path: root/make (follow)
* ./clock/Makefile.in,vJoel Sherrill1999-02-181-0/+111
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | ./clock/clock.c,v ./console/Makefile.in,v ./console/config.c,v ./console/console.c,v ./console/console.h,v ./console/debugio.c,v ./console/i8042.c,v ./console/i8042_p.h,v ./console/i8042vga.c,v ./console/i8042vga.h,v ./console/ns16550.c,v ./console/ns16550.h,v ./console/ns16550_p.h,v ./console/ns16550cfg.c,v ./console/ns16550cfg.h,v ./console/vga.c,v ./console/vga_p.h,v ./console/z85c30.c,v ./console/z85c30.h,v ./console/z85c30_p.h,v ./console/z85c30cfg.c,v ./console/z85c30cfg.h,v ./include/Makefile.in,v ./include/bsp.h,v ./include/chain.h,v ./include/coverhd.h,v ./include/extisrdrv.h,v ./include/nvram.h,v ./include/pci.h,v ./include/tod.h,v ./network/Makefile.in,v ./network/amd79c970.c,v ./network/amd79c970.h,v ./nvram/Makefile.in,v ./nvram/ds1385.h,v ./nvram/mk48t18.h,v ./nvram/nvram.c,v ./nvram/prepnvr.h,v ./nvram/stk11c68.h,v ./pci/Makefile.in,v ./pci/pci.c,v ./start/Makefile.in,v ./start/start.s,v ./startup/Makefile.in,v ./startup/bspclean.c,v ./startup/bspstart.c,v ./startup/bsptrap.s,v ./startup/device-tree,v ./startup/genpvec.c,v ./startup/linkcmds,v ./startup/rtems-ctor.cc,v ./startup/sbrk.c,v ./startup/setvec.c,v ./startup/spurious.c,v ./startup/swap.c,v ./timer/Makefile.in,v ./timer/timer.c,v ./tod/Makefile.in,v ./tod/cmos.h,v ./tod/tod.c,v ./universe/Makefile.in,v ./universe/universe.c,v ./vectors/Makefile.in,v ./vectors/README,v ./vectors/align_h.s,v ./vectors/vectors.s,v ./wrapup/Makefile.in,v ./Makefile.in,v ./README,v ./STATUS,v ./bsp_specs,v
* Jay Monkman <jmonkman@frasca.com> submitted the eth_comm BSP for a PPC860Joel Sherrill1999-02-171-0/+84
| | | | based board.
* Commented out disable of building network code so it is built. You canJoel Sherrill1999-02-051-1/+1
| | | | | hack through some paths to check error checking paths without a network driver.
* Added instruction and data cache enable.Joel Sherrill1999-02-051-2/+13
* Added comments to indicate what options are required to take advantageJoel Sherrill1999-01-191-1/+3
| | | | | | of removal of unused function code found in newer binutils/egcs snapshots. Early test with psim and hello.exe showed about a 13% gain.
* Changed definition of ASMFLAGS since as does not recognize -B optionJoel Sherrill1999-01-191-1/+1
| | | | used in gcc.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename allJoel Sherrill1998-12-143-14/+7
| | | | | .s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake.
* Patch from Emmanuel Raguet <raguet@crf.canon.fr> to add remote debug serverJoel Sherrill1998-12-032-0/+8
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | and RPC support to RTEMS. Thanks. :) Email follows: Hello, For Xmas, here is the Remote Debugger on RTEMS ! Here are 2 patches for the Remote Debugger on RTEMS for pc386 from Linux host : - one for RTEMS it self, - one for GDB-4.17. 1/ RTEMS patch -------------- This patch adds 2 libraries : - a simplified SUN RPC library - the Remote Debugger library The configuration command is the following : ../rtems4/configure --target=i386-rtemself --enable-rtemsbsp=pc386 --enable-rdbg The SUN RPC library is built only if networking is set. The RDBG library is built if networking and enable-rdbg are set. The function used to initialize the debugger is : rtems_rdbg_initialize (); A special function has been created to force a task to be in a "debug" state : enterRdbg(). The use of this function is not mandatory. 2/ GDB-4.17 patch ----------------- This patch create a new RTEMS target for GDB-4.17. The configuration command is the following : ./configure --enable-shared --target=i386RTEMS To connect to a target, use : target rtems [your_site_address] Then, attach the target using : attach 1 And... Debug ;) You can obtain the original GDB-4.17 on ftp://ftp.debian.org/debian/dists/stable/main/source/devel/gdb_4.17.orig.tar.gz This has been tested from a Debian 2.0.1 linux host.
