path: root/make (follow)
* B.Robinson MIPS patchGreg Menke2006-06-083-3/+8
* Remove non-longer-appropriate comment.Eric Norum2006-05-151-1/+0
* Keep the frame pointer since its presence makes various diagnostic toolsEric Norum2006-04-102-1/+5
| | | | much more useful.
* 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-03-164-0/+109
| | | | | * custom/hurricane.cfg, custom/rbtx4925.cfg, custom/rbtx4938.cfg: New (Submission by Bruce Robinson <brucer@pmccorp.com>).
* Remove (abandoned).Ralf Corsepius2006-03-163-126/+0
* 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-03-161-0/+5
| | | | | * custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Remove (abandoned).
* 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-091-0/+5
| | | | | * custom/leon1.cfg, custom/leon2.cfg, custom/leon3.cfg, sis.cfg: Merger from rtems-4-6-branch.
* Merger from rtems-4-6-branch.Ralf Corsepius2006-01-094-9/+52
* 2006-01-01 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-011-0/+6
| | | | | | PR 851/bsps * custom/gen5200.cfg, custom/pm520_cr825.cfg, custom/pm520_ze30.cfg: New (Submission by Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>).
* New (Submission by Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>).Ralf Corsepius2006-01-013-0/+70
* 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-223-20/+24
| | | | * custom/gba.cfg, custom/pc386.cfg: Use .elf instead of .obj.
* 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-221-0/+7
| | | | | | | * custom/dmv152.cfg, custom/i386ex.cfg, custom/idp.cfg, custom/mcf5235.cfg, custom/mrm332.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg: Use .srec for files containing SRECs.
* Use .srec for files containing SRECs.Ralf Corsepius2005-11-229-20/+20
* 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-221-0/+5
| | | | | * custom/gp32.cfg: Replace .gxb with .elf. * custom/i386ex.cfg, custom/ts_386ex.cfg: Replace .coff with .elf.
* Replace .coff with .elf.Ralf Corsepius2005-11-222-6/+6
* Replace .gxb with .elf.Ralf Corsepius2005-11-221-2/+2
* 2005-11-03 Till Straumann <strauman@slac.stanford.edu>Till Straumann2005-11-042-1/+6
| | | | | * custom/mvme5500.cfg: Fixed PR#846; must not use -mcpu=74xx, use -mcpu=750 instead.
* 2005-09-18 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-09-181-0/+2
| | | | | * custom/orp.cfg: Remove (abandoned). * custom/av5282.cfg: Remove obsolete vars.
* Remove obsolete vars.Ralf Corsepius2005-09-181-34/+0
* Remove (abandoned).Ralf Corsepius2005-09-181-22/+0
* 2005-09-18 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-09-182-6/+7
| | | | | * custom/gba.cfg: Remove PROFILE* (abandoned). Remove -static (bogus).
* 2005-09-12 Thomas Doerfler <Thomas.Doerfler@imd-systems.de>Joel Sherrill2005-09-123-0/+31
| | | | | PR 822/bsps * custom/mbx860_001b.cfg, custom/mbx860_1b.cfg: New files.
* 2005-08-17 Mike Bertosh <mbertosh@motioncontrol.org>Joel Sherrill2005-08-172-0/+90
| | | | * custom/av5282.cfg: New file.
* 2005-06-17 Markku Puro <markku.puro@kopteri.net>Joel Sherrill2005-06-173-1/+66
| | | | | * Makefile.am: Adding GameBoy Advance BSP. * custom/gba.cfg: New file.
* 2005-06-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-06-172-0/+55
| | | | * custom/mcf5235.cfg: New file.
* 2005-06-01 Philippe Simons <loki_666@fastmail.fm>Joel Sherrill2005-06-022-8/+15
| | | | * custom/gp32.cfg: Add make-cxx-exe.
* 2005-05-27 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-05-271-1/+7
| | | | | | * custom/mbx860_005b.cfg, custom/mcp750.cfg, custom/mtx603e.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg: Remove RTEMS_PPC_EXCEPTION_PROCESSING_MODEL (Obsolete).
