path: root/make (unfollow)
2003-12-122003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-1/+5
* Makefile.am: EXTRA_DIST +=.
2003-12-112003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius3-35/+27
* custom/Makefile.am: Remove. * Makefile.am: Merge-in former custom/Makefile.am
2003-11-242003-11-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius3-14/+5
* custom/HPUX9-posix.cfg: Remove INLINE, INLINE_UPCASE. * custom/default.cfg: Remove INLINE,INLINE_UPCASE.
2003-09-262003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-92/+4
* custom/simhppa.cfg: Removed.
2003-09-092003-08-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-2/+6
PR 470/bsps * custom/mcp750.cfg, custom/mtx603e.cfg, custem/mvme2307.cfg (make-exe): Rearrange arguments in calls to OBJCOPY to $(OBJCOPY) options infile outfile. (Reported for mcp750.cfg by Andrew Harris <Andrew.Harris@jhuapl.edu>).
2003-08-242003-08-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius4-3/+10
2003-08-202003-08-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-19/+6
* custom/mvme167.cfg: Remove PRINTK_MINOR, CONSOLE_MINOR (move to the BSP's configure-script). Remove BSP_CPPFLAGS (Obsolete).
2003-06-13Changed format so script will see PR number.Joel Sherrill1-1/+1
2003-06-062003-06-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius6-48/+35
PR 321: * leaf.cfg: Remove support for profile-variant. * main.cfg: Ditto. * compilers/gcc-no_bsp.cfg: Ditto. * compilers/gcc-portsw.cfg: Ditto. * compilers/gcc-target-default.cfg: Ditto.
2003-05-272003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-4/+4
* custom/mvme2307.cfg: Remove CFLAGS_PROFILE_V.
2003-03-252003-03-25 Thomas Doerfler <Thomas.Doerfler@imd-systems.de>Joel Sherrill3-0/+32
PR 368/filesystems * custom/mbx821_002.cfg, custom/mbx821_002b.cfg: New files included with this PR for alias BSPs.
2003-03-182003-03-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2-1/+7
PR 356/bsps * custom/mvme2307.cfg: This patch makes RTEMS/PowerPC eabi compliant. Enable EABI by adding -meabi -msdata=eabi CFLAGS.
2003-03-10Merger from rtems-4-6-branchRalf Corsepius6-5/+16
2003-02-142003-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-25/+5
AMD a29k obsolete. * custom/portsw.cfg: Removed.
2003-01-202003-01-20 Duane Gustavus <duane@unt.edu>Joel Sherrill2-1/+7
* custom/m2m332.cfg: Fix path to linkcmds_ROM.
2003-01-152003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius6-28/+13
* custom/Cygwin-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB. * custom/FreeBSD-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB. * custom/HPUX9-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB. * custom/Linux-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB. Move -D_BSD_SOURCE to CPU_CFLAGS. * custom/Solaris-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB. Move -Dsolaris2 to CPU_CFLAGS. Remove -D__EXTENSIONS__.
2002-12-062002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-2/+4
* custom/posix.cfg: Remove comment referring to host.cfg.
2002-11-292002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-1/+5
* custom/default.cfg: Pickup target.cfg from BSP directory.
2002-11-182002-11-17 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2-0/+51
* custom/mtx603e.cfg: New file.
2002-11-182002-11-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-17/+15
* leaf.cfg, main.cfg, compilers/gcc-target-default.cfg: Make build variants work for user applications post install.
2002-11-152002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius6-6/+8
* custom/Cygwin-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX. * custom/Linux-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX. * custom/Solaris-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX. * custom/FreeBSD-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX. * custom/HPUX9-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
2002-11-132002-11-13 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2-0/+44
* custom/edb7312.cfg: New file.
2002-11-122002-11-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius4-43/+50
* custom/default.cfg: Remove RTEMS_BSP_SPECS. Remove reference to obsolete Makefile. * leaf.cfg: Various changes to LIBVARIANT processing. * main.cfg: Ditto.