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-2315-36/+8
| | | | it work.
* Removed "HAS_NETWORKING=no".Joel Sherrill1998-11-231-4/+0
* Bug report from Peter Mueller <pmueller@decrc.abb.de>:Joel Sherrill1998-11-191-1/+1
| | | | | | | | I use the m68k/efi332 BSP together with a home made board. After some time of debugging I found that the m68020 CPU is used to build rtems. This is not correct, because the 68332 does not have some of the 68020 features (no separate int stack ...). It is necessary to change this to mcpu32. After a clean/make everything works fine.
* Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs alongJoel Sherrill1998-10-282-4/+1
| | | | with libchip.
* Patch from Erik Ivanenko <erik.ivanenko@utoronto.ca>:Joel Sherrill1998-10-221-15/+16
| | | | | | | | | | Please find attached a new i386ex.cfg. It has been altered to change the files that get generated with the .nxe extension to .coff. This change is necessary to align the file names generated by "make-exe" to the those referred to in the GDB.HOWTO found in the i386/shared/comm directory. It has been successfully tested on ticker ( without GDB), and base_sp( with GDB ) . I just set a breakpoint and continue...
* Removed unnecessary settings.Joel Sherrill1998-10-151-6/+0
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-10-141-0/+10
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1. Rtems contains some perl scripts that use hard-coded paths to /usr/bin/perl or /usr/local/bin/perl I have already fixed these problems by adding some checks to configure.in. While doing this, I also cleaned up some more autoconf related problems for generating shell scripts. This patch might seem a bit scary to you, but I am quite confident it won't break something (I've been testing it for almost a week now, however it might introduce typos for a limited number configurations I don't have access to - But it shouldn't be a problem for you to test them :-). I expect to get this finished tonight, hence you will very likely have the patch when you get up tomorrow. Changes: * Check for PERL and disable all PERL scripts if perl wasn't found. * Generate all KSHELL-scripts with autoconf instead of make-script * Automatic dependency handling for autoconf generated KSHELL or PERL scripts (make/rtems.cfg) Notes: * this patch contains new files and deletes some other files. * The patch is relative to rtems-4.0.0-beta4 with my previous rtems-rc-981014-1.diff patch applied. Testing: I tested it with sh-rtems and posix under linux. Now all targets which are touched by this patch and which are not used while building for sh-rtems and posix still need to be tested. AFAIS, only the sparc/erc32 BSP should be affected by this criterion. And if you like to, you should also consider testing it on a Cygwin32 and a Solaris host for one arbitrary BSP.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-10-141-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 2. "make profile" doesn't work. It aborts when building host-tools for embedded targets. I didn't yet have enough time to fix this problem. AFAIS this problem is related to handling of LDFLAGS_PROFILE[|_V] in gcc.cfg.in. For host applications, we use gcc for linking host applications, too. With profiling enabled CFLAGS_PROFILE_V contains -pg and is used to compile, but LDFLAGS_PROFILE_V is empty, hence -pg will not be passed to the linker causing gcc to fail to link, because it can't resolve some symbols introduced by compiling with -pg. I am not sure if I can provide a patch for this - Ether it is trivial to fix or requires basic work on host configuration ;- Fixing this one was trivial - But hard to trace. LDFLAGS_PROFILE_V needs to contain the same flags as CFLAGS_PROFILE_V, if gcc is used for linking (What else should have been expected ?, :-). The same problem was present for *_DEBUG_V, but apparently wasn't noticed by anybody, because things didn't break, but were silently ignored. I fixed these problems by setting these flags in configure.in whenever gcc is reported to be the host-compiler. For non-gcc host compilers "make debug" and "make profile" now becomes the same as an ordinary "make". This is a hack and addressing this problen could be more sophisticated, but I don't think it gives much sense to support compile variants for any host program (Who will ever try to profile/debug host tools?). Therefore I don't think it's useful to invest more effort into this problem.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to correct minorJoel Sherrill1998-10-131-4/+0
| | | | cosmetic things.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-10-054-13/+0
| | | | | | | | | | | | | | | | | | | | As mentioned in other mails before, there is are minor inconsistencies in the posix custom/*cfg files. Linux-posix.cfg sets RTEMS_BSP=posix FreeBSD-posix.cfg sets RTEMS_BSP=posix Solaris-posix.cfg first sets RTEMS_BSP=posix, later it sets RTEMS_BSP=solaris2 1. Setting RTEMS_BSP=posix is redunant to settings in default.cfg 2. The solaris variant of setting RTEMS_BSP is merely non-functional. The patch attached to this mail should clean up this issue. The patch was tested by building the posix bsp under i686-pc-linux-glibc1/glibc2 and Solaris2.6 (I did not run any rtems program, however) The HPUX9 and FreeBSD configuration files were adapted in analogy to the solaris and linux configurations.
