it try to eliminate any variable.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
This is the next step towards automake:
* Two scripts for the toplevel directory:
a) "autogen" (Idea borrowed from libtool and gnome) A helper script to
recursively regenerate autoconf/automake/aclocal generated files
(Still not perfect but sufficient).
b) "missing" (from automake-cvs archive). This file normally is
automatically generated by automake, but we have to manually add
it until we add automake support to the toplevel configure script.
"chmod 755 missing autogen" after applying the patch.
* Changing the toplevel installation directory [ I can hear you
falling off the chair ;-]
Until now rtems installed itself to $(prefix)/rtems. This is in
contradiction to automake and GNU/FSF/Cygnus conventions.
With this patch applied, rtems installs into $(prefix).
To achieve the old behaviour simply configure with
--prefix=<install-dir>/rtems instead of --prefix=<install-dir>
This is a widely visible change and I can understand if you don't
like it at the present point. It enables us to use automake's
default installation paths instead of having to set up installation
paths manually. At the moment this doesn't help much, but in the not
so far future this would enable us to mix cpu-only dependent libraries
into the host's cross-compiler library and header files into
newlib's include directories, tools into the toolchain directories etc.
I would recommend to change the main installation directory, however it's
up to you to draw the final design decision.
are:
problems that prevented the 19990302 snapshot from running on
the efi332.
I'm happy to report that rtems-19990302 is running on the efi332
board. I have enclosed a few minor patches below to the efi332 bsp. All
patches are within that library but one. make/custom/efi332.cfg has a
patch to select the right CPU_CFLAGS (at one time -m68332 was a
problem... -mcpu32 or -m68332 work fine now).
FP issues on this target:
The default variants of libc, libm and libgcc assume that a 68881
coprocessor is present. Without the FPSP, any floating point operation,
including printf() with a "%f" format specifier, is likely to cause an
unimplemented instruction exception.
The FPSP works with the default variants of libc, libm and libgcc. It does not
work in conjunction with the msoft-float variants. The paranoia test goes into
an infinite loop at milestone 40. I am guessing that floor() is returning an
incorrect value.
The msoft-float variants of libc, libm and libgcc appear to do floating point
I/O properly. They only failed in paranoia. Offhand, I can't think of why they
would conflict with the FPSP, so I think that there is something wrong with the
msoft-float code. It might be my installation.
Given my experiences, I decided to install the FPSP in bsp_start(), and to link
against the default variants of libc, libm and libgcc. This causes the
executables to increase in size by about 60 KB. The README file and the
mvme167.cfg specify how to remove the FPSP, and how to link against the
msoft-float variants of the libraries. This is not what Eric Norum had done: on
my host, his gen68360_040 port links RTEMS code with the msoft-float variants
of libc and libm, and the default variant of libgcc. In this configuration, the
output of printf() with "%f" is garbage on my target.
is long but I hate to lose the information so I am including it here.
> I am still fixing and recompiling but this is the issue that was not the
> result of another patch. This is a fundamental build issue that I value
> your opinion on.
This is difficult issue (I.e. I have no destinct solution for it)
Background:
(gnu-) make's implicit rules apply CFLAGS, CPPFLAGS, CXXFLAGS, ASFLAGS and
LDFLAGS (cf. make.info/Implicit Rules/Catalogue of Rules), only.
In brief:
CPPFLAGS .. passed to the c-preprocessor
CFLAGS ... passed to the c-compiler
CXXFLAGS ... equivalent to CFLAGS but passed to the c++ compiler
(Attention: CFLAGS is not passed to the c++ compiler)
ASFLAGS .. equivalent to CFLAGS, but passed to the assembler
LDFLAGS .. equivalent to CFLAGS, but passed to the linker
A bit oversimplifying, these make rules are as follows
.c.o:
$(CC) $(CPPFLAGS) $(CFLAGS) -c
.cc.o:
$(CXX) $(CPPFLAGS) $(CXXFLAGS) -c
.S.s:
$(CPP) $(CPPFLAGS)
.s.o:
$(AS) $(ASFLAGS)
My reading of the documentation (make.info) is that {AS|AR|CC|CXX|CPP}FLAGS
are ment to be passed to the related tools directly, however examinating
the rule set of gmake (gmake -p -f /dev/null") shows that many rules use
$(CC) instead of the related tools (eg. linker rules) etc.
I.e. these flags should not rely on being passed through cpp or gcc. With
gcc being the common frontend for all of these tools of a gnu-toolchain the
situation becomes difficult (Which option is passed to whom and which tool
really uses it?), because these variable can also contain the toolchain's
frontend (eg. AS=gcc, LD=gcc, CPP=gcc -E).
