2006-08-11 | added missing config file brs5l.cfg | Thomas Doerfler | 1 | -0/+15 | |
2006-08-09 | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 3 | -0/+53 | |
* Makefile.am: New port to Altera NIOS II. * custom/nios2_iss.cfg: New file. | |||||
2006-07-14 | added ChangeLog entries for PR1117/1118/1119/1120 | Thomas Doerfler | 1 | -0/+4 | |
2006-07-09 | applied patches for PR1117/1118/1119/1120 | Thomas Doerfler | 1 | -1/+1 | |
2006-06-20 | Remote gdb works well, so include debugging symbols. | Eric Norum | 1 | -1/+1 | |
2006-06-08 | B.Robinson MIPS patch | Greg Menke | 3 | -3/+8 | |
2006-05-15 | Remove non-longer-appropriate comment. | Eric Norum | 1 | -1/+0 | |
2006-04-10 | Keep the frame pointer since its presence makes various diagnostic tools | Eric Norum | 2 | -1/+5 | |
much more useful. | |||||
2006-03-16 | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 4 | -0/+109 | |
* custom/hurricane.cfg, custom/rbtx4925.cfg, custom/rbtx4938.cfg: New (Submission by Bruce Robinson <brucer@pmccorp.com>). | |||||
2006-03-16 | Remove (abandoned). | Ralf Corsepius | 3 | -126/+0 | |
2006-03-16 | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Remove (abandoned). | |||||
2006-01-09 | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* custom/leon1.cfg, custom/leon2.cfg, custom/leon3.cfg, sis.cfg: Merger from rtems-4-6-branch. | |||||
2006-01-09 | Merger from rtems-4-6-branch. | Ralf Corsepius | 4 | -9/+52 | |
2006-01-01 | 2006-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
PR 851/bsps * custom/gen5200.cfg, custom/pm520_cr825.cfg, custom/pm520_ze30.cfg: New (Submission by Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>). | |||||
2006-01-01 | New (Submission by Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>). | Ralf Corsepius | 3 | -0/+70 | |
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -20/+24 | |
* custom/gba.cfg, custom/pc386.cfg: Use .elf instead of .obj. | |||||
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+7 | |
* custom/dmv152.cfg, custom/i386ex.cfg, custom/idp.cfg, custom/mcf5235.cfg, custom/mrm332.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg: Use .srec for files containing SRECs. | |||||
2005-11-22 | Use .srec for files containing SRECs. | Ralf Corsepius | 9 | -20/+20 | |
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* custom/gp32.cfg: Replace .gxb with .elf. * custom/i386ex.cfg, custom/ts_386ex.cfg: Replace .coff with .elf. | |||||
2005-11-22 | Replace .coff with .elf. | Ralf Corsepius | 2 | -6/+6 | |
2005-11-22 | Replace .gxb with .elf. | Ralf Corsepius | 1 | -2/+2 | |
2005-11-04 | 2005-11-03 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2 | -1/+6 | |
* custom/mvme5500.cfg: Fixed PR#846; must not use -mcpu=74xx, use -mcpu=750 instead. | |||||
2005-09-18 | 2005-09-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+2 | |
* custom/orp.cfg: Remove (abandoned). * custom/av5282.cfg: Remove obsolete vars. | |||||
2005-09-18 | Remove obsolete vars. | Ralf Corsepius | 1 | -34/+0 | |
2005-09-18 | Remove (abandoned). | Ralf Corsepius | 1 | -22/+0 | |
2005-09-18 | 2005-09-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -6/+7 | |
* custom/gba.cfg: Remove PROFILE* (abandoned). Remove -static (bogus). | |||||
2005-09-12 | 2005-09-12 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> | Joel Sherrill | 3 | -0/+31 | |
PR 822/bsps * custom/mbx860_001b.cfg, custom/mbx860_1b.cfg: New files. | |||||
2005-08-17 | 2005-08-17 Mike Bertosh <mbertosh@motioncontrol.org> | Joel Sherrill | 2 | -0/+90 | |
