* | 2009-08-27 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-08-27 | 3 | -3/+6 |
| | | | | * custom/leon2.cfg, custom/leon3.cfg: Fix typo. | ||||
* | 2009-06-04 Xi Yang <hiyangxi@gmail.com> | Joel Sherrill | 2009-06-04 | 3 | -0/+26 |
| | | | | | * Makefile.am: New Gumstix BSP. * custom/gumstix.cfg: New file. | ||||
* | 2009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-05-28 | 2 | -0/+14 |
| | | | | * custom/csb637.cfg: New file. | ||||
* | added missing files | Thomas Doerfler | 2009-02-27 | 3 | -0/+46 |
* | * README: Added NCS. | Thomas Doerfler | 2009-02-27 | 1 | -15/+8 |
| | | | | | | | | | | | | | | | * Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot. | ||||
* | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-19 | 2 | -0/+22 |
| | | | | * custom/simsh2e.cfg: New file. | ||||
* | 2009-02-17 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2009-02-17 | 2 | -2/+6 |
| | | | | | PR 1371/bsps * custom/mvme167.cfg: mvme167 needs to convert ELF -> pure binary RALF. | ||||
* | 2009-02-17 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-17 | 2 | -0/+6 |
| | | | | * custom/uC5282.cfg: Add cvs Id. | ||||
* | 2009-02-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-11 | 2 | -1/+5 |
| | | | | * custom/h8sxsim.cfg: Small H8SX should be optimized for size. | ||||
* | Regenerate list of custom/*.cfg. | Ralf Corsepius | 2009-02-06 | 1 | -16/+111 |
* | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-06 | 1 | -0/+1 |
| | | | | * Makefile.am: Regenerate list of custom/*.cfg. | ||||
* | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-06 | 2 | -1/+2 |
| | | | | * Makefile.am: Remove custom/HPUX9-posix.cfg. | ||||
* | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-06 | 1 | -0/+4 |
| | | | | * custom/HPUX9-posix.cfg: Remove. | ||||
* | Remove. | Ralf Corsepius | 2009-02-06 | 1 | -19/+0 |
* | 2009-02-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-05 | 2 | -13/+4 |
| | | | | * custom/pck6.cfg: Remove. | ||||
* | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | 2008-12-04 | 3 | -1/+37 |
| | | | | | * Makefile.am: Add Lattice Mico32 support. * custom/lm32_evr.cfg: New file. | ||||
* | 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-11-20 | 2 | -0/+24 |
| | | | | * custom/avrtest.cfg: New file. | ||||
* | 2008-11-20 Daron Chabot <daronchabot@gmail.com> | Joel Sherrill | 2008-11-20 | 2 | -1/+6 |
| | | | | | | PR 1337/bsps * custom/pc386.cfg: Stripping .rodata section produces unusable executables for the i386-rtems target. | ||||
* | 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-14 | 3 | -1/+27 |
| | | | | | * Makefile.am: Add h8sxsim BSP variant. * custom/h8sxsim.cfg: New file. | ||||
* | Added -msoft-float and removed -funit-at-a-time in CPU_CFLAGS | Thomas Doerfler | 2008-10-10 | 2 | -1/+6 |
* | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-02 | 2 | -0/+25 |
| | | | | * custom/m32rsim.cfg: New file. | ||||
* | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-02 | 2 | -0/+26 |
| | | | | * custom/m32csim.cfg: New file. | ||||
* | 2008-10-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-10-02 | 1 | -0/+4 |
| | | | | * custom/virtex.cfg: Remove -Dvirtex. | ||||
* | Remove -Dvirtex. | Ralf Corsepius | 2008-10-02 | 1 | -1/+1 |
* | 2008-10-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-10-02 | 1 | -0/+5 |
| | | | | | * custom/pghplus.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg: Remove RTEMS_TQM_MODEL. | ||||
* | Remove RTEMS_TQM_MODEL. | Ralf Corsepius | 2008-10-02 | 3 | -3/+1 |
| | | | | | * custom/mpc5566evb.cfg, custom/mpc55xx.cfg: Remove RTEMS_BOARD_MODEL. | ||||
* | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 2008-10-02 | 3 | -5/+2 |
| | | | | * custom/pgh360.cfg: Remove RTEMS_BOARD_MODEL. | ||||
* | 2008-10-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-10-02 | 1 | -0/+6 |
| | | | | | | * custom/m5484FireEngine.cfg: Remove RTEMS_BOARD_MODEL. Remove RTEMS_54XX_DERIVATE (Unused). * custom/genmcf548x.cfg: Remove RTEMS_BOARD_MODEL. | ||||
* | Remove RTEMS_BOARD_MODEL. Remove RTEMS_54XX_DERIVATE (Unused). | Ralf Corsepius | 2008-10-02 | 1 | -2/+0 |
* | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 2008-10-02 | 1 | -1/+1 |
| | | | | | * custom/brs5l.cfg, custom/gen5200.cfg, custom/icecube.cfg, custom/pm520_cr825.cfg, custom/pm520_ze30.cfg: Remove RTEMS_BOARD_MODEL. | ||||
* | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 2008-10-02 | 5 | -6/+1 |
| | | | | | | * custom/gen83xx.cfg, custom/hsc_cm01.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg: Remove RTEMS_BOARD_MODEL, RTEMS_83XX_DERIVATE. | ||||
* | Remove RTEMS_BOARD_MODEL, RTEMS_83XX_DERIVATE. | Ralf Corsepius | 2008-10-02 | 4 | -8/+1 |
* | 2008-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-01 | 2 | -1/+5 |
| | | | | * custom/erc32.cfg: Revert accidental commit. | ||||
* | 2008-10-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-10-01 | 1 | -0/+10 |
| | | | | | | | | | | * custom/brs5l.cfg, custom/gen5200.cfg, custom/gen83xx.cfg, custom/genmcf548x.cfg, custom/hsc_cm01.cfg, custom/icecube.cfg, custom/m5484FireEngine.cfg, custom/mpc5566evb.cfg, custom/mpc55xx.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg, custom/pgh360.cfg, custom/pghplus.cfg, custom/pm520_cr825.cfg, custom/pm520_ze30.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg: Back out parts of yesterdays changes. | ||||
* | Back out parts of yesterdays changes. | Ralf Corsepius | 2008-10-01 | 17 | -7/+22 |
* | 2008-10-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-10-01 | 3 | -3/+6 |
| | | | | * custom/gen83xx.cfg, custom/lpc2478.cfg: Remove warning flags. | ||||
* | 2008-09-30 Jennifer Averett <jennifer.averett@oarcorp.com> | Joel Sherrill | 2008-09-30 | 2 | -1/+6 |
| | | | | | * custom/score603e.cfg: Modifications required to run on hardware. Some cleanup. | ||||
* | 2008-09-30 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-30 | 1 | -0/+5 |
| | | | | | * custom/m5484FireEngine.cfg: Eliminate RTEMS_54XX_DERIVATE (Unused). | ||||
* | Eliminate RTEMS_54XX_DERIVATE (Unused). | Ralf Corsepius | 2008-09-30 | 1 | -1/+0 |
| | | | | | * custom/pghplus.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg: Eliminate RTEMS_TQM_MODEL (Unused). | ||||
* | Eliminate RTEMS_TQM_MODEL (Unused). | Ralf Corsepius | 2008-09-30 | 3 | -3/+1 |
* | 2008-09-30 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-30 | 1 | -0/+9 |
| | | | | | | | | | * custom/brs5l.cfg, custom/gen5200.cfg, custom/gen83xx.cfg, custom/genmcf548x.cfg, custom/hsc_cm01.cfg, custom/icecube.cfg, custom/lpc2478.cfg, custom/m5484FireEngine.cfg, custom/mpc5566evb.cfg, custom/mpc55xx.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg, custom/pgh360.cfg, custom/pm520_cr825.cfg custom/pm520_ze30.cfg: Remove RTEMS_BOARD_MODEL. | ||||
* | Remove RTEMS_BOARD_MODEL. | Ralf Corsepius | 2008-09-30 | 15 | -19/+5 |
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 4 | -9/+9 |
| | | | | | * custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh4.cfg: Make all use RTEMS_BSP_FAMILY. | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 1 | -0/+4 |
| | | | | * custom/simsh1.cfg, custom/simsh2.cfg: Remove Author notice. | ||||
* | Remove Author notice. | Ralf Corsepius | 2008-09-29 | 2 | -4/+0 |
