* custom/nds.cfg: Email from author says to drop this flag.
* leaf.cfg: Do not override bsp-post-link.
* Makefile.am: Add smdk2410.
* custom/gp32.cfg: Add smdk2410. Update gp32 to use shared code.
* custom/smdk2410.cfg: New file.
* Makefile.am: Add nds.
* custom/nds.cfg: New file.
* leaf.cfg, custom/pc386.cfg, custom/pc386dx.cfg: It appears that the
default processor model optimization has changed in gcc 4.3.0.
* custom/av5282.cfg, custom/bare.cfg, custom/default.cfg,
custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5235.cfg, custom/mcp750.cfg,
custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg,
custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg,
custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg,
custom/mvme3100.cfg, custom/mvme5500.cfg, custom/nios2_iss.cfg,
custom/pc386.cfg, custom/posix.cfg, custom/score603e.cfg,
custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg,
custom/ts_386ex.cfg, custom/uC5282.cfg, custom/virtex.cfg: Switch to
explicit .exe instead of EXEEXT to get it to work.
* custom/mvme3100.cfg: Fixed typo, 'endef' not 'endif'.
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/gen405.cfg, custom/helas403.cfg: Remove (Abandonded).
* custom/mvme3100.cfg: Removed CFLAGS_PROFILE_V;
added '-g' to CFLAGS_DEBUG_V.
* custom/pc386.cfg: Use file with symbols.
* custom/ss555.cfg: Add CVS Id.
* custom/mvme3100.cfg: Add make-cxx-exe rule.
* custom/mcf5235.cfg, custom/mrm332.cfg, custom/pc386.cfg: Split
the make-exe and make-cxx-exe into bsp-link-c, bsp-link-cxx and
bsp-post-link make macros. This allow external autotools support.
* custom/mvme3100.cfg: Added; new BSP.
* custom/mvme5500.cfg: Fix typo.
* custom/mvme5500.cfg: Add compiler arguments sine without them, the
BSP has issues.
* custom/rtl22xx_t.cfg: New file, rtl22xx_t is a new bsp compiled
with THUMB enabled
* custom/icecube.cfg: Rename EP5200 to IceCube since that is the
nickname for the Freescale evaluation board it is based upon. BSP was
tested on a Freescale MPC5200LITE.
* custom/mcf5235.cfg: Remove bogus -m5200 from linker calls.
* custom/av5282.cfg: Remove bogus -qnolinkcmds, -m5200 from linker
calls.
* custom/gen83xx.cfg: Use -O2.
* custom/Linux-posix.cfg: Use -O2.
* custom/rbtx4938.cfg: Add missing -O2.
* custom/rtl22xx.cfg: Adjust indentation.
* custom/virtex.cfg: Use -O2.
* custom/Linux-posix.cfg: Make Linux link with just a C main -- avoid
using C++ ctor trick. An RTEMS C++ application running on this BSP
may have initialization order issues to address.
* custom/Linux-posix.cfg: Linux BSP must be linked with C++ compiler.
* custom/gen83xx.cfg: Add make-cxx-exe rule.
many different versions of new exception handling code to shared sources.
* custom/Linux-posix.cfg: Merge patch from Till Straumann which would
work except gcc core dumps with an ICE when may_alias is used in this
code. I filed a GCC PR and reduced optimization to -O0 and it does
run again.
* Templates/Makefile.leaf: At suggestion of Robert Grimes add commented
out make-cxx-exe usage example.
* custom/gen5200.cfg: Remove junk comment.
* custom/ep5200.cfg: New file.
* custom/armulator.cfg: Removed.
* custom/mvme5500.cfg: Use -O2 again.
* Makefile.am: DMV152 obsoleted.
* custom/dmv152.cfg: Removed.
* Makefile.am: Per Jiri Gaisler remove unused erc32nfp and leon1 BSP
variants.
* custom/erc32nfp.cfg, custom/leon1.cfg: Removed.
* custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/pc386.cfg,
custom/sim68000.cfg, custom/ts_386ex.cfg: Clean up to use .nxe
extension instead of BSP unique ones.
* compilers/gcc-no_bsp.cfg: There are no longer any required managers.
Plus some cleanup