* custom/av5282.cfg: New file. | |||||
2005-06-17 | 2005-06-17 Markku Puro <markku.puro@kopteri.net> | Joel Sherrill | 3 | -1/+66 | |
* Makefile.am: Adding GameBoy Advance BSP. * custom/gba.cfg: New file. | |||||
2005-06-17 | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+55 | |
* custom/mcf5235.cfg: New file. | |||||
2005-06-02 | 2005-06-01 Philippe Simons <loki_666@fastmail.fm> | Joel Sherrill | 2 | -8/+15 | |
* custom/gp32.cfg: Add make-cxx-exe. | |||||
2005-05-27 | 2005-05-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+7 | |
* custom/mbx860_005b.cfg, custom/mcp750.cfg, custom/mtx603e.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg: Remove RTEMS_PPC_EXCEPTION_PROCESSING_MODEL (Obsolete). | |||||
2005-05-27 | Remove RTEMS_PPC_EXCEPTION_PROCESSING_MODEL (Obsolete). | Ralf Corsepius | 6 | -7/+0 | |
2005-05-02 | 2005-05-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -42/+7 | |
* Makefile.am: Remove dmv177 and ppcn_60x. * custom/dmv177.cfg: Removed. | |||||
2005-04-30 | 2005-05-30 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -36/+4 | |
* custom/ppcn_60x.cfg: Remove (Gone from libbsp). | |||||
2005-04-28 | 2005-04-28 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 3 | -1/+42 | |
* Makefile.am: Initial release of ep1a bsp * custom/ep1a.cfg: New file. | |||||
2005-04-28 | 2005-04-28 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2 | -2/+7 | |
* custom/score603e.cfg: Update score603e to new exception model NOTE: These modifications have not been tested on hardware. | |||||
2005-03-11 | 2005-03-11 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2 | -50/+4 | |
* custom/vegaplus.cfg: Removed. | |||||
2005-03-11 | 2005-03-11 Philippe Simons <loki_666@fastmail.fm> | Jay Monkman | 2 | -0/+43 | |
* custom/gp32.cfg: New file. | |||||
2005-03-03 | 2005-03-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 4 | -21/+9 | |
* custom/mpc8260ads.cfg : Remove PPC_ASM, PPC_ABI. * custom/mvme5500.cfg: Remove CFLAGS_PROFILE_V. Remove -Wa,-m7450. | |||||
2005-02-25 | 2005-02-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -51/+6 | |
* custom/jmr3904.cfg: arm_bare_bsp obsoleted. * custom/arm_bare_bsp.cfg: Removed. | |||||
2005-02-25 | 2005-02-24 Jay Monkman | Jay Monkman | 1 | -9/+2 | |
* custom/csb337.cfg: Cleanup. | |||||
2005-02-25 | 2005-02-24 Jay Monkman | Jay Monkman | 2 | -0/+46 | |
* custom/csb350.cfg: New BSP. | |||||
2005-02-08 | Put -m5200 back in link-edit commands until proper versions of gcc (which take | Eric Norum | 2 | -2/+8 | |
-m528x as an order to load the -m5200 multilib variants) are widely available. | |||||
2005-02-05 | 2005-02-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -57/+13 | |
* custom/uC5282.cfg: Cleanup. | |||||
2005-01-28 | New BSP. | Eric Norum | 3 | -0/+91 | |
2005-01-20 | 2005-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 12 | -12/+32 | |
* custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/csb336.cfg, custom/csb337.cfg, custom/edb7312.cfg, custom/jmr3904.cfg, custom/pc486.cfg, custom/pc586.cfg, custom/pc686.cfg, custom/pck6.cfg, custom/vegaplus.cfg: Correct use of arguments for gcc 4.x. Hopefully they are still OK for gcc 3.3.5. | |||||
2005-01-01 | 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -285/+6 | |
* compilers/gcc-portsw.cfg: Remove. * Makefile.am: Reflect change above. | |||||
2004-12-30 | Cosmetics. | Ralf Corsepius | 1 | -8/+8 | |
2004-11-23 | 2004-11-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -51/+6 | |
* Makefile.am: Remove eth_comm. * custom/eth_comm.cfg: Removed. |
