* custom/FreeBSD-posix.cfg: Remove LIBC_DEFINES (Meaningless
with FreeBSD and now unused).
* custom/Solaris-posix.cfg: Add -D__EXTENSIONS__ to CPU_CFLAGS.
* custom/ss555.cfg: New file.
* make/Cygwin-posix.cfg: Remove DEFINES + LIBC_DEFINES (Meaningless
with Cygwin and now unused).
* make/Linux-posix.cfg: Merge LIBC_DEFINES into CPU_CFLAGS.
* custom/p4650.cfg: Remove obsolete variables and get closer to gcc 3.x
support.
PR 570/bsps
* custom/mvme2307.cfg: Do not use -msdata=eabi since
it breaks the linking of the vectors.
* Makefile.am: Cosmetics.
* Makefile.am: dist_rtems_make_DATA = main.cfg leaf.cfg.
dist_rtems_make_custom_DATA = custom/default.cfg.
* custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Re-added
these -- copied from the 4.6 branch.
PR 553/bsps
* custom/mrm332.cfg: Comment out objdump.
* Makefile.am: Remove obsolete custom/*.cfg.
PR 553/bsps
* custom/mrm332.cfg: Use OBJDUMP variable and turn invocation into a
comment.
* Makefile.am: Remove efi68k and efi332 references as they are no
longer in the tree.
Per John S. Gwynne <jgwynne@mrcday.com>, there are no longer any
users of these boards so we are removing them.
* custom/efi332.cfg, custom/efi68k.cfg: Removed.
* custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Removed.
* Makefile.am: EXTRA_DIST +=.
* custom/Makefile.am: Remove.
* Makefile.am: Merge-in former custom/Makefile.am
* custom/HPUX9-posix.cfg: Remove INLINE, INLINE_UPCASE.
* custom/default.cfg: Remove INLINE,INLINE_UPCASE.
* custom/simhppa.cfg: Removed.
PR 470/bsps
* custom/mcp750.cfg, custom/mtx603e.cfg, custem/mvme2307.cfg (make-exe):
Rearrange arguments in calls to OBJCOPY to $(OBJCOPY) options infile outfile.
(Reported for mcp750.cfg by Andrew Harris <Andrew.Harris@jhuapl.edu>).
PR 470/bsps
* custom/mvme167.cfg: Remove PRINTK_MINOR, CONSOLE_MINOR (move to
the BSP's configure-script).
Remove BSP_CPPFLAGS (Obsolete).
PR 321:
* leaf.cfg: Remove support for profile-variant.
* main.cfg: Ditto.
* compilers/gcc-no_bsp.cfg: Ditto.
* compilers/gcc-portsw.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* custom/mvme2307.cfg: Remove CFLAGS_PROFILE_V.
PR 368/filesystems
* custom/mbx821_002.cfg, custom/mbx821_002b.cfg: New files included
with this PR for alias BSPs.
PR 356/bsps
* custom/mvme2307.cfg: This patch makes RTEMS/PowerPC eabi compliant.
Enable EABI by adding -meabi -msdata=eabi CFLAGS.
AMD a29k obsolete.
* custom/portsw.cfg: Removed.
* custom/m2m332.cfg: Fix path to linkcmds_ROM.
* custom/Cygwin-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
* custom/FreeBSD-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
* custom/HPUX9-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
* custom/Linux-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
Move -D_BSD_SOURCE to CPU_CFLAGS.
* custom/Solaris-posix.cfg: Remove WORKSPACE_MB and HEAPSPACE_MB.
Move -Dsolaris2 to CPU_CFLAGS.
Remove -D__EXTENSIONS__.
* custom/posix.cfg: Remove comment referring to host.cfg.
* custom/default.cfg: Pickup target.cfg from BSP directory.
* custom/mtx603e.cfg: New file.
* leaf.cfg, main.cfg, compilers/gcc-target-default.cfg: Make
build variants work for user applications post install.
* custom/Cygwin-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/Linux-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/Solaris-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/FreeBSD-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/HPUX9-posix.cfg: Remove -DRTEMS_UNIXLIB -DRTEMS_UNIX.
* custom/edb7312.cfg: New file.
* custom/default.cfg: Remove RTEMS_BSP_SPECS. Remove reference to
obsolete Makefile.
* leaf.cfg: Various changes to LIBVARIANT processing.
* main.cfg: Ditto.
* Makefile.am: Add compilers/*.
* compilers/Makefile.am: Remove.
* lib.cfg: Remove.
* directory.cfg: Remove.
* README: Remove.
* Makefile.am: Add Templates/*.
* Templates/Makefile.am: Remove.
* custom/Cygwin-posix.cfg: Remove obsolete comment on RTEMS_LIBC_DIR.
* custom/FreeBSD-posix.cfg: Remove obsolete comment on RTEMS_LIBC_DIR.
* custom/HPUX9-posix.cfg: Ditto.
* custom/Linux-posix.cfg: Ditto.
* custom/armulator.cfg: Remove reference to PowerPC arguments.
* Part of addressing PR281.
* main.cfg: Added recognition of VARIANT=DEBUG on command line.
* compilers/gcc-target-default.cfg: Removed remaining support for
RTEMS_USE_GCC272 and RTEMS_LIBC_DIR as well as added -qrtems_debug
as one of the LDFLAGS when the debug variant is specified.
* custom/posix.cfg: Don't include host.cfg.
* custom/gen405.cfg: Corrected make-cxx-exe rule to use LINK.cc.
* orp.cfg: Bender BSP renamed to OpenRisc Reference Platform or ORP.
* custom/vegaplus.cfg: Fix bogus and corrupted make-exe.
