path: root/make (follow)
* 2001-11-27 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-271-5/+1
| | | | * ChangeLog: Deleted bogus entry.
* 2001-11-27 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-271-0/+8
| | | | | | | | This was tracked as PR39. * include/bsp.h, start/cpuboot.c, start/reset.S, startup/debugger, startup/linkcmds, startup/rom: Eliminated required definition of macros in the custom file for the BSP to compile. The ROM and ROM address and size settings are now linker script items.
* 2001-11-27 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-272-30/+8
| | | | | | | This was tracked as PR39. * custom/ods68302.cfg: Eliminated required definition of macros in this file for the BSP to compile. The ROM and ROM address and size settings are now linker script items.
* 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-276-50/+14
| | | | | | | | | | | | | * custom/gen405.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG; Remove make-target-options. * custom/helas403.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG; Remove make-target-options. * custom/mbx8xx.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE. * custom/mbx860_005b.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE. * custom/mpc8260ads.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE.
* 2001-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-264-76/+6
| | | | | * custom/papyrus.cfg: Removed. * custom/Makefile.am, custom/helas403.cfg: Removed reference to above.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-213-32/+5
| | | | | * custom/mvme2307.cfg: Reflect changes to motorola_powerpc/configure.ac. * custom/mcp750.cfg: Ditto.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-215-137/+10
| | | | | | | | * custom/dmv177.cfg: Reflect changes to dmv177/configure.ac. * custom/ppcn_60x.cfg: Refect changes to ppcn_60x/configure.ac. * custom/psim.cfg: Refect changes to psim/configure.ac. * custom/score603e.cfg: Reflect changes to score603e/configure.ac, remove SCORE603E_GENERATION.
* 2001-11-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-205-123/+8
| | | | | | | * custom/eth_comm.cfg: Reflect changes to eth_comm/configure.ac. * custom/mbx8xx.cfg: Reflect changes to mbx8xx/configure.ac. * custom/mbx860_005b.cfg: Ditto. * custom/mpc8620ads.cfg: Reflect changes to mpc8620/configure.ac.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-153-21/+5
| | | | | * custom/gensh1.cfg: remove make-target-options. * custom/gensh2.cfg: remove make-target-options.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-152-15/+5
| | | | | * custom/dmv152: Remove USE_CONSOLE_A, Remove USE_CONSOLE_B, remove make-target-options, remove BSP_CPPFLAGS.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-152-13/+4
| | | | * custom/simhppa.cfg: Remove SIMHPPA_FAST_IDLE, make-target-options.
* 2001-11-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-147-36/+7
| | | | | | | * custom/eth_comm.cfg, custom/mbx860_005b.cfg, custom/mbx8xx.cfg, custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mvme2307.cfg: These are new exception processing model BSPs and thus do not need to define PPC_USE_SPRG.
* 2001-11-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-141-0/+7
| | | | * ChangeLog: Added missing lines about simcpu32.cfg and sim68000.cfg.
* 2001-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-144-31/+30
| | | | * custom/ts_386ex.cfg: Remove make-target-options.
* 2001-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-143-26/+17
| | | | | | * custom/shsim.cfg: Remove HZ, BSP_CPPFLAGS, make-target-options. * custom/mvme2307.cfg: Fix PPC_USE_SPRG in make-target-options, re-adopt mcp750.cfg's make-exe.
* 2001-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-133-4/+13
| | | | | | * custom/helas403.cfg, custom/gen405.cfg: Removed dependency on the --srec-len argument to objcopy only supported in binutils 2.11 or newer.
* 2001-11-08 Dennis Ehlin (ECS) <Dennis.Ehlin@ecs.ericsson.se>Joel Sherrill2001-11-093-0/+97
| | | | | | | | | | This modification is part of the submitted modifications necessary to support the IBM PPC405 family. This submission was reviewed by Thomas Doerfler <Thomas.Doerfler@imd-systems.de> who ensured it did not negatively impact the ppc403 BSPs. The submission and tracking process was captured as PR50. * custom/gen405.cfg: New file. * custom/helas403.cfg: Modified to generate Srecords.
* 2001-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-302-1/+5
| | | | * custom/sim68000.cfg: Generate symbols off executable not Srecords.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-262-0/+65
| | | | * custom/mcf5206elite.cfg: New file.
* 2001-10-22 Andy Dachs <a.dachs@sstl.co.uk>Joel Sherrill2001-10-222-0/+119
| | | | * custom/mpc8260ads.cfg: New file.
* 2001-10-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-153-13/+6
| | | | | * custom/gensh4.cfg: Remove START_HW_INIT. * custom/simsh4.cfg: Remove START_HW_INIT, RTEMS_CPU_MODEL=sh7750.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-123-4/+5
| | | | | * custom/gensh4.cfg: Remove HZ. * custom/simsh4.cfg: Remove HZ.
* 2001-10-11 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-113-0/+159
| | | | | | * custom/gensh4.cfg, custom/simsh4.cfg: New files in support of Hitachi SH4 BSPs of the same name. Reviewed and some cleanup by Joel Sherrill <joel@OARcorp.com>.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-2/+5
| | | | * custom/gensh2.cfg: Remove -lstdc++ from make-exe.
* 2001-10-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-113-4/+13
| | | | | * custom/mbx8xx.cfg, custom/mvme167.cfg: Rewrote use of strip command to avoid using the apparently broken or deprecated -o argument.
* 2001-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-282-0/+13
| | | | | * custom/ods68302.cfg: Add custom make-cxx-exe rule to account for MC68302_BASE.
* 2001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-0/+10
| | | | * custom/bare.cfg: Define dummy make-cxx-exe.
* 2001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-5/+9
| | | | | * custom/gensh2.cfg: Remove -lstdc++ from make-exe. * ChangeLog: Formatting cleanup.