2002-11-122002-11-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius6-584/+15
* Makefile.am: Add compilers/*. * compilers/Makefile.am: Remove. * lib.cfg: Remove. * directory.cfg: Remove. * README: Remove.
2002-11-072002-11-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius3-12/+13
* Makefile.am: Add Templates/*. * Templates/Makefile.am: Remove.
2002-10-292002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-1/+4
* custom/Cygwin-posix.cfg: Remove obsolete comment on RTEMS_LIBC_DIR.
2002-10-262002-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius4-3/+6
* custom/FreeBSD-posix.cfg: Remove obsolete comment on RTEMS_LIBC_DIR. * custom/HPUX9-posix.cfg: Ditto. * custom/Linux-posix.cfg: Ditto.
2002-10-022002-10-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-2/+6
* custom/armulator.cfg: Remove reference to PowerPC arguments.
2002-09-132002-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-78/+17
* Part of addressing PR281. * main.cfg: Added recognition of VARIANT=DEBUG on command line. * compilers/gcc-target-default.cfg: Removed remaining support for RTEMS_USE_GCC272 and RTEMS_LIBC_DIR as well as added -qrtems_debug as one of the LDFLAGS when the debug variant is specified.
2002-08-122002-08-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-1/+5
* custom/posix.cfg: Don't include host.cfg.
2002-08-092002-08-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+6
* custom/gen405.cfg: Corrected make-cxx-exe rule to use LINK.cc.
2002-08-072002-08-07 Ivan Guzvinec <ivang@opencores.org>Joel Sherrill2-1/+5
* orp.cfg: Bender BSP renamed to OpenRisc Reference Platform or ORP.
2002-08-072002-08-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-3/+5
* custom/vegaplus.cfg: Fix bogus and corrupted make-exe.
2002-08-062002-08-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill5-4/+9
* custom/efi332.cfg, custom/gen68340.cfg, custom/gen68360.cfg, custom/mrm332.cfg: Use more proper CPU models so libcpu knows more.
2002-08-062002-08-06 Chris Ziomkowski <chris@asics.ws>Joel Sherrill2-0/+27
* custom/or32sim.cfg: New file added as part of merge from OpenCores repository.
2002-08-052002-08-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-12/+9
* Per PR260 eliminate use of make-target-options. This impacted RTEMS allowing a distinction between the CPU32 and CPU32+ in the SuperCore and required that the m68k optimized memcpy be moved to libcpu. * custom/gen68360.cfg: Remove make-target-options.
2002-08-022002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill7-39/+15
* eth_comm.cfg, mbx821_001.cfg, mbx860_002.cfg, mbx860_005b.cfg, mbx8xx.cfg, mpc8260ads.cfg: Per PR260 removed make-target-options.
2002-08-012002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-5/+4
* custom/mvme136.cfg: Per PR260 removed make-target-options.
2002-07-312002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+7
* custom/vegaplus.cfg: Generate the Mapfile into $(ARCH) so it will disappear when make clean is performed.
2002-07-242002-07-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-3/+17
* custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg: Updated to use gcc 3.1 arguments.
2002-07-222002-07-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-4/+10
* Templates/Makefile.leaf: Clarify the MANAGERS example.
2002-07-012002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+5
* custom/p4650.cfg: Update arguments to gcc3.
2002-06-142002-06-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-5/+13
* custom/jmr3904.cfg, custom/p4650.cfg, custom/p4600.cfg: Switch to gcc 3.1 arguments.
2002-05-142002-05-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill8-18/+14
* custom/dmv177.cfg: Use -mcpu=603e. * custom/ppcn_60x.cfg: Use -mcpu=603e. * custom/psim.cfg: Use -mcpu=603e. * custom/score603e.cfg: Use -mcpu=603e. * custom/ts_386ex.cfg: Remove obsolete comments. * custom/rxgen960.cfg: Remove obsolete comments. * custom/cvme961.cfg: Remove obsolete comments.
