path: root/make (follow)
* 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-161-0/+5
| | | | | * custom/bare.cfg: Remove (Abandoned). * Makefile.am: Remove custom/bare.cfg.
* Remove custom/bare.cfg.Ralf Corsepius2009-10-161-2/+0
* Remove (Abandoned).Ralf Corsepius2009-10-161-38/+0
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-1/+4
| | | | * Makefile.am: Remove custom/no_bsp.cfg.
* Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius2009-10-151-15/+0
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-151-0/+5
| | | | | * custom/no_bsp.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-116/+4
| | | | * Makefile.am: Reflect custom/*.cfg having moved.
* Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius2009-10-1525-705/+0
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-151-0/+13
| | | | | | | | | | | | | * custom/av5282.cfg, custom/csb360.cfg, custom/gen68302.cfg, custom/gen68340.cfg, custom/gen68360_040.cfg, custom/gen68360.cfg, custom/pgh360.cfg, custom/genmcf548x.cfg, custom/m5484FireEngine.cfg, custom/idp.cfg, custom/mcf5206elite.cfg, custom/mcf52235.cfg, custom/mcf5235.cfg, custom/mcf5329.cfg, custom/mrm332.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme147s.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg, custom/ods68302.cfg, custom/sim68000.cfg, custom/simcpu32.cfg, custom/uC5282.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius2009-10-1527-557/+0
| | | | | | | | | | | | | * custom/csb336.cfg, custom/csb337.cfg, custom/csb637.cfg, custom/edb7312.cfg, custom/gba.cfg, custom/arm1136jfs.cfg, custom/arm1136js.cfg, custom/arm7tdmi.cfg, custom/arm920.cfg, custom/armcortexa9.cfg, custom/gp32.cfg, custom/gumstix.cfg, custom/lpc24xx.cfg, custom/lpc24xx_ea.cfg, custom/lpc24xx_ncs_ram.cfg, custom/lpc24xx_ncs_rom_ext.cfg, custom/lpc24xx_ncs_rom_int.cfg, custom/nds.cfg, custom/rtl22xx.cfg, custom/rtl22xx_t.cfg, custom/smdk2410.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-151-0/+7
| | | | | | | * custom/csb350.cfg, custom/genmongoosev.cfg, custom/hurricane.cfg, custom/jmr3904.cfg, custom/rbtx4925.cfg custom/rbtx4938.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius2009-10-152-43/+0
| | | | | * custom/m32csim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
| | | | | * custom/m32rsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-30/+5
| | | | | * custom/lm32_evr.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius2009-10-153-47/+0
| | | | | * custom/icecube.cfg, custom/pm520_cr825.cfg, pm520_ze30.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius2009-10-153-40/+0
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-151-0/+6
| | | | | | * custom/hsc_cm01.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
| | | | | * custom/bf537Stamp.cfg, custom/eZKit533.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-14/+5
| | | | | * custom/brs5l.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-153-42/+5
| | | | | * custom/h8sim.cfg, custom/h8sxsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
| | | | | * custom/c3xsim.cfg, custom/c4xsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
| | | | | * custom/pghplus.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius2009-10-1529-679/+0
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-151-0/+15
| | | | | | | | | | | | | | | * custom/ep1a.cfg, custom/gen5200.cfg, custom/gen83xx.cfg, custom/haleakala.cfg, custom/mbx821_001.cfg, custom/mbx821_002.cfg, custom/mbx821_002b.cfg, custom/mbx860_001b.cfg, custom/mbx860_002.cfg, custom/mbx860_005b.cfg, custom/mbx860_1b.cfg, custom/mbx8xx.cfg, custom/mcp750.cfg, custom/mpc5566evb.cfg, custom/mpc55xx.cfg, custom/mpc8260ads.cfg, custom/mtx603e.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg, custom/psim.cfg, custom/qemuppc.cfg, custom/score603e.cfg, custom/ss555.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg, custom/virtex.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
| | | | | * custom/nios2_iss.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius2009-10-154-67/+0
| | | | | | * custom/leon3.cfg, custom/leon2.cfg, custom/sis.cfg, custom/erc32.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
| | | | | * custom/avrtest.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius2009-10-1515-354/+0
| | | | | | | * custom/i386ex.cfg, custom/pc486.cfg, custom/ts_386ex.cfg, custom/pc386.cfg, custom/pc586.cfg, custom/pc386dx.cfg, custom/pc686.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
| | | | | | | * custom/gensh1.cfg, custom/gensh2.cfg, custom/gensh4.cfg, custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh2e.cfg, custom/simsh4.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-0/+6
| | | | | | * custom/Cygwin-posix.cfg, custom/FreeBSD-posix.cfg, custom/Linux-posix.cfg, custom/Solaris-posix.cfg, custom/posix.cfg: Remove.
* Remove.Ralf Corsepius2009-10-145-108/+0
* add missing filesThomas Doerfler2009-10-052-0/+18
* renamed config filesThomas Doerfler2009-10-056-32/+20
* 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-10-017-0/+114
| | | | | | * Makefile.am: Add new BSP variants for ARM simulator in GDB. * custom/arm1136jfs.cfg, custom/arm1136js.cfg, custom/arm7tdmi.cfg, custom/arm920.cfg, custom/armcortexa9.cfg: New files.
* 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-09-243-0/+31
| | | | | * Makefile.am: Add qemuppc.cfg. * custom/qemuppc.cfg: New file.
* 2009-09-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-142-1/+5
| | | | * custom/gen83xx.cfg: Remove -funit-at-a-time.
* 2009-08-27 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-273-3/+6
| | | | * custom/leon2.cfg, custom/leon3.cfg: Fix typo.
* 2009-06-04 Xi Yang <hiyangxi@gmail.com>Joel Sherrill2009-06-043-0/+26
| | | | | * Makefile.am: New Gumstix BSP. * custom/gumstix.cfg: New file.
* 2009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-05-282-0/+14
| | | | * custom/csb637.cfg: New file.
* added missing filesThomas Doerfler2009-02-273-0/+46
* * README: Added NCS.Thomas Doerfler2009-02-271-15/+8
| | | | | | | | | | | | | | | * Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
* 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-02-192-0/+22
| | | | * custom/simsh2e.cfg: New file.
* 2009-02-17 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2009-02-172-2/+6
| | | | | PR 1371/bsps * custom/mvme167.cfg: mvme167 needs to convert ELF -> pure binary RALF.
* 2009-02-17 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-02-172-0/+6
| | | | * custom/uC5282.cfg: Add cvs Id.
