path: root/make (follow)
* 2001-03-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-142-0/+57
| | | | * custom/genmongossev.cfg: New file.
* 2001-02-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-03-011-2/+2
| | | | | | | | * configure.in: Reworked for Canadian Cross support. * Makefile.am: Reflect changes to configure.in. * config.guess, config.sub: Update from subversions.gnu.org. * README.cdn-X: New file. * tools/Makefile.am: Remove build, tools from SUBDIRS.
* 2001-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-212-0/+15
| | | | * custom/pc386dx.cfg: New bsp.
* 2001-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-126-23/+6
| | | | | | * custom/Cygwin-posix.cfg, custom/HPUX9-posix.cfg, custom/Solaris-posix.cfg, custom/FreeBSD-posix.cfg, custom/Linux-posix.cfg: Remove RTEMS_UNIX from make-target-options.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-054-24/+7
| | | | | | | * lib.cfg: include $(PROJECT_ROOT)/make/leaf.cfg * main.cfg: Set PROJECT_RELEASE=$(exec_prefix)/$(RTEMS_BSP). * host.cfg.in: Remove RM, make-script. * ChangeLog: Remove bogus 2001-01-22 entry.
* 2001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-224-12/+72
| | | | | * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and simsh7045.
* 2001-01-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-092-10/+5
| | | | | * custom/pc386.cfg (make-exe): Removed commented out lines that were displayed in build longs.
* 2001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-084-10/+27
| | | | | | * custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Remove unneeded definitions when compiled for "mips" rather than "mips64orion." Correct CPU_CFLAGS.
* 2001-01-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-052-2/+7
| | | | | * custom/gensh1.cfg: Removed rest of make-target-options and moved them to BSP configure options.
* 2001-01-03 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2001-01-032-13/+15
| | | | | * custom/mcp750.cfg (make-exe): Rewrite to avoid writing to install point or assuming BSP build tree is available.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-032-14/+4
| | | | * custom/psim.cfg: Removed unused variables.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-033-2/+6
| | | | | * custom/sim68000.cfg: Corrected CPU model for simcpu32 configuration. * custom/simcpu32.cfg: Removed MVME162 reference.
* 2000-12-14 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2000-12-142-3/+8
| | | | | * custom/mcp750.cfg: Fix problems in generation of .exe file. Still need to fix to avoid touching install point on non-install stanza.
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-062-6/+11
| | | | | * custom/vegaplus.cfg: Fix make-exe rule and eliminate mkdir and copies that should not be in it.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-012-1/+5
| | | | * custom/jmr3904.cfg: Turn optimization back up to -O2.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-302-2/+7
| | | | | * custom/jmr3904.cfg: Use -m3900 not -mips3. TX3904 is actually a mips1. gcc translates -m3900 into that.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-272-1/+5
| | | | * custom/jmr3904.cfg: Fix incorrect reference to i960.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-273-2/+64
| | | | | | | | * custom/shsim.cfg: New file. * custom/Makefile.am: Modified to reflect addition of shsim.cfg. The shsim is for the SH simulator in gdb. It should be able to be used with multiple SH CPU models. This will require adding BSP variants.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-252-25/+33
| | | | | | | | * custom/pc386.cfg: make-exe rule would write into $(PROJECT_RELEASE) area. This is not cool because it $(PROJECT_RELEASE) is generally not writeable after the BSP is installed and you do not want every application installed there by default. Reported by Eric Norum <eric.norum@usask.ca>.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-253-2/+60
| | | | | * custom/Makefile.am: Updated to add jmr3904.cfg * custom/jmr3904.cfg: New file.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-152-13/+5
| | | | | * custom/leon2.cfg: Removed defines that are now generated in a non-BSP specific manner.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-136-7/+149
| | | | | | * custom/Makefile.am: Modified to reflect addition of files. * custom/erc32.cfg: Modified to support addition of no-FP ERC32 variant. * custom/erc32nfp.cfg, custom/leon1.cfg, custom/leon2.cfg: New file.
* 2000-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-102-1/+5
| | | | * custom/Cygwin-posix.cfg: Add -U__STRICT_ANSI__ to LIBC_DEFINES.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-272-3/+7
| | | | * custom/bare.cfg: Add @ to make-exe, make make-exe more verbose.
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-253-2/+11
| | | | | | | * custom/p4600.cfg, custom/p4650.cfg: Commented out RTEMS_CPU definition since this information can be picked up from autoconf generated files. These BSPs are shared by the mips and mips64orion "ports."
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-182-1/+6
| | | | * compilers/gcc-portsw.cfg: Use gcc style flags.
