* | Added rule for .cxx and .cpp per suggestion from Geoffroy Montel | Joel Sherrill | 1998-06-09 | 1 | -0/+6 |
| | | | | <g_montel@yahoo.com>. | ||||
* | Changed spacing | Joel Sherrill | 1998-06-03 | 1 | -2/+0 |
* | Changed BSP name to posix. | Joel Sherrill | 1998-06-03 | 1 | -0/+1 |
* | Changed ppc to PowerPC in comments. | Joel Sherrill | 1998-06-03 | 2 | -6/+6 |
* | Updated to current source and removed warnings. | Joel Sherrill | 1998-05-30 | 1 | -17/+18 |
* | New file -- from rtems-LM-980406 based on a 12/97 RTEMS snapshot. | Joel Sherrill | 1998-05-30 | 1 | -0/+112 |
* | Changed invocation of bin2boot to match gcc 2.8 rule. | Joel Sherrill | 1998-05-27 | 1 | -1/+1 |
* | Added names for C++ compilers. | Joel Sherrill | 1998-05-27 | 1 | -0/+7 |
* | Now uses BSP specific configure variables and compiles for i486 and m68k. | Joel Sherrill | 1998-05-22 | 1 | -1/+8 |
* | Renamed bare BSP specific options to make the dependency obvious. | Joel Sherrill | 1998-05-22 | 1 | -3/+4 |
* | Added bare bsp from Chris Johns <cjohns@plessey.com.au>. | Joel Sherrill | 1998-05-21 | 3 | -0/+60 |
* | Per patch from Ralf Corsepius removed redundant lines. | Joel Sherrill | 1998-05-21 | 1 | -23/+0 |
* | Removed undesirable space in TARGET_ARCH assignment line. | Joel Sherrill | 1998-05-21 | 1 | -9/+4 |
| | | | | | | Cleaned up command line macro definitions. Per patch from Ralf Corsepius UNIX ports always needs C++ for rtems-ctor.cc. | ||||
* | Per patch from Ralf Corsepius UNIX ports always needs C++ for rtems-ctor.cc. | Joel Sherrill | 1998-05-21 | 1 | -4/+0 |
* | Some patches in place from Brian Stevens which help the Solaris port | Joel Sherrill | 1998-05-20 | 1 | -7/+10 |
| | | | | | build. It does not link successfully for him. It does not compile for me locally. | ||||
* | Copied gcc 2.7.2 style make-exe rule to gcc 2.8 conditional. This | Joel Sherrill | 1998-05-20 | 1 | -1/+6 |
| | | | | lets the makefile work in both cases. | ||||
* | Changed CPP rule per patch from Ralf Corsepius. | Joel Sherrill | 1998-05-20 | 1 | -1/+1 |
* | Added much stuff formerly in multiple compiler files. | Joel Sherrill | 1998-05-18 | 1 | -0/+27 |
* | Added conditional around TARGET_ARCH to prevent accidental overrides. | Joel Sherrill | 1998-05-18 | 1 | -0/+2 |
* | Switched to using shared gcc-target-default.cfg. | Joel Sherrill | 1998-05-18 | 3 | -12/+10 |
* | Added C++ rule. | Joel Sherrill | 1998-05-18 | 1 | -1/+22 |
| | | | | Added CROSS_TARGET conditionals so unix port can share this file. | ||||
* | Added RTEMS_CROSS_TARGET. | Joel Sherrill | 1998-05-18 | 1 | -0/+2 |
* | Modified objcopy to remove extra sections. | Joel Sherrill | 1998-05-04 | 1 | -3/+6 |
| | | | | Modified gcc 2.8 style link rule to provide start address correctly. | ||||
* | Changed default target architecture name | Joel Sherrill | 1998-04-30 | 1 | -1/+1 |
* | Modified objcopy invocation to ignore more sections. | Joel Sherrill | 1998-04-30 | 1 | -3/+7 |
* | Update from Pedro Romano <pmcnr@camoes.rnl.ist.utl.pt>. | Joel Sherrill | 1998-04-27 | 1 | -17/+31 |
* | Fixes from Ralf Corsepius: | Joel Sherrill | 1998-04-27 | 4 | -45/+21 |