* Switched from HAS_KA9Q=no to HAS_NETWORKING=no.Joel Sherrill1998-10-011-2/+2
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-10-011-0/+8
| | | | | | | | | Here's a patch to get rid of the `#define RTEMS__mcpu32p__ 1' when gen68360.cfg is being used as a companion for gen68360_040.cfg. The old version worked because of the order of the conditional tests in m68k.h (the check for __mc68040__ is before the test for RTEMS__mcpu32p__) , but I think it might have been a little confusing to others just getting started.
* BSP submitted by Thomas Doerfler <td@imd.m.isar.de>:Joel Sherrill1998-09-301-0/+110
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Finally I am through: I have found the last bugs that made RTEMS- 4.0-beta3 start on my ppc403 board from ROM. So now the '403 support is up to date again. Roughly I have added the following features: - support for the on-chip interrupt controller (in a separate module) - interrupt support for the console device - termios support for the console device ============================================== Since the BSP behaivour changed in some details (console no longer is polling, other memory layout etc) I have created a new BSP "helas403" rather than changing the "papyrus" BSP. The old "polled" console driver still sticks around in "console.c.polled" To get the BSP up and running, I had to create the new BSP files (derived from papyrus). Besides that, the following source areas have been changed: - c/src/lib/libcpu/powerpc/ppc403: changes to console driver, small changes to clock driver, new "ictrl" interrupt controller driver - c/src/exec/score/cpu/powerpc/ppc.h: some small changes (added ppc403 characteristics like a exception vector prefix register, some special register definitions). I am quite sure, they are compatible with the existing sources, although I did not check - c/src/exec/score/cpu/powerpc/cpu.c: There is one severe limitation in the exception entries: Due to the current code arrangement, the "branch absolute" to the ISR handler may only jump to the first 128MByte or the last 128MByte of the 4GByte address range. When the ppc403 is running out of ROM, the ROM functions are located in the last 128MByte (0xFFF00000 and up). These addresses were not handled correctly (sign reduced) in "install_raw_handler". The change I added should work on existing ppc BSPs aswell... - c/src/lib/libc/termios.c: During my tests, I added one change you sent me, so this patch will already be incorporated in the current source tree. There are some smaller changes, see the attached diff file. ========================================= Concerning the GNU toolchain: I tried several tool chains. Finally I almost succeeded with egcs-1.0.3a with patch egcs-1.0.3-rtems-diff-19980527 I had to add the following lines to the egcs files. Without them configure complaint that the cross compiler could not generate executable output. - additional lines needed in egcs distribution in file gcc/config/rs6000/rtems.h: +++ lines start #undef STARTFILE_DEFAULT_SPEC #define STARTFILE_DEFAULT_SPEC "ecrti.o%s" #undef ENDFILE_DEFAULT_SPEC #define ENDFILE_DEFAULT_SPEC "ecrtn.o%s" ++++ lines end As far as I have seen in the Changelog of egcs, you have recently sent two patches affecting the powerpc support, but they were added in the wrong order.... :-( egcs-19980628 with patch egcs-19980628-rtems-diff-19980707 does not work! I used binutils 2.9.1 with patch binutils-2.9.1-rtems-diff-19980515 (binutils 2.8.1 does not work, internal error in gas) and newlib-1.8.0 with patch newlib-1.8.0-rtems-diff-19980707 Finally I had to poke a line in the "bit" script, since, on my LINUX machine, the GNU make is only available as "make", not as "gmake"... For all the tools and newlib I selected configuration "powerpc- rtems". -------------------------------------------- IMD Ingenieurbuero fuer Microcomputertechnik Thomas Doerfler Herbststrasse 8 D-82178 Puchheim Germany email: td@imd.m.isar.de