* Remove RTEMS_PPC_EXCEPTION_PROCESSING_MODEL (Obsolete).Ralf Corsepius2005-05-276-7/+0
* 2005-05-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-05-023-42/+7
| | | | | * Makefile.am: Remove dmv177 and ppcn_60x. * custom/dmv177.cfg: Removed.
* 2005-05-30 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-04-302-36/+4
| | | | * custom/ppcn_60x.cfg: Remove (Gone from libbsp).
* 2005-04-28 Jennifer Averett <jennifer.averett@oarcorp.com>Jennifer Averett2005-04-283-1/+42
| | | | | * Makefile.am: Initial release of ep1a bsp * custom/ep1a.cfg: New file.
* 2005-04-28 Jennifer Averett <jennifer.averett@oarcorp.com>Jennifer Averett2005-04-282-2/+7
| | | | | * custom/score603e.cfg: Update score603e to new exception model NOTE: These modifications have not been tested on hardware.
* 2005-03-11 Jay Monkman <jtm@lopingdog.com>Jay Monkman2005-03-112-50/+4
| | | | * custom/vegaplus.cfg: Removed.
* 2005-03-11 Philippe Simons <loki_666@fastmail.fm>Jay Monkman2005-03-112-0/+43
| | | | * custom/gp32.cfg: New file.
* 2005-03-03 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-03-034-21/+9
| | | | | | * custom/mpc8260ads.cfg : Remove PPC_ASM, PPC_ABI. * custom/mvme5500.cfg: Remove CFLAGS_PROFILE_V. Remove -Wa,-m7450.
* 2005-02-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-02-253-51/+6
| | | | | * custom/jmr3904.cfg: arm_bare_bsp obsoleted. * custom/arm_bare_bsp.cfg: Removed.
* 2005-02-24 Jay MonkmanJay Monkman2005-02-251-9/+2
| | | | * custom/csb337.cfg: Cleanup.
* 2005-02-24 Jay MonkmanJay Monkman2005-02-252-0/+46
| | | | * custom/csb350.cfg: New BSP.
* Put -m5200 back in link-edit commands until proper versions of gcc (which takeEric Norum2005-02-082-2/+8
| | | | -m528x as an order to load the -m5200 multilib variants) are widely available.
* 2005-02-05 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-052-57/+13
| | | | * custom/uC5282.cfg: Cleanup.
* New BSP.Eric Norum2005-01-283-0/+91
* 2005-01-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-01-2012-12/+32
| | | | | | | | * custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/csb336.cfg, custom/csb337.cfg, custom/edb7312.cfg, custom/jmr3904.cfg, custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg, custom/pck6.cfg, custom/vegaplus.cfg: Correct use of arguments for gcc 4.x. Hopefully they are still OK for gcc 3.3.5.
* 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-013-285/+6
| | | | | * compilers/gcc-portsw.cfg: Remove. * Makefile.am: Reflect change above.
* Cosmetics.Ralf Corsepius2004-12-301-8/+8
* 2004-11-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-11-233-51/+6
| | | | | * Makefile.am: Remove eth_comm. * custom/eth_comm.cfg: Removed.
* 2004-11-22 Jennifer Averett <jennifer@OARcorp.com>Jennifer Averett2004-11-222-2/+7
| | | | | PR 581/bsps * custom/psim.cfg: Convert PSIM to new exception model.
* 2004-11-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-11-172-0/+17
| | | | * custom/mvme2100.cfg: Add make-cxx-exe rule.
* 2004-11-10 Richard Campbell <richard.campbell@oarcorp.com>Joel Sherrill2004-11-103-2/+54
| | | | | * Makefile.am: Add MVME2100 BSP. * custom/mvme2100.cfg: New file.
* 2004-11-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-11-053-4/+10
| | | | | | * custom/csb336.cfg, custom/csb337.cfg: RTEMS_CPU must match an architecture name for RTEMS. Since this was used as the -mcpu argument to GCC, that also had to be changed.
* Add -Wa,-m7450 to CPU_CFLAGS until gcc/gas get their acts together.Eric Norum2004-10-272-1/+5