| | | | | | | | | | | | | * Posix BSP configuration: Moved some rules from make/custom/*-posix.cfg files to make/custom/posix.cfg, Removed references to stdc++ from *posix.cfg files (rtems doesn't use/need libstdc++) NOTE: Building Posix-BSPs should now work again for native compilation with gcc, i..e. linux using primary compiler and primary libc. All Posix-BSP configurations that don't use gcc as primary compiler or don't use the primary libc don't work, e.g. solaris, linux w/ egcs as secondary compiler won't be built correctly. | ||||
* | Removed forced enable of POSIX API. Now follow configuration flag. | Joel Sherrill | 1998-04-27 | 1 | -3/+0 |
* | Fixed bad CVS Id string. | Joel Sherrill | 1998-04-27 | 1 | -2/+1 |
| | | | | Removed unnecessary definition of "ED". | ||||
* | Stack checker now enabled via initial set of user extensions. This | Joel Sherrill | 1998-04-15 | 26 | -124/+0 |
| | | | | | eliminates the need to build the entire application with the STACK_CHECKER_ON macro defined. | ||||
* | Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵ | Joel Sherrill | 1998-04-14 | 1 | -1/+2 |
| | | | | gcc-target-default.cfg | ||||
* | Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵ | Joel Sherrill | 1998-04-14 | 3 | -66/+230 |
* | Stack checker on | Joel Sherrill | 1998-04-14 | 1 | -6/+1 |
* | Updates from PPC refresh | Joel Sherrill | 1998-04-14 | 1 | -3/+33 |
* | new file | Joel Sherrill | 1998-04-14 | 1 | -0/+122 |
* | Purged references to STACK_CHECKER_REPORT_USAGE | Joel Sherrill | 1998-04-06 | 2 | -6/+1 |
* | Purged references to STACK_CHECKER_REPORT_USAGE | Joel Sherrill | 1998-04-06 | 22 | -113/+1 |
* | Reordered CFLAGS definition so CFLAGS_DEFAULT is before | Joel Sherrill | 1998-04-06 | 2 | -4/+2 |
| | | | | | CFLAGS_$(TARGET_VARIANTS). This makes sure that -Wall appears before any individual warnings are disabled during "debug" builds. | ||||
* | Changed CPU model to mcpu32. | Joel Sherrill | 1998-04-06 | 1 | -1/+1 |
* | Added test so the build procedure would stop if a directory did not exist. | Joel Sherrill | 1998-04-03 | 1 | -0/+2 |
| | | | | | This typically indicates a bug in a directory level Makefile or a configure scrip bug. | ||||
* | Fixed CUSTOM_FILES rule so it properly picked up files included from | Joel Sherrill | 1998-03-31 | 1 | -2/+11 |
| | | | | make/custom files. | ||||
* | Made the POSIX API option follow the configure line. | Joel Sherrill | 1998-03-30 | 1 | -3/+1 |
* | Made the HAS_POSIX_API follow the configure line option. | Joel Sherrill | 1998-03-30 | 1 | -5/+0 |
* | Made the C++ option follow the configure option. | Joel Sherrill | 1998-03-30 | 1 | -9/+0 |
* | Made HAS_POSIX_API have a "no" definition when it is not enabled. | Joel Sherrill | 1998-03-30 | 1 | -0/+2 |
* | Made C++ follow the configure option. | Joel Sherrill | 1998-03-30 | 1 | -4/+0 |
* | Changed RTEMS cpu to hppa1.1. | Joel Sherrill | 1998-03-24 | 1 | -2/+1 |
* | Added rule to transform hppa1.1 to hppa1_1 since hppa1.1 is not a | Joel Sherrill | 1998-03-24 | 1 | -3/+12 |
| | | | | valid cpp symbol. | ||||
* | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 1998-03-24 | 1 | -0/+1 |
| | | | | the CPU family name constants. | ||||
* | renamed ppc to powerpc | Joel Sherrill | 1998-03-23 | 1 | -1/+1 |
