I have managed to build the bsp ods68302 and the rtti test case I made
with egcs-1.1b and binutils-2.9.1.
I have built our C++ application and got no link errors so it looks like
this is now working. I am yet to test the code but getting the thing to
link was the problem.
Please find a patch attached which removes the -fno-rtti option.
The patch (rtems-rc-980821.diff) I had sent recently to fix the "make
install" problem in rtems-980821/make/ still contained a bug (Thanks to
Eric N. for reporting it).
The patch enclosed to this mail is a corrected version of this patch,
which finally should fix this problem.
Here is another patch to hopefully enhance rtems' configuration.
Motivation: Try to support other c-compilers besides gcc (I tried to
build rtems under Solaris using sun's WSPro c-compiler).
Here is a couple of small patches concerning the host compiler
configuration, which fix/work-around the worst problems when using sun's
WSPro c-compiler.
* Replaced make/compilers/gcc.cfg with make/compilers/gcc.cfg.in, ie.
gcc.cfg is generated by configure now.
* Removed a line containing a hard-coded "gcc" from gcc.cfg (BUG-fix).
* Add -g to host compiler flags only if configure reported -g to work
* Add -Wall to host compiler flags only if configure reported that the
host compiler is gcc (WSPro's cc chokes on -Wall).
* Some modifications to make/Makefile.in
* Adapted make/custom/default.cfg to the new location of gcc.cfg
BTW, gcc.cfg/gcc.cfg.in seems to be full of unused code (DEBUG-VARIANTS
etc.) which deserves to be cleaned up, IMO.
IMO, a similar patch should be applied to gcc-target-default.cfg
It fixes netboot build problem, KA9Q configuration
for pc386, some compiler wardning, it also removed some stuff
ifdef'ed with '#if 0'.
BSDINSTALL=@INSTALL@
in autoconf.
fixed.
CPU_ASFLAGS.
<raguet@crf.canon.fr> to make their patches work together.
Here is a patch for KA9Q stack.
This patch contains an Ethernet Driver for Western Digital,
some fixes for the UDP and TCP protocols (for endian conversion)
and some little programs which allow the test of UDP and TCP
sockets via Ethernet.
I have tested that on an Intel machine. If someone can test it
on a big-endian machine, ...
sources files.
TARGET_VARIANTS
NOTE:
FINALLY:
to each Makefile.in.
Changes to make/custom/gensh1.cfg. Needed for shgen support
Switched PPC_USE_SPRG to "0" so RTEMS use of sprg would not conflict with
any possible sprg usage by the DY-4 ROM monitor.
<corsepiu@faw.uni-ulm.de> and his comments are below:
Joel, obviously you did apply my previous patch to
gcc-target-default.cfg -- This should have been gcc.cfg
(gcc-target-default.cfg should NOT contain any EXEEXT).
> It seems that rules for %{EXEEXT} don't exist in gcc-target-default.cfg
No, gcc-target-default.cfg is used to compile executables for the target
only, not for the host.
EXEEXT may only be used for programs to be run on the host.
> What should I add please?
This was a bug in my initial configuration patch to rtems-980616. A
correction to this patch I had sent to Joel at 26.06.98 doesn't seem to
have made it into the snapshot.
Please find attached the patch I had sent to Joel, hopefully this patch
fixes this problem.
read from and write to a floppy.
Geoffroy Montel <g_montel@yahoo.com>.
I had trouble merging his original patch and this corrected a reject.
<qqi@world.std.com>). Unfortunately after merging these,
the pc386 will not boot using grub for for. It still does not
work using netboot for me. Here is his summary of changes:
rtems/c/src/lib/libbsp/i386/pc386/Makefile.in
Added support for new sub-directory
rtems/c/src/lib/libbsp/i386/pc386/bsp_specs
Made possible to build COFF image
rtems/c/src/lib/libbsp/i386/pc386/console/console.c
Added support for serial consoles, selectable by patching
binary image, added __assert(), use _IBMPC_inch_sleep()
instaed of _IMBPC_inch()
rtems/c/src/lib/libbsp/i386/pc386/console/inch.c
Added _IMBPC_inch_sleep()
rtems/c/src/lib/libbsp/i386/pc386/console/outch.c
Oops - just formatting
rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in
Added support for new files
rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h
Added support for new features
rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h
New file: definitions for serial ports
rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h
New file: definitions for PCI BIOS
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in
New file: makefile in new directory
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c
New file: i386-stub interface
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c
New file: i386-stub itself
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c
New file: serial ports
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c
New file: PCI BIOS support
rtems/c/src/lib/libbsp/i386/pc386/start/start.s
Commented out DEBUG_EARLY stuff, everything is working fine
rtems/c/src/lib/libbsp/i386/pc386/start/start16.s
Cleaned up
rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
Added call to console_resereve_resources
rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c
rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s
Fixed typo in comments
rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in
Changed to reflect cnages in code
rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
Trivialized, problem - I do not know how to make patch
remove obsolete files - there are a lot of them there
rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c
New file: utility to do binary patches
rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in
Added support for new directory
rtems/make/custom/pc386.cfg
Add COFF image building
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
Cleaned up command line macro definitions.
Per patch from Ralf Corsepius UNIX ports always needs C++ for rtems-ctor.cc.
build. It does not link successfully for him. It does not compile
for me locally.
lets the makefile work in both cases.
Added CROSS_TARGET conditionals so unix port can share this file.