* 2001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-212-15/+19
* 2001-09-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-141-1/+1
| | | | | | | | | | * aclocal/canonical-target-name.m4: Use AC_CANONICAL_TARGET instead of AC_CANONICAL_SYSTEM. * aclocal/config-subdirs.m4: Use AS_MKDIR_P instead of mkinstalldirs and mkdir. * aclocal/target.m4: Obsolete RTEMS_OUTPUT_BUILD_SUBDIRS, hack RTEMS_CONFIG_BUILD_SUBDIRS, introduce _RTEMS_OUTPUT_BUILD_SUBDIRS.
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-1915-72/+18
| | | | | | | | | | | | | | | | | custom/Cygwin-posix.cfg: Remove -U__STRICT_ANSI__, make-target-options. custom/FreeBSD-posix.cfg: Remove make-target-options. custom/HPUX9-posix.cfg: Dito. custom/Linux-posix.cfg: Dito. custom/Solaris-posix.cfg: Dito. custom/arm_bare_bsp.cfg: Dito. custom/armulator.cfg: Dito. custom/erc32.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/i386ex.cfg: Remove make-target-options. custom/i960sim.cfg: Remove make-target-options. custom/mvme2307.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/rxgen960.cfg: Remove make-target-options, cleanup comments. custom/score603e.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/vegaplus.cfg: Remove make-target-options.
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-252-2/+6
| | | | * custom/mrm332.cfg: Switched $(SED) to sed.
* 2000-05-25 Matt Cross <profesor@gweep.net>Joel Sherrill2001-05-251-0/+93
| | | | | | | | | | | | | | | | | * New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * .cvsignore, ChangeLog Makefile.am, README, bsp_specs, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in, console/.cvsignore, console/Makefile.am, console/console.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c, spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c, start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore, startup/Makefile.am, startup/bspclean.c, startup/bspstart.c, startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM, timer/.cvsignore, timer/Makefile.am, timer/timer.c, times, wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
* 2000-05-25 Matt Cross <profesor@gweep.net>Joel Sherrill2001-05-251-0/+7
| | | | | | | * New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * custom/mrm332.cfg: New file.
* 2001-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-242-11/+5
| | | | | * custom/dmv177.cfg: Remove CONSOLE_USE_INTERRUPTS, CONSOLE_USE_POLLED, HAS_RTC.
* 2001-05-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-113-12/+5
| | | | | * custom/gensh1.cfg: Remove HZ, BSP_CPPFLAGS. * custom/gensh2.cfg: Dito.
* 2001-05-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-087-27/+15
| | | | | | | | | | * leaf.cfg: Remove CFLAGS_DEBUG_OPTIMIZE_V. * compilers/gcc-no_bsp.cfg: Remove CPP_CC_FLAGS. * compilers/gcc-portsw.cfg: Remove CPP_CC_FLAGS. * compilers/gcc-target-default.cfg: Remove *_DEBUG_OPTIMIZE_*-flags, remove unused flags, remove -ansi from CPP. * custom/eth_comm.cfg: Remove CPU_DEFINES. * custom/sim68000.cfg: Remove CPU_DEFINES.
* 2001-04-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-04-266-7/+12
| | | | | | | | * compilers/gcc-no_bsp.cfg: Remove -ansi -fasm. * compilers/gcc-default.cfg: Dito. * compilers/gcc-portsw.cfg: Remove -Hansi. * custom/posix.cfg: Remove inclusion of target.cfg. * custom/simhppa.cfg: Remove -ansi -fasm.
* 2001-04-11 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-04-112-0/+6
| | | | | * custom/eth_comm.cfg: Switch the eth_comm BSP to use the "new exception processing model."
* 2001-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-112-2/+7
| | | | | * custom/default.cfg: Switch to using exec_prefix to reflect new organization of install point from Ralf Corsepius.
* 2001-03-30 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-04-062-4/+14
| | | | | * custom/mbx860_005b.cfg: This switches the MBX8xx BSP to the use the "new exception processing model."
* 2001-03-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-142-0/+57
| | | | * custom/genmongossev.cfg: New file.
* 2001-02-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-03-011-2/+2
| | | | | | | | * configure.in: Reworked for Canadian Cross support. * Makefile.am: Reflect changes to configure.in. * config.guess, config.sub: Update from subversions.gnu.org. * README.cdn-X: New file. * tools/Makefile.am: Remove build, tools from SUBDIRS.
* 2001-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-212-0/+15
| | | | * custom/pc386dx.cfg: New bsp.
* 2001-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-126-23/+6
| | | | | | * custom/Cygwin-posix.cfg, custom/HPUX9-posix.cfg, custom/Solaris-posix.cfg, custom/FreeBSD-posix.cfg, custom/Linux-posix.cfg: Remove RTEMS_UNIX from make-target-options.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-054-24/+7
| | | | | | | * lib.cfg: include $(PROJECT_ROOT)/make/leaf.cfg * main.cfg: Set PROJECT_RELEASE=$(exec_prefix)/$(RTEMS_BSP). * host.cfg.in: Remove RM, make-script. * ChangeLog: Remove bogus 2001-01-22 entry.
* 2001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-224-12/+72
| | | | | * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and simsh7045.
* 2001-01-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-092-10/+5
| | | | | * custom/pc386.cfg (make-exe): Removed commented out lines that were displayed in build longs.
* 2001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-084-10/+27
| | | | | | * custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Remove unneeded definitions when compiled for "mips" rather than "mips64orion." Correct CPU_CFLAGS.
* 2001-01-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-052-2/+7
| | | | | * custom/gensh1.cfg: Removed rest of make-target-options and moved them to BSP configure options.