For some commonly used options the situation is quite clear:
* -g -> CFLAGS
* -OX -> CFLAGS
* -D -> CPPFLAGS
* -A -> CPPFLAGS
But where to add -m, -B, -specs, -qrtems_XXX ?
* -B, -specs, -qrtems_XXX are gcc-frontend options
* -m is a combinations of flags to go to different destinations, in many
(all?) cases, the following is valid
-m is expanded by gcc into a set of -D and -A options
-m is interpreted by cc1 as a machine flag to generate a specific
instruction set.
-m is interpreted by gcc as an implicit linker search path for multilibs to
set up calls to LD.
>From my point of view this indicates we can either destingush between these
different usages (= separately add -m to CFLAGS, LDFLAGS etc) or to add it
to CPPFLAGS and use gcc (the frontend) instead of calling each tool
directly (less error prone) -- I vote for CPPFLAGS, but I am not sure.
Now, where to add CPU_CFLAGS?
AFAIS, in probably all cases CPU_CFLAGS contain -D -A, and -m options,
only.
* -D and -A are supposed to go to CPPFLAGS
* -mXXX options can have multiple meanings (It can be gcc, collect2/ld and
cc1/cc1plus option simultaneously)
Here, I made a mistake - I destinguished between CPU_DEFINES to be added to
CPPFLAGS and CPU_CFLAGS to be added to CFLAGS and CXXFLAGS (cf.
gcc-target-default.cfg), generally assuming CPU_CFLAGS are CFLAGS.
This breaks preprocessing *.S into *.i files because CPU_CFLAGS flags were
not added to CPPFLAGS. Hence *all* *.S were compiled without taking
-mXX-flags into account. The i960/cvme BSP was the only one which
explicitly checked for a specific -m flag (-mca) and refused to compile
without it -- all other CPUs/BSPs silently swallowed this.
IMO, we can either
1) add CPU_CFLAGS and CPU_DEFINES to CPPFLAGS, thus silently convert
CPU_CFLAGS's meaning into CPU_DEFINES (Alternative solution: rename
CPU_CFLAGS to CPU_DEFINES and merge CPU_FLAGS with CPU_DEFINES).
or
2) destinguish between CPU_DEFINES and CPU_CFLAGS. In this case we would
need to check the contents of each CPU_CFLAGS in custom/*.cfg and move the
some parts of the contents to CPU_DEFINES and keep other parts in
CPU_CFLAGS (CFLAGS must contain options for the c/c++-compiler only!).
Though Solution 2) is the clearer one, I implemented 1) which is the
simplier one (the patch below).
ATTENTION: This patch is small in size, but affects almost everything.
Additional complications araise with linking:
Some BSPs call LD and AS directly (esp. gcc-2.7 make-exe rules). If LD=gcc
then LDFLAGS are supposed to be gcc-options, but if LD=ld then LDFLAGS is
supposed to contain ld-options.
An analog thought is valid for AS, but luckily enough ASFLAGS is not used
of inside the whole source tree.
Most RTEMS' custom/*.cfg use $(CC) $(CFLAGS) to link with gcc-2.8 make-exe
rules. With the patch below (CPU_CFLAGS added to CPPFLAGS) this means
CPU_CFLAGS will not be passed to the linker, which is incorrect for
multilibbed CPU's.
gmake's default rule set contains a variety of rules for linking, all
ending up in calling $(CC) $(LDFLAGS) for linking at their very end.
IMO, this means we should use something like
LINK.o = $(CC) $(LDFLAGS) in gcc-target-default.cfg
+ modify all gcc-2.8 make-exe rules to use
$(LINK.o) .......
+ setup LDFLAGS according to the requirements of the above.
I.e. we should use $(CC) for linking instead of calling the linker (LD)
directly and set LDFLAGS = $(CPPFLAGS) $(CFLAGS) or similar.
> 3) rtems-rc-19990131-2.diff
> now)
> patches will apply then ;-.
> 2) rtems-rc-19990131-1.diff
> Rework of compilers/*.cfg files (esp. gcc-target-default.cfg) to adapt
> the flags/makefile variables to automake and make standards (cf.
> make.info - implicit rules/variables).
> This patch is rather risky and may probably break things, but is an
> essential step towards automake.
> FWIW: It also reverts the i386-ASMFLAGS/ASFLAGS-patch, which was wrong,
> as I had to experience ;-.
