path: root/make (follow)
* 2000-05-25 Matt Cross <profesor@gweep.net>Joel Sherrill2001-05-251-0/+93
| | | | | | | | | | | | | | | | | * New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * .cvsignore, ChangeLog Makefile.am, README, bsp_specs, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in, console/.cvsignore, console/Makefile.am, console/console.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c, spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c, start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore, startup/Makefile.am, startup/bspclean.c, startup/bspstart.c, startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM, timer/.cvsignore, timer/Makefile.am, timer/timer.c, times, wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
* 2000-05-25 Matt Cross <profesor@gweep.net>Joel Sherrill2001-05-251-0/+7
| | | | | | | * New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * custom/mrm332.cfg: New file.
* 2001-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-242-11/+5
| | | | | * custom/dmv177.cfg: Remove CONSOLE_USE_INTERRUPTS, CONSOLE_USE_POLLED, HAS_RTC.
* 2001-05-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-113-12/+5
| | | | | * custom/gensh1.cfg: Remove HZ, BSP_CPPFLAGS. * custom/gensh2.cfg: Dito.
* 2001-05-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-087-27/+15
| | | | | | | | | | * leaf.cfg: Remove CFLAGS_DEBUG_OPTIMIZE_V. * compilers/gcc-no_bsp.cfg: Remove CPP_CC_FLAGS. * compilers/gcc-portsw.cfg: Remove CPP_CC_FLAGS. * compilers/gcc-target-default.cfg: Remove *_DEBUG_OPTIMIZE_*-flags, remove unused flags, remove -ansi from CPP. * custom/eth_comm.cfg: Remove CPU_DEFINES. * custom/sim68000.cfg: Remove CPU_DEFINES.
* 2001-04-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-04-266-7/+12
| | | | | | | | * compilers/gcc-no_bsp.cfg: Remove -ansi -fasm. * compilers/gcc-default.cfg: Dito. * compilers/gcc-portsw.cfg: Remove -Hansi. * custom/posix.cfg: Remove inclusion of target.cfg. * custom/simhppa.cfg: Remove -ansi -fasm.
* 2001-04-11 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-04-112-0/+6
| | | | | * custom/eth_comm.cfg: Switch the eth_comm BSP to use the "new exception processing model."
* 2001-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-112-2/+7
| | | | | * custom/default.cfg: Switch to using exec_prefix to reflect new organization of install point from Ralf Corsepius.
* 2001-03-30 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-04-062-4/+14
| | | | | * custom/mbx860_005b.cfg: This switches the MBX8xx BSP to the use the "new exception processing model."
* 2001-03-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-142-0/+57
| | | | * custom/genmongossev.cfg: New file.
* 2001-02-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-03-011-2/+2
| | | | | | | | * configure.in: Reworked for Canadian Cross support. * Makefile.am: Reflect changes to configure.in. * config.guess, config.sub: Update from subversions.gnu.org. * README.cdn-X: New file. * tools/Makefile.am: Remove build, tools from SUBDIRS.
* 2001-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-212-0/+15
| | | | * custom/pc386dx.cfg: New bsp.
* 2001-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-126-23/+6
| | | | | | * custom/Cygwin-posix.cfg, custom/HPUX9-posix.cfg, custom/Solaris-posix.cfg, custom/FreeBSD-posix.cfg, custom/Linux-posix.cfg: Remove RTEMS_UNIX from make-target-options.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-054-24/+7
| | | | | | | * lib.cfg: include $(PROJECT_ROOT)/make/leaf.cfg * main.cfg: Set PROJECT_RELEASE=$(exec_prefix)/$(RTEMS_BSP). * host.cfg.in: Remove RM, make-script. * ChangeLog: Remove bogus 2001-01-22 entry.
* 2001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-224-12/+72
| | | | | * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and simsh7045.
* 2001-01-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-092-10/+5
| | | | | * custom/pc386.cfg (make-exe): Removed commented out lines that were displayed in build longs.
* 2001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-084-10/+27
| | | | | | * custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Remove unneeded definitions when compiled for "mips" rather than "mips64orion." Correct CPU_CFLAGS.
* 2001-01-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-052-2/+7
| | | | | * custom/gensh1.cfg: Removed rest of make-target-options and moved them to BSP configure options.
* 2001-01-03 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2001-01-032-13/+15
| | | | | * custom/mcp750.cfg (make-exe): Rewrite to avoid writing to install point or assuming BSP build tree is available.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-032-14/+4
| | | | * custom/psim.cfg: Removed unused variables.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-033-2/+6
| | | | | * custom/sim68000.cfg: Corrected CPU model for simcpu32 configuration. * custom/simcpu32.cfg: Removed MVME162 reference.
* 2000-12-14 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2000-12-142-3/+8
| | | | | * custom/mcp750.cfg: Fix problems in generation of .exe file. Still need to fix to avoid touching install point on non-install stanza.
