path: root/make (unfollow)
2015-11-05Resurrect make/Templates/Makefile.libSebastian Huber1-0/+58
This file was accidentally removed by 370c09a1f4012139aebabb4f2c9ec081855fc94d.
2015-11-03Add STM32F4 HAL FilesIsaac Gutekunst1-58/+0
The origin of this code is: + STM32CubeF4 V1.8.0 from http://www.st.com/web/en/catalog/tools/PF259243
2013-08-09Use $(EXEEXT) [defaults to "exe"] to generate binariesNick Withers1-8/+5
2013-03-08RTEMS: Delete ChangeLog files.Gedare Bloom1-1920/+0
This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
2013-02-13make: Remove -qrtems_debug flag usageSebastian Huber1-3/+0
2012-05-11Remove CVS Id Strings (manual edits after script)Joel Sherrill3-7/+1
These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill3-9/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-02-01Remove all .cvsignore files.Joel Sherrill2-4/+0
2011-12-082011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill3-38/+6
PR 1589/build * leaf.cfg, Templates/Makefile.leaf: Remove obsolete optional manager capability.
2011-06-172011-06-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-59/+4
* host.cfg.in: Remove (Unused).
2011-04-012011-04-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-2/+6
* custom/default.cfg: Update to account for movement of .cfg files.
2011-03-042011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-20/+4
* Makefile.am: Remove (merged into ../Makefile.am).
2011-03-042011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius3-196/+5
* compilers/gcc-target-default.cfg: Remove (Unused). * Makefile.am: Reflect change above.
2011-03-042011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius3-238/+6
* compilers/gcc-no_bsp.cfg: Remove (Unused). * Makefile.am: Reflect change above.
2010-07-272010-07-27 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-0/+9
PR 1532/testing * host.cfg.in: Add initial tests for untar capabilities.
2009-10-162009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+5
* custom/bare.cfg: Remove (Abandoned). * Makefile.am: Remove custom/bare.cfg.
2009-10-16Remove custom/bare.cfg.Ralf Corsepius1-2/+0
2009-10-16Remove (Abandoned).Ralf Corsepius1-38/+0
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-1/+4
* Makefile.am: Remove custom/no_bsp.cfg.
2009-10-15Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius1-15/+0
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+5
* custom/no_bsp.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-116/+4
* Makefile.am: Reflect custom/*.cfg having moved.
2009-10-15Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius25-705/+0
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+13
* custom/av5282.cfg, custom/csb360.cfg, custom/gen68302.cfg, custom/gen68340.cfg, custom/gen68360_040.cfg, custom/gen68360.cfg, custom/pgh360.cfg, custom/genmcf548x.cfg, custom/m5484FireEngine.cfg, custom/idp.cfg, custom/mcf5206elite.cfg, custom/mcf52235.cfg, custom/mcf5235.cfg, custom/mcf5329.cfg, custom/mrm332.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme147s.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg, custom/ods68302.cfg, custom/sim68000.cfg, custom/simcpu32.cfg, custom/uC5282.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-15Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius27-557/+0
* custom/csb336.cfg, custom/csb337.cfg, custom/csb637.cfg, custom/edb7312.cfg, custom/gba.cfg, custom/arm1136jfs.cfg, custom/arm1136js.cfg, custom/arm7tdmi.cfg, custom/arm920.cfg, custom/armcortexa9.cfg, custom/gp32.cfg, custom/gumstix.cfg, custom/lpc24xx.cfg, custom/lpc24xx_ea.cfg, custom/lpc24xx_ncs_ram.cfg, custom/lpc24xx_ncs_rom_ext.cfg, custom/lpc24xx_ncs_rom_int.cfg, custom/nds.cfg, custom/rtl22xx.cfg, custom/rtl22xx_t.cfg, custom/smdk2410.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+7
* custom/csb350.cfg, custom/genmongoosev.cfg, custom/hurricane.cfg, custom/jmr3904.cfg, custom/rbtx4925.cfg custom/rbtx4938.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-15Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius2-43/+0
* custom/m32csim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/m32rsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-30/+5
* custom/lm32_evr.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-15Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius3-47/+0
* custom/icecube.cfg, custom/pm520_cr825.cfg, pm520_ze30.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-15Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius3-40/+0
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+6
* custom/hsc_cm01.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/bf537Stamp.cfg, custom/eZKit533.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-14/+5
* custom/brs5l.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius3-42/+5
* custom/h8sim.cfg, custom/h8sxsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/c3xsim.cfg, custom/c4xsim.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/pghplus.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-15Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius29-679/+0
2009-10-152009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+15
* custom/ep1a.cfg, custom/gen5200.cfg, custom/gen83xx.cfg, custom/haleakala.cfg, custom/mbx821_001.cfg, custom/mbx821_002.cfg, custom/mbx821_002b.cfg, custom/mbx860_001b.cfg, custom/mbx860_002.cfg, custom/mbx860_005b.cfg, custom/mbx860_1b.cfg, custom/mbx8xx.cfg, custom/mcp750.cfg, custom/mpc5566evb.cfg, custom/mpc55xx.cfg, custom/mpc8260ads.cfg, custom/mtx603e.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg, custom/psim.cfg, custom/qemuppc.cfg, custom/score603e.cfg, custom/ss555.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg, custom/virtex.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/nios2_iss.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-15Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius4-67/+0
* custom/leon3.cfg, custom/leon2.cfg, custom/sis.cfg, custom/erc32.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/avrtest.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
2009-10-15Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).Ralf Corsepius15-354/+0
* custom/i386ex.cfg, custom/pc486.cfg, custom/ts_386ex.cfg, custom/pc386.cfg, custom/pc586.cfg, custom/pc386dx.cfg, custom/pc686.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
* custom/gensh1.cfg, custom/gensh2.cfg, custom/gensh4.cfg, custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh2e.cfg, custom/simsh4.cfg: Remove (Moved to c/src/lib/libbsp/<cpu>/<bsp>).