2002-05-092001-05-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-0/+11
* custom/jmr3904.cfg, custom/p4650.cfg: Add comments for gcc 3.1 compatable arguments.
2002-04-182002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill12-117/+42
* custom/dmv177.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/eth_comm.cfg: Remove make-target-options. Add -Dmpc$(CPU_TYPE) -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to CPU_CFLAGS. * custom/gen405.cfg: Add -D_OLD_EXCEPTIONS -Dppc405 to CPU_CFLAGS. * custom/helas403.cfg: Add -D_OLD_EXCEPTIONS -Dppc403 to CPU_CFLAGS. * custom/mbx8xx.cfg: Remove make-target-options. Add -Dmpc$(CPU_TYPE) -D$(RTEMS_MBX_MODEL) to CPU_CFLAGS. Remove obsolete comments. * custom/mcp750.cfg: Add -Dmpc750 to CPU_CFLAGS. Remove obsolete comments. * custom/mpc8260ads.cfg: Remove make-target-options. Add -Dmpc8260 -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to CPU_CFLAGS. * custom/mvme2307.cfg: Add -Dmpc604 to CPU_CFLAGS. Remove obsolete comments. * custom/ppcn_60x.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/psim.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/score603e.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments.
2002-04-042002-04-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+5
* custom/gen405.cfg: Remove -D__powerpc__.
2002-04-032002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill4-35/+7
* custom/erc32nfp.cfg: Remove CPU_U32_FIX. * custom/erc32.cfg: Ditto. * custom/leon2.cfg: Ditto.
2002-03-292002-03-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill4-20/+6
* custom/erc32.cfg: Remove NO_TABLE_MOVE. Remove FPU_REVB. * custom/erc32nfp.cfg: Remove NO_TABLE_MOVE. Remove FPU_REVB. * custom/leon2.cfg: Remove NO_TABLE_MOVE.
2002-03-282002-03-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill36-465/+41
* custom/cvme961.cfg: Remove GCC272 support. * custom/dmv152.cfg: Remove GCC272 support. * custom/efi332.cfg: Remove GCC272 support. * custom/efi68k.cfg: Remove GCC272 support. * custom/eth_comm.cfg: Remove GCC272 support. * custom/gen405.cfg: Remove GCC272 support. * custom/gen68302.cfg: Remove GCC272 support. * custom/gen68340.cfg: Remove GCC272 support. * custom/gen68360.cfg: Remove GCC272 support. * custom/genmongoosev.cfg: Remove GCC272 support. * custom/helas403.cfg: Remove GCC272 support. * custom/i386ex.cfg: Remove GCC272 support. * custom/i960sim.cfg: Remove GCC272 support. * custom/idp.cfg: Remove GCC272 support. * custom/leon2.cfg: Remove GCC272 support. * custom/mbx8xx.cfg: Remove GCC272 support. * custom/mcf5206elite.cfg: Remove GCC272 support. * custom/mpc8260ads.cfg: Remove GCC272 support. * custom/mrm332.cfg: Remove GCC272 support. * custom/mvme136.cfg: Remove GCC272 support. * custom/mvme147.cfg: Remove GCC272 support. * custom/mvme167.cfg: Remove GCC272 support. * custom/ods68302.cfg: Remove GCC272 support. * custom/p4000.cfg: Remove GCC272 support. * custom/p4600.cfg: Remove GCC272 support. * custom/p4650.cfg: Remove GCC272 support. * custom/pc386.cfg: Remove GCC272 support. * custom/portsw.cfg: Remove GCC272 support. * custom/psim.cfg: Remove GCC272 support. * custom/rxgen960.cfg: Remove GCC272 support. * custom/score603e.cfg: Remove GCC272 support. * custom/sim68000.cfg: Remove GCC272 support. * custom/simhppa.cfg: Remove GCC272 support. * custom/simsh4.cfg: Remove GCC272 support. * custom/ts_386ex.cfg: Remove GCC272 support.
