future.
cd <rtems-source-tree>
This is an attempt to work-around a couple of nasty bugs in librdbg's
Makefiles and configuration:
Configure and build RTEMS as below:
configure --enable-networking --enable-rdbg --target=i386-rtems
make RTEMS_BSP=i386ex
After a few minutes you will notice that building aborts in librdbg ....
Analysis:
1) librdbg is tried to be built, though librdbg is not supported and the
required directory hierarchy librdbg/i386/i386ex/ is not existant.
The cause for this is incorrect setting of HAS_RDBG in most
make/custom/*.cfg files (except pc386.cfg). At the moment all
custom/*.cfg files (except pc386.cfg) in general are required to contain
HAS_RDBG=no. However, having HAS_NETWORKING=no in most custom/*.cfg
files and the toplevel configure script suppress building librdbg for
all CPUs except of i386.
=> The i386ex BSP falls though this scheme and librdbg is tried to be
build (CPU=i386 and HAS_NETWORKING=yes).
2) The Makefile.ins below lib/librdbg in general support i386/pc386 only
and are not capable to be used for multiple CPUs or BSPs (RPCGEN
generates it's target and bsp-specific files into librdbg/, therefore no
other CPU or BSP can ever be built afterwards). This problem is hidden
until now, because only a single CPU/BSP pair (i386/pc386) is really
supported.
3) The Makefile.ins below lib/librdbg can delete source files due to
improper handling of source files (make clean removes the *.x files in
the source-tree when configuring inside of the source-tree).
The patch below tries to work-around these problems for the i386ex and
the pc386 BSPs. This work-around is rather fragile (it applies rpcgen
-D, I don't know how portable this is) and incomplete (all custom/*.cfg
except of pc386.cfg should contain HAS_RDBG=no), nevertheless it should
FYI: I am not talking about using "make -C <dir>", which probably
is much faster on M$ hosts than RTEMS's implementation, but about
removing --enable-gmake-print support and to apply a variant of
automake's subdirectory.
Automake's subdirectory rule seems to be a little bit faster, but I
wouldn't bet on this.
Attached to this mail is my proposal.
After applying the patch, please run
cvs rm aclocal/enable-gmake-print.m4
Installing of bsp_specs for aliased bsps is broken. Instead of installing
RTEMS_BSP_FAMILY/bsp_specs, RTEMS_BSP/bsp_specs was tried to be installed.
The patch below should fix this problem (tested with mips64orion p4600 and
p4650).
releasing a snapshot:
1. Cleanup to aclocal/
cvs rm -f aclocal/cygwin.m4
cvs rm -f aclocal/exeext.m4
2. rtems-rc-19990328-0.diff
Some (minor) bug-fixes:
3. rtems-rc-19990328-1.diff
-ac -am -ci.
(reduces size of configure.in
With my most recent automake patch (automake II) we could even simplify more
files below make/, because the host-compiler related parts of those files
aren't used anymore :-.
Whatsoever, the patch below should fix this problem.
Note: This is a mere bug fix, it doesn't move any of the variables involved
to target.cfg nor does it try to eliminate any variable.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
This is the next step towards automake:
* Two scripts for the toplevel directory:
a) "autogen" (Idea borrowed from libtool and gnome) A helper script to
recursively regenerate autoconf/automake/aclocal generated files
(Still not perfect but sufficient).
b) "missing" (from automake-cvs archive). This file normally is
automatically generated by automake, but we have to manually add
it until we add automake support to the toplevel configure script.
"chmod 755 missing autogen" after applying the patch.
* Changing the toplevel installation directory [ I can hear you
falling off the chair ;-]
Until now rtems installed itself to $(prefix)/rtems. This is in
contradiction to automake and GNU/FSF/Cygnus conventions.
With this patch applied, rtems installs into $(prefix).
To achieve the old behaviour simply configure with
--prefix=<install-dir>/rtems instead of --prefix=<install-dir>
This is a widely visible change and I can understand if you don't
like it at the present point. It enables us to use automake's
default installation paths instead of having to set up installation
paths manually. At the moment this doesn't help much, but in the not
so far future this would enable us to mix cpu-only dependent libraries
into the host's cross-compiler library and header files into
newlib's include directories, tools into the toolchain directories etc.
