Update #3818.
- Allow the RTEMS_ROOT to be conditionally supplied. This
can be a staging area before being moved to the final
install prefix location.
- Update the default.cfg to use RTEMS_ROOT and to not rely on
the exec_prefix so it's paths can be staged.
- Fix and add the needed configure subs.
Closes #3768
This file was accidentally removed by
370c09a1f4012139aebabb4f2c9ec081855fc94d.
The origin of this code is:
+ STM32CubeF4 V1.8.0 from http://www.st.com/web/en/catalog/tools/PF259243
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
PR 1589/build
* leaf.cfg, Templates/Makefile.leaf: Remove obsolete optional manager
capability.
* host.cfg.in: Remove (Unused).
* custom/default.cfg: Update to account for movement of .cfg files.
* Makefile.am: Remove (merged into ../Makefile.am).
* compilers/gcc-target-default.cfg: Remove (Unused).
* Makefile.am: Reflect change above.
* compilers/gcc-no_bsp.cfg: Remove (Unused).
PR 1532/testing
* host.cfg.in: Add initial tests for untar capabilities.
* custom/bare.cfg: Remove (Abandoned).
* Makefile.am: Remove custom/bare.cfg.
* Makefile.am: Remove custom/no_bsp.cfg.
* custom/no_bsp.cfg:
Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* Makefile.am: Reflect custom/*.cfg having moved.
* custom/av5282.cfg, custom/csb360.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360_040.cfg, custom/gen68360.cfg,
custom/pgh360.cfg, custom/genmcf548x.cfg,
custom/m5484FireEngine.cfg, custom/idp.cfg, custom/mcf5206elite.cfg,
custom/mcf52235.cfg, custom/mcf5235.cfg, custom/mcf5329.cfg,
custom/mrm332.cfg, custom/mvme136.cfg, custom/mvme147.cfg,
custom/mvme147s.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg,
custom/mvme167.cfg, custom/ods68302.cfg, custom/sim68000.cfg,
custom/simcpu32.cfg, custom/uC5282.cfg:
* custom/csb336.cfg, custom/csb337.cfg, custom/csb637.cfg,
custom/edb7312.cfg, custom/gba.cfg, custom/arm1136jfs.cfg,
custom/arm1136js.cfg, custom/arm7tdmi.cfg, custom/arm920.cfg,
custom/armcortexa9.cfg, custom/gp32.cfg, custom/gumstix.cfg,
custom/lpc24xx.cfg, custom/lpc24xx_ea.cfg,
custom/lpc24xx_ncs_ram.cfg, custom/lpc24xx_ncs_rom_ext.cfg,
custom/lpc24xx_ncs_rom_int.cfg, custom/nds.cfg,
custom/rtl22xx.cfg, custom/rtl22xx_t.cfg,
custom/smdk2410.cfg:
* custom/csb350.cfg, custom/genmongoosev.cfg,
custom/hurricane.cfg, custom/jmr3904.cfg, custom/rbtx4925.cfg
custom/rbtx4938.cfg:
* custom/m32csim.cfg:
* custom/m32rsim.cfg:
* custom/lm32_evr.cfg:
* custom/icecube.cfg, custom/pm520_cr825.cfg, pm520_ze30.cfg:
* custom/hsc_cm01.cfg, custom/mpc8313erdb.cfg,
custom/mpc8349eamds.cfg:
* custom/bf537Stamp.cfg, custom/eZKit533.cfg:
* custom/brs5l.cfg:
* custom/h8sim.cfg, custom/h8sxsim.cfg:
* custom/c3xsim.cfg, custom/c4xsim.cfg:
* custom/pghplus.cfg:
* custom/ep1a.cfg, custom/gen5200.cfg, custom/gen83xx.cfg,
custom/haleakala.cfg, custom/mbx821_001.cfg,
custom/mbx821_002.cfg, custom/mbx821_002b.cfg,
custom/mbx860_001b.cfg, custom/mbx860_002.cfg,
custom/mbx860_005b.cfg, custom/mbx860_1b.cfg,
custom/mbx8xx.cfg, custom/mcp750.cfg, custom/mpc5566evb.cfg,
custom/mpc55xx.cfg, custom/mpc8260ads.cfg, custom/mtx603e.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg,
custom/mvme5500.cfg, custom/psim.cfg, custom/qemuppc.cfg,
custom/score603e.cfg, custom/ss555.cfg, custom/tqm8xx.cfg,
custom/tqm8xx_stk8xx.cfg, custom/virtex.cfg:
* custom/nios2_iss.cfg:
* custom/leon3.cfg, custom/leon2.cfg, custom/sis.cfg,
custom/erc32.cfg:
* custom/avrtest.cfg:
