* custom/gen405.cfg, custom/helas403.cfg: Remove (Abandonded).
* custom/mvme3100.cfg: Removed CFLAGS_PROFILE_V;
added '-g' to CFLAGS_DEBUG_V.
* custom/pc386.cfg: Use file with symbols.
* custom/ss555.cfg: Add CVS Id.
* custom/mvme3100.cfg: Add make-cxx-exe rule.
* custom/mcf5235.cfg, custom/mrm332.cfg, custom/pc386.cfg: Split
the make-exe and make-cxx-exe into bsp-link-c, bsp-link-cxx and
bsp-post-link make macros. This allow external autotools support.
* custom/mvme3100.cfg: Added; new BSP.
* custom/mvme5500.cfg: Fix typo.
* custom/mvme5500.cfg: Add compiler arguments sine without them, the
BSP has issues.
* custom/rtl22xx_t.cfg: New file, rtl22xx_t is a new bsp compiled
with THUMB enabled
* custom/icecube.cfg: Rename EP5200 to IceCube since that is the
nickname for the Freescale evaluation board it is based upon. BSP was
tested on a Freescale MPC5200LITE.
* custom/mcf5235.cfg: Remove bogus -m5200 from linker calls.
* custom/av5282.cfg: Remove bogus -qnolinkcmds, -m5200 from linker
calls.
* custom/gen83xx.cfg: Use -O2.
* custom/Linux-posix.cfg: Use -O2.
* custom/rbtx4938.cfg: Add missing -O2.
* custom/rtl22xx.cfg: Adjust indentation.
* custom/virtex.cfg: Use -O2.
* custom/Linux-posix.cfg: Make Linux link with just a C main -- avoid
using C++ ctor trick. An RTEMS C++ application running on this BSP
may have initialization order issues to address.
* custom/Linux-posix.cfg: Linux BSP must be linked with C++ compiler.
* custom/gen83xx.cfg: Add make-cxx-exe rule.
many different versions of new exception handling code to shared sources.
* custom/Linux-posix.cfg: Merge patch from Till Straumann which would
work except gcc core dumps with an ICE when may_alias is used in this
code. I filed a GCC PR and reduced optimization to -O0 and it does
run again.
* Templates/Makefile.leaf: At suggestion of Robert Grimes add commented
out make-cxx-exe usage example.
* custom/gen5200.cfg: Remove junk comment.
* custom/ep5200.cfg: New file.
* custom/armulator.cfg: Removed.
* custom/mvme5500.cfg: Use -O2 again.
* Makefile.am: DMV152 obsoleted.
* custom/dmv152.cfg: Removed.
* Makefile.am: Per Jiri Gaisler remove unused erc32nfp and leon1 BSP
variants.
* custom/erc32nfp.cfg, custom/leon1.cfg: Removed.
* custom/gba.cfg, custom/gp32.cfg, custom/i386ex.cfg, custom/pc386.cfg,
custom/sim68000.cfg, custom/ts_386ex.cfg: Clean up to use .nxe
extension instead of BSP unique ones.
* compilers/gcc-no_bsp.cfg: There are no longer any required managers.
Plus some cleanup
* leaf.cfg, compilers/gcc-no_bsp.cfg: Add optional manager stub
for Classic API Barrier.
* custom/rtl22xx.cfg: Cleanup.
* Makefile.am: Add custom/rtl22xx.cfg.
* custom/rtl22xx.cfg: New (Initial submission).
* make/Makefile.am: Cleanup.
* custom/Cygwin-posix.cfg, custom/FreeBSD-posix.cfg,
custom/HPUX9-posix.cfg, custom/Linux-posix.cfg,
custom/Solaris-posix.cfg, custom/armulator.cfg, custom/av5282.cfg,
custom/bare.cfg, custom/c3xsim.cfg, custom/c4xsim.cfg,
custom/csb336.cfg, custom/csb360.cfg, custom/dmv152.cfg,
custom/eZKit533.cfg, custom/edb7312.cfg, custom/ep1a.cfg,
custom/erc32.cfg, custom/erc32nfp.cfg, custom/gba.cfg,
custom/gen405.cfg, custom/gen5200.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/gensh1.cfg,
custom/gensh2.cfg, custom/gensh4.cfg, custom/gp32.cfg,
custom/h8sim.cfg, custom/helas403.cfg, custom/hurricane.cfg,
custom/i386ex.cfg, custom/idp.cfg, custom/jmr3904.cfg,
custom/leon2.cfg, custom/leon3.cfg, custom/mbx821_002b.cfg,
custom/mbx8xx.cfg, custom/mcf5206elite.cfg, custom/mcf5235.cfg,
custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mrm332.cfg,
custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg,
custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg,
custom/nios2_iss.cfg, custom/ods68302.cfg, custom/pc386.cfg,
custom/psim.cfg, custom/rbtx4925.cfg, custom/score603e.cfg,
custom/sim68000.cfg, custom/simcpu32.cfg, custom/simsh4.cfg,
custom/simsh7032.cfg, custom/simsh7045.cfg, custom/ss555.cfg,
custom/ts_386ex.cfg: Add -g to CFLAGS_OPTIMIZE_V.
* custom/gensh1.cfg, custom/gensh2.cfg, custom/gensh4.cfg,
custom/hurricane.cfg, custom/rbtx4925.cfg, custom/simsh4.cfg:
Use $(NM) -g -n instead of $(NM) -n.