I would recommend to change the main installation directory, however it's
up to you to draw the final design decision.
are:
problems that prevented the 19990302 snapshot from running on
the efi332.
I'm happy to report that rtems-19990302 is running on the efi332
board. I have enclosed a few minor patches below to the efi332 bsp. All
patches are within that library but one. make/custom/efi332.cfg has a
patch to select the right CPU_CFLAGS (at one time -m68332 was a
problem... -mcpu32 or -m68332 work fine now).
FP issues on this target:
The default variants of libc, libm and libgcc assume that a 68881
coprocessor is present. Without the FPSP, any floating point operation,
including printf() with a "%f" format specifier, is likely to cause an
unimplemented instruction exception.
The FPSP works with the default variants of libc, libm and libgcc. It does not
work in conjunction with the msoft-float variants. The paranoia test goes into
an infinite loop at milestone 40. I am guessing that floor() is returning an
incorrect value.
The msoft-float variants of libc, libm and libgcc appear to do floating point
I/O properly. They only failed in paranoia. Offhand, I can't think of why they
would conflict with the FPSP, so I think that there is something wrong with the
msoft-float code. It might be my installation.
Given my experiences, I decided to install the FPSP in bsp_start(), and to link
against the default variants of libc, libm and libgcc. This causes the
executables to increase in size by about 60 KB. The README file and the
mvme167.cfg specify how to remove the FPSP, and how to link against the
msoft-float variants of the libraries. This is not what Eric Norum had done: on
my host, his gen68360_040 port links RTEMS code with the msoft-float variants
of libc and libm, and the default variant of libgcc. In this configuration, the
output of printf() with "%f" is garbage on my target.
is long but I hate to lose the information so I am including it here.
> I am still fixing and recompiling but this is the issue that was not the
> result of another patch. This is a fundamental build issue that I value
> your opinion on.
This is difficult issue (I.e. I have no destinct solution for it)
Background:
(gnu-) make's implicit rules apply CFLAGS, CPPFLAGS, CXXFLAGS, ASFLAGS and
LDFLAGS (cf. make.info/Implicit Rules/Catalogue of Rules), only.
In brief:
CPPFLAGS .. passed to the c-preprocessor
CFLAGS ... passed to the c-compiler
CXXFLAGS ... equivalent to CFLAGS but passed to the c++ compiler
(Attention: CFLAGS is not passed to the c++ compiler)
ASFLAGS .. equivalent to CFLAGS, but passed to the assembler
LDFLAGS .. equivalent to CFLAGS, but passed to the linker
A bit oversimplifying, these make rules are as follows
.c.o:
$(CC) $(CPPFLAGS) $(CFLAGS) -c
.cc.o:
$(CXX) $(CPPFLAGS) $(CXXFLAGS) -c
.S.s:
$(CPP) $(CPPFLAGS)
.s.o:
$(AS) $(ASFLAGS)
My reading of the documentation (make.info) is that {AS|AR|CC|CXX|CPP}FLAGS
are ment to be passed to the related tools directly, however examinating
the rule set of gmake (gmake -p -f /dev/null") shows that many rules use
$(CC) instead of the related tools (eg. linker rules) etc.
I.e. these flags should not rely on being passed through cpp or gcc. With
gcc being the common frontend for all of these tools of a gnu-toolchain the
situation becomes difficult (Which option is passed to whom and which tool
really uses it?), because these variable can also contain the toolchain's
frontend (eg. AS=gcc, LD=gcc, CPP=gcc -E).
For some commonly used options the situation is quite clear:
* -g -> CFLAGS
* -OX -> CFLAGS
* -D -> CPPFLAGS
* -A -> CPPFLAGS
But where to add -m, -B, -specs, -qrtems_XXX ?
* -B, -specs, -qrtems_XXX are gcc-frontend options
* -m is a combinations of flags to go to different destinations, in many
(all?) cases, the following is valid
-m is expanded by gcc into a set of -D and -A options
-m is interpreted by cc1 as a machine flag to generate a specific
instruction set.
-m is interpreted by gcc as an implicit linker search path for multilibs to
set up calls to LD.
