* custom/csb336.cfg, custom/edb7312.cfg, custom/gba.cfg:
CFLAGS_OPTIMIZE_V = -O2.
* custom/eZKit533.cfg: CFLAGS_OPTIMIZE = -O0.
* custom/gensh1.cfg, custom/ep1a.cfg, custom/erc32.cfg,
custom/erc32nfp.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg,
custom/armulator.cfg, custom/gp32.cfg: CFLAGS_OPTIMIZE_V = -O2.
* custom/Cygwin-posix.cfg, custom/FreeBSD-posix.cfg,
custom/HPUX9-posix.cfg, custom/Linux-posix.cfg,
custom/Solaris-posix.cfg, custom/armulator.cfg,
custom/av5282.cfg, custom/bare.cfg,
custom/csb336.cfg, custom/csb337.cfg,
custom/csb350.cfg, custom/csb360.cfg,
custom/dmv152.cfg, custom/eZKit533.cfg,
custom/edb7312.cfg, custom/ep1a.cfg,
custom/erc32.cfg, custom/erc32nfp.cfg,
custom/gba.cfg, custom/gen405.cfg,
custom/gen5200.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg,
custom/genmongoosev.cfg, custom/gensh1.cfg,
custom/gensh2.cfg, custom/gensh4.cfg,
custom/gp32.cfg, custom/h8sim.cfg,
custom/helas403.cfg, custom/hurricane.cfg,
custom/i386ex.cfg, custom/idp.cfg,
custom/jmr3904.cfg,custom/leon2.cfg,
custom/leon3.cfg, custom/mbx821_002b.cfg,
custom/mbx8xx.cfg, custom/mcf5206elite.cfg,
custom/mcf5235.cfg, custom/mcp750.cfg,
custom/mpc8260ads.cfg, custom/mrm332.cfg,
custom/mtx603e.cfg, custom/mvme136.cfg,
custom/mvme147.cfg, custom/mvme162.cfg,
custom/mvme162lx.cfg, custom/mvme167.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg,
custom/mvme5500.cfg, custom/ods68302.cfg,
custom/pc386.cfg, custom/psim.cfg,
custom/rbtx4925.cfg, custom/rbtx4938.cfg,
custom/score603e.cfg, custom/shsim.cfg,
custom/sim68000.cfg, custom/simcpu32.cfg,
custom/simsh4.cfg, custom/simsh7032.cfg,
custom/simsh7045.cfg, custom/ss555.cfg,
custom/ts_386ex.cfg: Cleanup.
* custom/uC5282.cfg: Remove hard-code compiler flags.
* custom/av5282.cfg, custom/csb360.cfg, custom/mcf5206elite.cfg,
custom/mcf5235.cfg: Remove ASFLAGS, CPU_ASFLAGS (Unused).
* custom/eZKit533.cfg: New file.
PR 1150/bsps
* custom/mvme5500.cfg: This is a follow-up of the PR846 due to the fact
that gcc (4.0.2) implicitely uses the vector engine for optimization;
-mcpu=7450 -Dmpc7455 -mno-altivec -mabi=altivec is better.
* Makefile.am: New port to Altera NIOS II.
* custom/nios2_iss.cfg: New file.
much more useful.
* custom/hurricane.cfg, custom/rbtx4925.cfg, custom/rbtx4938.cfg:
New (Submission by Bruce Robinson <brucer@pmccorp.com>).
* custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg:
Remove (abandoned).
* custom/leon1.cfg, custom/leon2.cfg, custom/leon3.cfg, sis.cfg:
Merger from rtems-4-6-branch.
PR 851/bsps
* custom/gen5200.cfg, custom/pm520_cr825.cfg, custom/pm520_ze30.cfg:
New (Submission by Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>).
* custom/gba.cfg, custom/pc386.cfg: Use .elf instead of .obj.
* custom/dmv152.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mcf5235.cfg, custom/mrm332.cfg, custom/mvme136.cfg,
custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg:
Use .srec for files containing SRECs.
* custom/gp32.cfg: Replace .gxb with .elf.
* custom/i386ex.cfg, custom/ts_386ex.cfg: Replace .coff with .elf.
* custom/mvme5500.cfg: Fixed PR#846; must not use -mcpu=74xx, use
-mcpu=750 instead.
* custom/orp.cfg: Remove (abandoned).
* custom/av5282.cfg: Remove obsolete vars.
* custom/gba.cfg: Remove PROFILE* (abandoned).
Remove -static (bogus).
PR 822/bsps
* custom/mbx860_001b.cfg, custom/mbx860_1b.cfg: New files.
* custom/av5282.cfg: New file.
* Makefile.am: Adding GameBoy Advance BSP.
* custom/gba.cfg: New file.
* custom/mcf5235.cfg: New file.
* custom/gp32.cfg: Add make-cxx-exe.
* custom/mbx860_005b.cfg, custom/mcp750.cfg, custom/mtx603e.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg:
Remove RTEMS_PPC_EXCEPTION_PROCESSING_MODEL (Obsolete).
* Makefile.am: Remove dmv177 and ppcn_60x.
* custom/dmv177.cfg: Removed.
* custom/ppcn_60x.cfg: Remove (Gone from libbsp).
