enabled now at configure time.
cpuopts.h.
to disabled.
problems at runtime.
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
that removes setting unused variables WORKSPACE_MB and HEAPSPACE_MB.
find tools like packhex after installation.
<elkolli@crf.canon.fr> to add support for the mbx860_005b.
significant things:
and PowerPC
same code base.
significant things:
and PowerPC
same code base.
by gdb 5.0's i960 simulator) is enough to run hello world.
linkcmds updated, simio references removed, and switch to libchip for
serial ports from simio.
Added a MEMORY_MAP file to capture information about the various
addresses on this board.
In addition, many of the beta patches are now included.
Erwin Rol <erwin@muffin.org>.
that contains:
* Removes MKLIB
handling)
that contains:
The workarounds related to the issues with
ppc/helas403 (triggers a nasty bug in automake-2.14) and mcp750.cfg
(Which is basically broken)
patch -p1 < rtems-rc-20000118-6.diff
./bootstrap
Note:
* Though this patch is small, ./bootstrap is absolutely necessary.
* Now your CVS source tree is identical to my local CVS.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
is no way to build this target.
pc686.cfg was not present.
the mvme2307 and mcp750 BSPs. In addition, it can support many
Motorola PowerPC based VME and PCI boards.
which is described below:
break something.
SUBDIRS in a Makefile.am)
* An update to gensh2.cfg.
cd <srcdir>
John Mills <jmills@tga.com>.
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
bugs.
rm -rf c/src/exec/score/cpu/i960/wrap
rm -rf c/src/exec/score/cpu/m68k/wrap
rm -rf c/src/exec/score/cpu/sh/wrap
rm -rf c/src/exec/score/cpu/sparc/wrap
rm -rf c/src/exec/score/cpu/unix/wrap
patch -p1 < rtems-rc-19991123-rc-1.diff
./bootstrap
Known bugs:
* "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does
not handle recursion to subdirectories correctly (recurses too often).
However, this issue is hardly visible and should be tolerable for the
moment.
Addtional major bugs:
* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
in the previous commits.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
<corsepiu@faw.uni-ulm.de>.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
for RTEMS.