* Patch from Eric Norum <eric@skatter.USask.Ca>:Joel Sherrill1998-09-301-7/+0
| | | | | | | | | | | | | | | | | | | | | | | I found that my 68040/68360 test programs would not run even after I fixed the `wrong BSP' problem. It seems that there's a bug in the interrupt handling code for processors with hardware interrupt stacks (e.g. 68040). The wrong status register was getting pushed on the stack for the `return from exception' to call _ISR__Dispatch. This ended up making the context switch code run on the interrupt stack, so interrupt-driven context switches would always fail. I guess that no one has tried running any of the RTEMS-4.0 snapshots on a 68040 machine! Anyhow, here are the patches for 1) gen68360.cfg --- to fix the `wrong-BSP' problem. 2) m68k/cpu_asm.s --- to fix the hardware interrupt stack problem. With these patches in place, the network demo programs run on my 68040/68360 system. The paranoia program runs with no failures, defects nor flaws.
* Improved missing directory message.Joel Sherrill1998-09-241-1/+4
* Patch from Aleksey (Quality Quorum <qqi@world.std.com>):Joel Sherrill1998-09-231-0/+1
| | | | | | | | | | | 1. Finally fixes raw interrupts for pc386 2. Makes some minor cleanup in console and startup 3. Makes rtems_termios_dequeue_characters() to return count of outstanding chars - it allows to simplify console isrs a little bit. 4. pc386 uart modified to be friendlier to termios parameter changes, to have minor performance improvement and to take advantage of of above termios modification.
* Updates to tree to make it build with all desired changes and the conversionJoel Sherrill1998-09-111-1/+1
| | | | of the SONIC driver to the new FreeBSD stack instead of KA9Q.
* Patch from Chris Johns <ccj@acm.org>:Joel Sherrill1998-09-101-1/+1
| | | | | | | | | | | I have managed to build the bsp ods68302 and the rtti test case I made with egcs-1.1b and binutils-2.9.1. I have built our C++ application and got no link errors so it looks like this is now working. I am yet to test the code but getting the thing to link was the problem. Please find a patch attached which removes the -fno-rtti option.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-08-241-9/+15
| | | | | | | | | The patch (rtems-rc-980821.diff) I had sent recently to fix the "make install" problem in rtems-980821/make/ still contained a bug (Thanks to Eric N. for reporting it). The patch enclosed to this mail is a corrected version of this patch, which finally should fix this problem.
* A patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-08-213-33/+235
| | | | | | | | | | | | | | | | | | | | | | | | | | Here is another patch to hopefully enhance rtems' configuration. Motivation: Try to support other c-compilers besides gcc (I tried to build rtems under Solaris using sun's WSPro c-compiler). Here is a couple of small patches concerning the host compiler configuration, which fix/work-around the worst problems when using sun's WSPro c-compiler. Changes: * Replaced make/compilers/gcc.cfg with make/compilers/gcc.cfg.in, ie. gcc.cfg is generated by configure now. * Removed a line containing a hard-coded "gcc" from gcc.cfg (BUG-fix). * Add -g to host compiler flags only if configure reported -g to work * Add -Wall to host compiler flags only if configure reported that the host compiler is gcc (WSPro's cc chokes on -Wall). * Some modifications to make/Makefile.in * Adapted make/custom/default.cfg to the new location of gcc.cfg BTW, gcc.cfg/gcc.cfg.in seems to be full of unused code (DEBUG-VARIANTS etc.) which deserves to be cleaned up, IMO. IMO, a similar patch should be applied to gcc-target-default.cfg
* Patches from Eric NorumJoel Sherrill1998-08-2031-126/+3
* FreeBSD stack compiles for the first time (except libc/strsep.c)Joel Sherrill1998-08-2030-1/+125
* Patch from Aleksey <qqi@world.std.com>:Joel Sherrill1998-08-191-7/+1
| | | | | | It fixes netboot build problem, KA9Q configuration for pc386, some compiler wardning, it also removed some stuff ifdef'ed with '#if 0'.
* Patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> and myself toJoel Sherrill1998-08-191-1/+0
| | | | | | | | | | | | | | | | | | | | | | | | make solaris target buildable. > 1. The ipc check fails since solaris does not define union semun. > The unix port code actually defines this type itself on solaris. Doing > the same thing lets it get configured. Then... > 2. It looks like BSDINSTALL is not defined properly. BSDINSTALL is defined in make/host.cfg.in as BSDINSTALL=@INSTALL@ @INSTALL@ is generated by autoconf's standard macro AC_PROG_INSTALL, which is widely used in almost any autoconf/automake configured package. In case there is really something wrong with it, then it must be considered a bug in autoconf. I can see a doubious fragment in AC_PROG_INSTALL, which is used when no appropriate bsd-install is found. Finally Ralf saw a problem with the find on solaris which I also saw and fixed.
* Cleaned up the ka9q definition.Joel Sherrill1998-08-191-4/+0
* changed load addressJoel Sherrill1998-08-051-2/+5
* Patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to make ASFLAGS include theJoel Sherrill1998-08-011-1/+1
| | | | CPU_ASFLAGS.
* Added HAS_RTC and enabled KA9Q.Joel Sherrill1998-07-301-4/+2
* Added missing parts of patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1998-07-281-4/+16
* Switching console interrupts on and off as we test.Joel Sherrill1998-07-251-1/+1
* Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel RaguetJoel Sherrill1998-07-241-1/+1
| | | | <raguet@crf.canon.fr> to make their patches work together.
* Patch from Emmanuel Raguet <raguet@crf.canon.fr>:Joel Sherrill1998-07-231-1/+1
| | | | | | | | | | | | Here is a patch for KA9Q stack. This patch contains an Ethernet Driver for Western Digital, some fixes for the UDP and TCP protocols (for endian conversion) and some little programs which allow the test of UDP and TCP sockets via Ethernet. I have tested that on an Intel machine. If someone can test it on a big-endian machine, ...
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. Comments:Joel Sherrill1998-07-172-5/+8
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Added support for bsd "install" ($(BSDINSTALL)) to host.cfg.in, i.e. the standard "install" program that most packages (including automake) use. In Makefiles outside of rtems, "install" normally is referenced by $(INSTALL), but rtems already uses $(INSTALL) for install-if-change, hence I used $(BSDINSTALL) instead to keep up backward compatibility. * Removed references to @GREP@ etc. from host.cfg.in, as configure.in doesn't check for them (Minor cleanup). * Added installation flags INST*FLAGS to host.cfg.in, which should replace -m XXXX flags for installation calls. *Changes to gcc.cfg to enable it to build host programs from multiple sources files. Should not disturb existing sources, but neccessary. * There was a not-so-minor bug in the configuration files: "make install" and "make debug_install" don't work in all subdirectories!! I tried to fix this by adding "install" to MTARGETS in main.cfg, which seems to solve most of the problems. But there still seem to be rare (?) cases where "make debug_install" still seems to have problems. * Changes to many host related tool-Makefiles to demonstrate the abilities of INST*FLAGS, BSDINSTALL and the new rules in gcc.cfg. ..of cause ... but BSDINSTALL is THE standard method to install files in most program packages besides rtems. This part of the patch fixes some minor protection setting problems, but doesn't support TARGET_VARIANTS NOTE: I hope you will like the BSDINSTALL, INST*FLAGS stuff. It is a step to get rid of "install-if-change" and to rely on a more standard installation procedure. If you don't like BSDINSTALL, removing it from the patch isn't difficult- just grep for BSDINSTALL and replace BSDINSTALL with INSTALL or MKDIR. FINALLY: I still have another patch pending (well, not a complete patch yet, it's a partial patch to demonstrate the principle), which adds automatic rebuilding of files generated by autoconf/configure. At the moment I don't dare to submit it, because integrating this patch would require to modify all Makefile.ins because we'd need to add a new "include " line to each Makefile.in.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1998-07-171-1/+4
| | | | Changes to make/custom/gensh1.cfg. Needed for shgen support
* Switched CONSOLE_USE_INTERRUPTS to "1" so console would use interrupts.Joel Sherrill1998-07-151-2/+2
| | | | | Switched PPC_USE_SPRG to "0" so RTEMS use of sprg would not conflict with any possible sprg usage by the DY-4 ROM monitor.
