* Makefile.am: New Gumstix BSP.
* custom/gumstix.cfg: New file.
* custom/csb637.cfg: New file.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
* custom/simsh2e.cfg: New file.
PR 1371/bsps
* custom/mvme167.cfg: mvme167 needs to convert ELF -> pure binary RALF.
* custom/uC5282.cfg: Add cvs Id.
* custom/h8sxsim.cfg: Small H8SX should be optimized for size.
* Makefile.am: Regenerate list of custom/*.cfg.
* Makefile.am: Remove custom/HPUX9-posix.cfg.
* custom/HPUX9-posix.cfg: Remove.
* custom/pck6.cfg: Remove.
* Makefile.am: Add Lattice Mico32 support.
* custom/lm32_evr.cfg: New file.
* custom/avrtest.cfg: New file.
PR 1337/bsps
* custom/pc386.cfg: Stripping .rodata section produces unusable
executables for the i386-rtems target.
* Makefile.am: Add h8sxsim BSP variant.
* custom/h8sxsim.cfg: New file.
* custom/m32rsim.cfg: New file.
* custom/m32csim.cfg: New file.
* custom/virtex.cfg: Remove -Dvirtex.
* custom/pghplus.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg:
Remove RTEMS_TQM_MODEL.
* custom/mpc5566evb.cfg, custom/mpc55xx.cfg: Remove
RTEMS_BOARD_MODEL.
* custom/pgh360.cfg: Remove RTEMS_BOARD_MODEL.
* custom/m5484FireEngine.cfg: Remove RTEMS_BOARD_MODEL.
Remove RTEMS_54XX_DERIVATE (Unused).
* custom/genmcf548x.cfg: Remove RTEMS_BOARD_MODEL.
* custom/brs5l.cfg, custom/gen5200.cfg, custom/icecube.cfg,
custom/pm520_cr825.cfg, custom/pm520_ze30.cfg: Remove RTEMS_BOARD_MODEL.
* custom/gen83xx.cfg, custom/hsc_cm01.cfg, custom/mpc8313erdb.cfg,
custom/mpc8349eamds.cfg: Remove RTEMS_BOARD_MODEL,
RTEMS_83XX_DERIVATE.
* custom/erc32.cfg: Revert accidental commit.
* custom/brs5l.cfg, custom/gen5200.cfg, custom/gen83xx.cfg,
custom/genmcf548x.cfg, custom/hsc_cm01.cfg, custom/icecube.cfg,
custom/m5484FireEngine.cfg, custom/mpc5566evb.cfg,
custom/mpc55xx.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg,
custom/pgh360.cfg, custom/pghplus.cfg, custom/pm520_cr825.cfg,
custom/pm520_ze30.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg:
Back out parts of yesterdays changes.
* custom/gen83xx.cfg, custom/lpc2478.cfg: Remove warning flags.
* custom/score603e.cfg: Modifications required to run on hardware. Some
cleanup.
Eliminate RTEMS_54XX_DERIVATE (Unused).
Eliminate RTEMS_TQM_MODEL (Unused).
custom/lpc2478.cfg, custom/m5484FireEngine.cfg,
custom/mpc5566evb.cfg, custom/mpc55xx.cfg, custom/mpc8313erdb.cfg,
custom/mpc8349eamds.cfg, custom/pgh360.cfg, custom/pm520_cr825.cfg
* custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh4.cfg: Make all use
RTEMS_BSP_FAMILY.
* custom/simsh1.cfg, custom/simsh2.cfg: Remove Author notice.
* Makefile.am, custom/simsh4.cfg: Recognize the the GDB SuperH
simulator is just an architectural simulator and does not include
devices. Rename existing simulator BSP configurations to simsh1 and
simsh2 and add simsh4.
* custom/simsh1.cfg, custom/simsh2.cfg: New files.
* custom/shsim.cfg, custom/simsh7032.cfg, custom/simsh7045.cfg: Removed.
