path: root/make (follow)
* 2001-10-22 Andy Dachs <a.dachs@sstl.co.uk>Joel Sherrill2001-10-222-0/+119
| | | | * custom/mpc8260ads.cfg: New file.
* 2001-10-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-153-13/+6
| | | | | * custom/gensh4.cfg: Remove START_HW_INIT. * custom/simsh4.cfg: Remove START_HW_INIT, RTEMS_CPU_MODEL=sh7750.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-123-4/+5
| | | | | * custom/gensh4.cfg: Remove HZ. * custom/simsh4.cfg: Remove HZ.
* 2001-10-11 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-113-0/+159
| | | | | | * custom/gensh4.cfg, custom/simsh4.cfg: New files in support of Hitachi SH4 BSPs of the same name. Reviewed and some cleanup by Joel Sherrill <joel@OARcorp.com>.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-2/+5
| | | | * custom/gensh2.cfg: Remove -lstdc++ from make-exe.
* 2001-10-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-113-4/+13
| | | | | * custom/mbx8xx.cfg, custom/mvme167.cfg: Rewrote use of strip command to avoid using the apparently broken or deprecated -o argument.
* 2001-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-282-0/+13
| | | | | * custom/ods68302.cfg: Add custom make-cxx-exe rule to account for MC68302_BASE.
* 2001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-0/+10
| | | | * custom/bare.cfg: Define dummy make-cxx-exe.
* 2001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-5/+9
| | | | | * custom/gensh2.cfg: Remove -lstdc++ from make-exe. * ChangeLog: Formatting cleanup.
* 2001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-212-15/+19
* 2001-09-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-141-1/+1
| | | | | | | | | | * aclocal/canonical-target-name.m4: Use AC_CANONICAL_TARGET instead of AC_CANONICAL_SYSTEM. * aclocal/config-subdirs.m4: Use AS_MKDIR_P instead of mkinstalldirs and mkdir. * aclocal/target.m4: Obsolete RTEMS_OUTPUT_BUILD_SUBDIRS, hack RTEMS_CONFIG_BUILD_SUBDIRS, introduce _RTEMS_OUTPUT_BUILD_SUBDIRS.
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-1915-72/+18
| | | | | | | | | | | | | | | | | custom/Cygwin-posix.cfg: Remove -U__STRICT_ANSI__, make-target-options. custom/FreeBSD-posix.cfg: Remove make-target-options. custom/HPUX9-posix.cfg: Dito. custom/Linux-posix.cfg: Dito. custom/Solaris-posix.cfg: Dito. custom/arm_bare_bsp.cfg: Dito. custom/armulator.cfg: Dito. custom/erc32.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/i386ex.cfg: Remove make-target-options. custom/i960sim.cfg: Remove make-target-options. custom/mvme2307.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/rxgen960.cfg: Remove make-target-options, cleanup comments. custom/score603e.cfg: Remove CONSOLE_USE_POLLED, CONSOLE_USE_INTERRUPTS. custom/vegaplus.cfg: Remove make-target-options.
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-252-2/+6
| | | | * custom/mrm332.cfg: Switched $(SED) to sed.
* 2000-05-25 Matt Cross <profesor@gweep.net>Joel Sherrill2001-05-251-0/+93
| | | | | | | | | | | | | | | | | * New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * .cvsignore, ChangeLog Makefile.am, README, bsp_specs, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in, console/.cvsignore, console/Makefile.am, console/console.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c, spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c, start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore, startup/Makefile.am, startup/bspclean.c, startup/bspstart.c, startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM, timer/.cvsignore, timer/Makefile.am, timer/timer.c, times, wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
* 2000-05-25 Matt Cross <profesor@gweep.net>Joel Sherrill2001-05-251-0/+7
| | | | | | | * New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * custom/mrm332.cfg: New file.
* 2001-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-242-11/+5
| | | | | * custom/dmv177.cfg: Remove CONSOLE_USE_INTERRUPTS, CONSOLE_USE_POLLED, HAS_RTC.
* 2001-05-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-113-12/+5
| | | | | * custom/gensh1.cfg: Remove HZ, BSP_CPPFLAGS. * custom/gensh2.cfg: Dito.
* 2001-05-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-087-27/+15
| | | | | | | | | | * leaf.cfg: Remove CFLAGS_DEBUG_OPTIMIZE_V. * compilers/gcc-no_bsp.cfg: Remove CPP_CC_FLAGS. * compilers/gcc-portsw.cfg: Remove CPP_CC_FLAGS. * compilers/gcc-target-default.cfg: Remove *_DEBUG_OPTIMIZE_*-flags, remove unused flags, remove -ansi from CPP. * custom/eth_comm.cfg: Remove CPU_DEFINES. * custom/sim68000.cfg: Remove CPU_DEFINES.
* 2001-04-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-04-266-7/+12
| | | | | | | | * compilers/gcc-no_bsp.cfg: Remove -ansi -fasm. * compilers/gcc-default.cfg: Dito. * compilers/gcc-portsw.cfg: Remove -Hansi. * custom/posix.cfg: Remove inclusion of target.cfg. * custom/simhppa.cfg: Remove -ansi -fasm.
* 2001-04-11 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-04-112-0/+6
| | | | | * custom/eth_comm.cfg: Switch the eth_comm BSP to use the "new exception processing model."