* Yet another EXEEXT patch. This one is from Ralf CorsepiusJoel Sherrill1998-07-111-2/+2
| | | | | | | | <corsepiu@faw.uni-ulm.de> and his comments are below: Joel, obviously you did apply my previous patch to gcc-target-default.cfg -- This should have been gcc.cfg (gcc-target-default.cfg should NOT contain any EXEEXT).
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. Comments:Joel Sherrill1998-07-101-2/+2
| | | | | | | | | | | | | | | | | | > It seems that rules for %{EXEEXT} don't exist in gcc-target-default.cfg No, gcc-target-default.cfg is used to compile executables for the target only, not for the host. EXEEXT may only be used for programs to be run on the host. > What should I add please? This was a bug in my initial configuration patch to rtems-980616. A correction to this patch I had sent to Joel at 26.06.98 doesn't seem to have made it into the snapshot. Please find attached the patch I had sent to Joel, hopefully this patch fixes this problem.
* Now strip elf executables so they are much smaller and quicker toJoel Sherrill1998-07-091-0/+1
| | | | read from and write to a floppy.
* Initial submission of gen68340 BSP (should run on a 68349) fromJoel Sherrill1998-07-011-0/+102
| | | | Geoffroy Montel <g_montel@yahoo.com>.
* Correction from Aleksey Romanov <qqi@world.std.com> to finish off his patch.Joel Sherrill1998-06-291-0/+1
| | | | I had trouble merging his original patch and this corrected a reject.
* PC386 BSP enhancements from Aleksey Romanov (Quality QuorumJoel Sherrill1998-06-271-0/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | <qqi@world.std.com>). Unfortunately after merging these, the pc386 will not boot using grub for for. It still does not work using netboot for me. Here is his summary of changes: rtems/c/src/lib/libbsp/i386/pc386/Makefile.in Added support for new sub-directory rtems/c/src/lib/libbsp/i386/pc386/bsp_specs Made possible to build COFF image rtems/c/src/lib/libbsp/i386/pc386/console/console.c Added support for serial consoles, selectable by patching binary image, added __assert(), use _IBMPC_inch_sleep() instaed of _IMBPC_inch() rtems/c/src/lib/libbsp/i386/pc386/console/inch.c Added _IMBPC_inch_sleep() rtems/c/src/lib/libbsp/i386/pc386/console/outch.c Oops - just formatting rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in Added support for new files rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h Added support for new features rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h New file: definitions for serial ports rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h New file: definitions for PCI BIOS rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in New file: makefile in new directory rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c New file: i386-stub interface rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c New file: i386-stub itself rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c New file: serial ports rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c New file: PCI BIOS support rtems/c/src/lib/libbsp/i386/pc386/start/start.s Commented out DEBUG_EARLY stuff, everything is working fine rtems/c/src/lib/libbsp/i386/pc386/start/start16.s Cleaned up rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c Added call to console_resereve_resources rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c Added support for serial console rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s Fixed typo in comments rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in Changed to reflect cnages in code rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c Trivialized, problem - I do not know how to make patch remove obsolete files - there are a lot of them there rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c New file: utility to do binary patches rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in Added support for new directory rtems/make/custom/pc386.cfg Add COFF image building
* Monstrous patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. I haveJoel Sherrill1998-06-2735-188/+132
