* custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh4.cfg: Make all use
RTEMS_BSP_FAMILY.
* custom/simsh1.cfg, custom/simsh2.cfg: Remove Author notice.
* Makefile.am, custom/simsh4.cfg: Recognize the the GDB SuperH
simulator is just an architectural simulator and does not include
devices. Rename existing simulator BSP configurations to simsh1 and
simsh2 and add simsh4.
* custom/simsh1.cfg, custom/simsh2.cfg: New files.
* custom/shsim.cfg, custom/simsh7032.cfg, custom/simsh7045.cfg: Removed.
* custom/bf537skyeye.cfg: Removed.
* custom/bf537Stamp.cfg, custom/erc32.cfg: Add skyeye alias for
bf537stamp.
* custom/bf537skyeye.cfg: New file.
* custom/lpc2478.cfg: Comment out use of U-Boot specific mkimage since
we do not reliably know it is installed.
* custom/ep1a.cfg, custom/mtx603e.cfg, custom/mvme2100.cfg,
custom/psim.cfg, custom/score603e.cfg: Eliminate vestiges of mpc603e
define.
* compilers/gcc-no_bsp.cfg, compilers/gcc-target-default.cfg,
custom/bare.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg,
custom/default.cfg, custom/haleakala.cfg, custom/mbx8xx.cfg,
custom/mvme2307.cfg, custom/mvme3100.cfg, custom/mvme5500.cfg,
custom/posix.cfg, custom/ss555.cfg, custom/virtex.cfg: Eliminate
START_BASE and START_FILE.
PR 1314/bsps
* custom/mvme3100.cfg: Remove old stuff.
* compilers/gcc-no_bsp.cfg: Eliminate some obsolete junk.
* leaf.cfg: LINK.c and LINK.cc include LDFLAGS so do not include it in
make-exe and make-cxx-exe definitions. This was resulting in the
linker script being processed twice and breaking some BSPs.
* leaf.cfg, compilers/gcc-target-default.cfg, custom/bf537Stamp.cfg,
custom/gen5200.cfg, custom/gen83xx.cfg, custom/genmcf548x.cfg,
custom/mbx8xx.cfg, custom/mpc55xx.cfg, custom/nds.cfg,
custom/pc386.cfg, custom/tqm8xx.cfg: Remove use of AM_LDFLAGS. Ensure
LDFLAGS works all the time. Clean up BSPs which defined their own
make-exe rules inappropriately.
* custom/bf537Stamp.cfg: New file.
updated haleakala BSP
added MPC55xx BSP
adapted PPC exception code
* custom/mcf5329.cfg: New file.
* custom/mcf52235.cfg: Change to mcf5223x.
* custom/av5282.cfg, custom/csb360.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/mcf5206elite.cfg,
custom/mcf5235.cfg, custom/mrm332.cfg, custom/mvme136.cfg,
custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg,
custom/mvme167.cfg, custom/ods68302.cfg, custom/sim68000.cfg,
custom/simcpu32.cfg, custom/uC5282.cfg: Change CCFLAGS to use the
-mcpu= option for Coldfires now supported in GCC 4.3.0.
2008-06-10 Matthew Riek <matthew.riek@ibiscomputer.com.au>
* custom/mcf52235.cfg: New.
* custom/nds.cfg: Email from author says to drop this flag.
* leaf.cfg: Do not override bsp-post-link.
* Makefile.am: Add smdk2410.
* custom/gp32.cfg: Add smdk2410. Update gp32 to use shared code.
* custom/smdk2410.cfg: New file.
* Makefile.am: Add nds.
* custom/nds.cfg: New file.
* leaf.cfg, custom/pc386.cfg, custom/pc386dx.cfg: It appears that the
default processor model optimization has changed in gcc 4.3.0.
* custom/av5282.cfg, custom/bare.cfg, custom/default.cfg,
custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5235.cfg, custom/mcp750.cfg,
custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg,
custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg,
custom/mvme3100.cfg, custom/mvme5500.cfg, custom/nios2_iss.cfg,
custom/pc386.cfg, custom/posix.cfg, custom/score603e.cfg,
custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg,
custom/ts_386ex.cfg, custom/uC5282.cfg, custom/virtex.cfg: Switch to
explicit .exe instead of EXEEXT to get it to work.
* custom/mvme3100.cfg: Fixed typo, 'endef' not 'endif'.
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/gen405.cfg, custom/helas403.cfg: Remove (Abandonded).
* custom/mvme3100.cfg: Removed CFLAGS_PROFILE_V;
added '-g' to CFLAGS_DEBUG_V.
* custom/pc386.cfg: Use file with symbols.
* custom/ss555.cfg: Add CVS Id.
* custom/mvme3100.cfg: Add make-cxx-exe rule.
* custom/mcf5235.cfg, custom/mrm332.cfg, custom/pc386.cfg: Split
the make-exe and make-cxx-exe into bsp-link-c, bsp-link-cxx and
bsp-post-link make macros. This allow external autotools support.
* custom/mvme3100.cfg: Added; new BSP.
* custom/mvme5500.cfg: Fix typo.
* custom/mvme5500.cfg: Add compiler arguments sine without them, the
BSP has issues.
* custom/rtl22xx_t.cfg: New file, rtl22xx_t is a new bsp compiled
with THUMB enabled