* 2001-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-112-2/+7
| | | | | * custom/default.cfg: Switch to using exec_prefix to reflect new organization of install point from Ralf Corsepius.
* 2001-03-30 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-04-062-4/+14
| | | | | * custom/mbx860_005b.cfg: This switches the MBX8xx BSP to the use the "new exception processing model."
* 2001-03-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-142-0/+57
| | | | * custom/genmongossev.cfg: New file.
* 2001-02-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-03-011-2/+2
| | | | | | | | * configure.in: Reworked for Canadian Cross support. * Makefile.am: Reflect changes to configure.in. * config.guess, config.sub: Update from subversions.gnu.org. * README.cdn-X: New file. * tools/Makefile.am: Remove build, tools from SUBDIRS.
* 2001-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-212-0/+15
| | | | * custom/pc386dx.cfg: New bsp.
* 2001-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-126-23/+6
| | | | | | * custom/Cygwin-posix.cfg, custom/HPUX9-posix.cfg, custom/Solaris-posix.cfg, custom/FreeBSD-posix.cfg, custom/Linux-posix.cfg: Remove RTEMS_UNIX from make-target-options.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-054-24/+7
| | | | | | | * lib.cfg: include $(PROJECT_ROOT)/make/leaf.cfg * main.cfg: Set PROJECT_RELEASE=$(exec_prefix)/$(RTEMS_BSP). * host.cfg.in: Remove RM, make-script. * ChangeLog: Remove bogus 2001-01-22 entry.
* 2001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-224-12/+72
| | | | | * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and simsh7045.
* 2001-01-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-092-10/+5
| | | | | * custom/pc386.cfg (make-exe): Removed commented out lines that were displayed in build longs.
* 2001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-084-10/+27
| | | | | | * custom/p4000.cfg, custom/p4600.cfg, custom/p4650.cfg: Remove unneeded definitions when compiled for "mips" rather than "mips64orion." Correct CPU_CFLAGS.
* 2001-01-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-052-2/+7
| | | | | * custom/gensh1.cfg: Removed rest of make-target-options and moved them to BSP configure options.
* 2001-01-03 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2001-01-032-13/+15
| | | | | * custom/mcp750.cfg (make-exe): Rewrite to avoid writing to install point or assuming BSP build tree is available.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-032-14/+4
| | | | * custom/psim.cfg: Removed unused variables.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-033-2/+6
| | | | | * custom/sim68000.cfg: Corrected CPU model for simcpu32 configuration. * custom/simcpu32.cfg: Removed MVME162 reference.
* 2000-12-14 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2000-12-142-3/+8
| | | | | * custom/mcp750.cfg: Fix problems in generation of .exe file. Still need to fix to avoid touching install point on non-install stanza.
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-062-6/+11
| | | | | * custom/vegaplus.cfg: Fix make-exe rule and eliminate mkdir and copies that should not be in it.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-012-1/+5
| | | | * custom/jmr3904.cfg: Turn optimization back up to -O2.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-302-2/+7
| | | | | * custom/jmr3904.cfg: Use -m3900 not -mips3. TX3904 is actually a mips1. gcc translates -m3900 into that.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-272-1/+5
| | | | * custom/jmr3904.cfg: Fix incorrect reference to i960.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-273-2/+64
| | | | | | | | * custom/shsim.cfg: New file. * custom/Makefile.am: Modified to reflect addition of shsim.cfg. The shsim is for the SH simulator in gdb. It should be able to be used with multiple SH CPU models. This will require adding BSP variants.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-252-25/+33
| | | | | | | | * custom/pc386.cfg: make-exe rule would write into $(PROJECT_RELEASE) area. This is not cool because it $(PROJECT_RELEASE) is generally not writeable after the BSP is installed and you do not want every application installed there by default. Reported by Eric Norum <eric.norum@usask.ca>.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-253-2/+60
| | | | | * custom/Makefile.am: Updated to add jmr3904.cfg * custom/jmr3904.cfg: New file.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-152-13/+5
| | | | | * custom/leon2.cfg: Removed defines that are now generated in a non-BSP specific manner.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-136-7/+149
| | | | | | * custom/Makefile.am: Modified to reflect addition of files. * custom/erc32.cfg: Modified to support addition of no-FP ERC32 variant. * custom/erc32nfp.cfg, custom/leon1.cfg, custom/leon2.cfg: New file.
* 2000-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-102-1/+5
| | | | * custom/Cygwin-posix.cfg: Add -U__STRICT_ANSI__ to LIBC_DEFINES.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-272-3/+7
| | | | * custom/bare.cfg: Add @ to make-exe, make make-exe more verbose.
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-253-2/+11
| | | | | | | * custom/p4600.cfg, custom/p4650.cfg: Commented out RTEMS_CPU definition since this information can be picked up from autoconf generated files. These BSPs are shared by the mips and mips64orion "ports."
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-182-1/+6
| | | | * compilers/gcc-portsw.cfg: Use gcc style flags.
* 2000-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-136-80/+8
| | | | | * custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/dmv177.cfg, custom/mcp750.cfg, custom/vegaplus.cfg: Clean up.
* 2000-09-13 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2000-09-132-0/+101
| | | | | | * vegaplus BSP submitted by Emmanuel Raguet <raguet@crf.canon.fr> and Eric Valette <valette@crf.canon.fr>. * custom/vegaplus.cfg: New file.