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | made no attempt to divide the comments up and place them with just the appropriate files. Here is an excerpt from Ralf's email: Changes including comments on changes I made after cycling through all the targets: * Added ranlib support. Now all targets use "ranlib" instead of "ar -s" to build an index for a library. If ranlib isn't detected during configuration, check if ar -s is working and try "ar -s" instead of * Removed $(XXX_FOR_TARGET) from make/target.cfg.in, use $(XXX) instead now. * gcc-target-default.cfg: LINK_XXXX-defines reworked to solve the -l problem under posix (cf gcc-target-default.cfg) * rtems-glom replaced by Makefile-rules inside of the wrapup/Makefile.in that has been using rtems-glom until now. * Removed CCC and friends in gcc-target-default.cfg, as they have been breaking CXX support. * Removed CONFIG.$(TARGET_ARCH).CC lines from several custom/*.cfg files, because this is now set in custom/default.cfg. * Added aclocal/ar-s.m4, check whether "ar -s" is working * Added aclocal/cygwin.m4 and aclocal/exeext.m4. * Reworked aclocal/canonicalize-tools.m4: Added ar -s check; fixes for problems when XXX_FOR_TARGET is given via environment variables (didn't work for gcc until now), adding cygwin check, improved autoconf-cache handling. * Removed -l from make rule dependencies. LINK_LIBS is now allowed to contain -L and -l. LINK_OBJS and LINK_FILES must not contain -L or -l. gcc28 make-exe rules now link using $(LINK_OBJS) $(LINK_LIBS) => Almost all custom/*.cfg are modified. This is very likely to break something because of typos or having missed to edit a file. Open problems, known bugs, things I didn't do: * custom/p4000.cfg seems to be out of date and requires to be reviewed. (JRS NOTE: It is subordinate p4650 and p4600 -- both of which build ok after minor changes.) * custom/psim.cfg needs to be reviewed, I added some changes to it, I am insecure about. (JRS NOTE: psim had a minor problem endif/endef swapped but runs fine.) * rtems-glom.in can now be removed. * gcc*.cfg files "make depend" rules don't honor language specific flags (e.g CXXFLAGS is ignored for *.cc) - Nothing to worry about now, but may cause problems for hosts/targets not using gcc or rtems-add-ons that use external packages. * AFAIS, the no_bsp BSP can't be build anymore, i.e. configure refused to configure for it whatever I tried. * The toplevel and toplevel+1 README files are quite out-dated * cygwin.m4 isn't of much use for rtems. In most cases (cf. aclocal/*.m4) it is worked around by directly using $host_os. I think I'll remove it soon after the next snapshot * Before release the cygwin patch needs to be tested under cygwin. I may have broken/missed something (esp. the sed-pattern to convert \\ into / may be broken). * You should try to build/run the posix-BSP under solaris - I don't expect problems, but I am not 100% sure, esp. with regard to ranlib/ar -s. * You should consider to convert all make/compilers/*.cfg files into make/compilers/*.cfg.in files and let autoconf generate the *.cfg. This may help getting rid of some if/then/else statements and help hard-coding some defines into those files in future and shouldn't disturb now. * Not having installed libc.a/libm.a on a host may still break building rtems, esp. when using -disable-gcc28 as the gcc27-configuration scheme directly accesses libc.a and libm.a. The problem should not appear when using gcc28 because it references libc/libm only through -lc and -lm which may be static or dynamic (I didn't test this). * shgen is not yet included (I didn't yet have enough time to integrate it). * I know about a few more configure-probs (esp. cross-checking --enable-* flags). + warn/refuse to configure when --enable-libcdir and --enable-gcc28 are given. + force --enable-libcdir when --disable-gcc28 is given * Replaced KSHELL with @KSH@ in some shell scripts generated by configure.in. * Added a dependency to aclocal/*.m4 in the toplevel Makefile => configure and aclocal.m4 will now be rebuild when any aclocal/*.m4 file is changed * Some changes to aclocal/gcc-pipe.m4 and aclocal/gcc-specs.m4 * Replaced i[[3456]]86-unknown-freebsd2.[[12]] with i[[3456]]86-*freebsd2.* in configure.in, as I suppose there might exist a variety of valid vendors (2nd field of the name-tripple) * Disabled override MAKEFLAGS in toplevel Makefile.in - Potential side-effects are not really clear to me. * In mvme162.cfg, $(LINK_LIBS) is missing in the CC line in gcc28's make-exe rule (yet another one I missed to edit). Just append $(LINK_LIBS) to the "CC" line, like I hopefully did to ALL other custom/*.cfg files. * the problem with mvme162lx.cfg is a follow-up problem of the mvme162.cfg-bug. * mvme162/console and idp/console had variables named Buffer which conflicted with similarly named variables in some tests.