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-062-6/+11
| | | | | * custom/vegaplus.cfg: Fix make-exe rule and eliminate mkdir and copies that should not be in it.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-012-1/+5
| | | | * custom/jmr3904.cfg: Turn optimization back up to -O2.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-302-2/+7
| | | | | * custom/jmr3904.cfg: Use -m3900 not -mips3. TX3904 is actually a mips1. gcc translates -m3900 into that.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-272-1/+5
| | | | * custom/jmr3904.cfg: Fix incorrect reference to i960.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-273-2/+64
| | | | | | | | * custom/shsim.cfg: New file. * custom/Makefile.am: Modified to reflect addition of shsim.cfg. The shsim is for the SH simulator in gdb. It should be able to be used with multiple SH CPU models. This will require adding BSP variants.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-252-25/+33
| | | | | | | | * custom/pc386.cfg: make-exe rule would write into $(PROJECT_RELEASE) area. This is not cool because it $(PROJECT_RELEASE) is generally not writeable after the BSP is installed and you do not want every application installed there by default. Reported by Eric Norum <eric.norum@usask.ca>.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-253-2/+60
| | | | | * custom/Makefile.am: Updated to add jmr3904.cfg * custom/jmr3904.cfg: New file.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-152-13/+5
| | | | | * custom/leon2.cfg: Removed defines that are now generated in a non-BSP specific manner.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-136-7/+149
| | | | | | * custom/Makefile.am: Modified to reflect addition of files. * custom/erc32.cfg: Modified to support addition of no-FP ERC32 variant. * custom/erc32nfp.cfg, custom/leon1.cfg, custom/leon2.cfg: New file.
* 2000-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-102-1/+5
| | | | * custom/Cygwin-posix.cfg: Add -U__STRICT_ANSI__ to LIBC_DEFINES.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-272-3/+7
| | | | * custom/bare.cfg: Add @ to make-exe, make make-exe more verbose.
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-253-2/+11
| | | | | | | * custom/p4600.cfg, custom/p4650.cfg: Commented out RTEMS_CPU definition since this information can be picked up from autoconf generated files. These BSPs are shared by the mips and mips64orion "ports."
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-182-1/+6
| | | | * compilers/gcc-portsw.cfg: Use gcc style flags.
* 2000-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-136-80/+8
| | | | | * custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/dmv177.cfg, custom/mcp750.cfg, custom/vegaplus.cfg: Clean up.
* 2000-09-13 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2000-09-132-0/+101
| | | | | | * vegaplus BSP submitted by Emmanuel Raguet <raguet@crf.canon.fr> and Eric Valette <valette@crf.canon.fr>. * custom/vegaplus.cfg: New file.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-128-12/+23
| | | | | | | | | | * custom/erc32.cfg: Add comment on -mno-v8, -mcypress. * custom/gen68302.cfg: Comment out LIBC_LIB[C|M]. * custom/gen68340.cfg: Comment out LIBC_LIB[C|M]. * custom/gen68360.cfg: Comment out LIBC_LIB[C|M]. * custom/idp.cfg: Comment out LIBC_LIB[C|M]. * custom/mvme162.cfg: Comment out LIBC_LIB[C|M]. * custom/ods68302.cfg: Comment out LIBC_LIB[C|M].
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-122-1/+4
| | | | * custom/gensh2.cfg: Fix comments.
* 2000-09-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-122-1/+6
| | | | | * custom/mvme167.cfg (CPP_CFLAGS): Corrected to only include compiler arguments that specify CPU model options.
* 2000-09-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-122-0/+8
| | | | | | * custom/mbx860_005b.cfg (make-target-options): Add lines to define PRINTK_MINOR SMC1_MINOR and PRINTK_IO_MODE. The settings may be incorrect but the BSP now compiles.
* 2000-09-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-062-4/+5
| | | | * custom/arm_bare_bsp.cfg: Fix comments.
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-014-28/+12
| | | | | | * custom/gensh1.cfg, custom/gensh2.cfg: Abandon gcc-2.7.2's make-exe * custom/simcpu32.cfg: Set RTEMS_BSVC_MODEL = simcpu32 * ChangeLog: File paths corrected
* 2000-08-29 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2000-08-292-2/+6
| | | | * custom/armulator.cfg: Corrected make-exe rule to pick up debug flags.
* 2000-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-08-256-4/+22
| | | | | | | | * make/custom/pck6.cfg: New file * make/custom/pc486.cfg: Use -m486 * make/custom/pc586.cfg: Use -mpentium * make/custom/pc686.cfg: Use -mmpentiumpro * make/custom/i386ex.cfg: Use -msoft-float
* 2000-08-11 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-08-252-14/+25
| | | | * custom/mbx8xx.cfg: Add support for configuration parameters in NVRAM
* 2000-08-25 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2000-08-251-3/+7
| | | | * ChangeLog: File paths corrected.
* 2000-08-04 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-08-112-25/+37
| | | | | | * mvme167.cfg: Add specification of printk port, console port and serial I/O mode. Arrange for the stripped executable to be copied up the build tree.
* 2000-08-10 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-08-102-19/+60
| | | | | | | | * mbx8xx.cfg: Support for shared printk and no termios. 2000-08-10 John Cotton <john.cotton@nrc.ca> * mbx8xx.cfg: Support added for dejagnu test harness.
* New file.Joel Sherrill2000-08-101-0/+4