* 2000-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-136-80/+8
| | | | | * custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/dmv177.cfg, custom/mcp750.cfg, custom/vegaplus.cfg: Clean up.
* 2000-09-13 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2000-09-132-0/+101
| | | | | | * vegaplus BSP submitted by Emmanuel Raguet <raguet@crf.canon.fr> and Eric Valette <valette@crf.canon.fr>. * custom/vegaplus.cfg: New file.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-128-12/+23
| | | | | | | | | | * custom/erc32.cfg: Add comment on -mno-v8, -mcypress. * custom/gen68302.cfg: Comment out LIBC_LIB[C|M]. * custom/gen68340.cfg: Comment out LIBC_LIB[C|M]. * custom/gen68360.cfg: Comment out LIBC_LIB[C|M]. * custom/idp.cfg: Comment out LIBC_LIB[C|M]. * custom/mvme162.cfg: Comment out LIBC_LIB[C|M]. * custom/ods68302.cfg: Comment out LIBC_LIB[C|M].
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-122-1/+4
| | | | * custom/gensh2.cfg: Fix comments.
* 2000-09-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-122-1/+6
| | | | | * custom/mvme167.cfg (CPP_CFLAGS): Corrected to only include compiler arguments that specify CPU model options.
* 2000-09-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-122-0/+8
| | | | | | * custom/mbx860_005b.cfg (make-target-options): Add lines to define PRINTK_MINOR SMC1_MINOR and PRINTK_IO_MODE. The settings may be incorrect but the BSP now compiles.
* 2000-09-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-062-4/+5
| | | | * custom/arm_bare_bsp.cfg: Fix comments.
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-014-28/+12
| | | | | | * custom/gensh1.cfg, custom/gensh2.cfg: Abandon gcc-2.7.2's make-exe * custom/simcpu32.cfg: Set RTEMS_BSVC_MODEL = simcpu32 * ChangeLog: File paths corrected
* 2000-08-29 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2000-08-292-2/+6
| | | | * custom/armulator.cfg: Corrected make-exe rule to pick up debug flags.
* 2000-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-08-256-4/+22
| | | | | | | | * make/custom/pck6.cfg: New file * make/custom/pc486.cfg: Use -m486 * make/custom/pc586.cfg: Use -mpentium * make/custom/pc686.cfg: Use -mmpentiumpro * make/custom/i386ex.cfg: Use -msoft-float
* 2000-08-11 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-08-252-14/+25
| | | | * custom/mbx8xx.cfg: Add support for configuration parameters in NVRAM
* 2000-08-25 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2000-08-251-3/+7
| | | | * ChangeLog: File paths corrected.
* 2000-08-04 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-08-112-25/+37
| | | | | | * mvme167.cfg: Add specification of printk port, console port and serial I/O mode. Arrange for the stripped executable to be copied up the build tree.
* 2000-08-10 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-08-102-19/+60
| | | | | | | | * mbx8xx.cfg: Support for shared printk and no termios. 2000-08-10 John Cotton <john.cotton@nrc.ca> * mbx8xx.cfg: Support added for dejagnu test harness.
* New file.Joel Sherrill2000-08-101-0/+4
* Executables are now in binary format for download using network.Joel Sherrill2000-08-021-3/+4
* Produce Srecords.Joel Sherrill2000-08-011-10/+6
* Added sim68000 BSP for the BSVC simulator. This BSP includes theJoel Sherrill2000-08-012-0/+78
| | | | | alias simcpu32 that supports the CPU32 simulator in BSVC. At this point, it is still under development.
* Patch rtems-rc-20000731-2-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-08-0112-20/+20
| | | | | | | | | | | | | | that does the following: Changes: Remove $(SED) and $(CP) from make/custom/*.cfg Motivation: * autoconf and automake presuppose sed and cp to be present. * make/host.cfg.in already contains SED = sed hard-coded into it for a long time. * Elimination of make-variables * Eliminate make/*.cfg files or at least reduce their complexity :)
* New bsp for simulator in gdb. Does not work yet.Joel Sherrill2000-07-311-0/+53
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-272-27/+0
| | | | Removed obsolete flags from new custom files.
* Port of RTEMS to the ARM processor family by Eric ValetteJoel Sherrill2000-07-271-0/+95
| | | | | | <valette@crf.canon.fr> and Emmanuel Raguet <raguet@crf.canon.fr> of Canon CRF - Communication Dept. This port includes a basic BSP that is sufficient to link hello world.
* Patch from Charles-Antoine Gauthier <charles.gauthier@nrc.ca> thatJoel Sherrill2000-07-261-1/+1
| | | | | removes warnings from the network.c file and has slight additions to the configuration file to support Java.
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-261-1/+2
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