>From my point of view this indicates we can either destingush between these
different usages (= separately add -m to CFLAGS, LDFLAGS etc) or to add it
to CPPFLAGS and use gcc (the frontend) instead of calling each tool
directly (less error prone) -- I vote for CPPFLAGS, but I am not sure.
Now, where to add CPU_CFLAGS?
AFAIS, in probably all cases CPU_CFLAGS contain -D -A, and -m options,
only.
* -D and -A are supposed to go to CPPFLAGS
* -mXXX options can have multiple meanings (It can be gcc, collect2/ld and
cc1/cc1plus option simultaneously)
Here, I made a mistake - I destinguished between CPU_DEFINES to be added to
CPPFLAGS and CPU_CFLAGS to be added to CFLAGS and CXXFLAGS (cf.
gcc-target-default.cfg), generally assuming CPU_CFLAGS are CFLAGS.
This breaks preprocessing *.S into *.i files because CPU_CFLAGS flags were
not added to CPPFLAGS. Hence *all* *.S were compiled without taking
-mXX-flags into account. The i960/cvme BSP was the only one which
explicitly checked for a specific -m flag (-mca) and refused to compile
without it -- all other CPUs/BSPs silently swallowed this.
IMO, we can either
1) add CPU_CFLAGS and CPU_DEFINES to CPPFLAGS, thus silently convert
CPU_CFLAGS's meaning into CPU_DEFINES (Alternative solution: rename
CPU_CFLAGS to CPU_DEFINES and merge CPU_FLAGS with CPU_DEFINES).
or
2) destinguish between CPU_DEFINES and CPU_CFLAGS. In this case we would
need to check the contents of each CPU_CFLAGS in custom/*.cfg and move the
some parts of the contents to CPU_DEFINES and keep other parts in
CPU_CFLAGS (CFLAGS must contain options for the c/c++-compiler only!).
Though Solution 2) is the clearer one, I implemented 1) which is the
simplier one (the patch below).
ATTENTION: This patch is small in size, but affects almost everything.
Additional complications araise with linking:
Some BSPs call LD and AS directly (esp. gcc-2.7 make-exe rules). If LD=gcc
then LDFLAGS are supposed to be gcc-options, but if LD=ld then LDFLAGS is
supposed to contain ld-options.
An analog thought is valid for AS, but luckily enough ASFLAGS is not used
of inside the whole source tree.
Most RTEMS' custom/*.cfg use $(CC) $(CFLAGS) to link with gcc-2.8 make-exe
rules. With the patch below (CPU_CFLAGS added to CPPFLAGS) this means
CPU_CFLAGS will not be passed to the linker, which is incorrect for
multilibbed CPU's.
gmake's default rule set contains a variety of rules for linking, all
ending up in calling $(CC) $(LDFLAGS) for linking at their very end.
IMO, this means we should use something like
LINK.o = $(CC) $(LDFLAGS) in gcc-target-default.cfg
+ modify all gcc-2.8 make-exe rules to use
$(LINK.o) .......
+ setup LDFLAGS according to the requirements of the above.
I.e. we should use $(CC) for linking instead of calling the linker (LD)
directly and set LDFLAGS = $(CPPFLAGS) $(CFLAGS) or similar.
> 3) rtems-rc-19990131-2.diff
> now)
> patches will apply then ;-.
> 2) rtems-rc-19990131-1.diff
> Rework of compilers/*.cfg files (esp. gcc-target-default.cfg) to adapt
> the flags/makefile variables to automake and make standards (cf.
> make.info - implicit rules/variables).
> This patch is rather risky and may probably break things, but is an
> essential step towards automake.
> FWIW: It also reverts the i386-ASMFLAGS/ASFLAGS-patch, which was wrong,
> as I had to experience ;-.
> Adds variables to the custom/*cfg files to specify the location of
> tools. The purpose is to remove hard-coded paths from the Makefiles.
> In later steps this eases moving the tools to other locations.
<corsepiu@faw.uni-ulm.de>.
./clock/clock.c,v
./console/Makefile.in,v
./console/config.c,v
./console/console.c,v
./console/console.h,v
./console/debugio.c,v
./console/i8042.c,v
./console/i8042_p.h,v
./console/i8042vga.c,v
./console/i8042vga.h,v
./console/ns16550.c,v
./console/ns16550.h,v
./console/ns16550_p.h,v
./console/ns16550cfg.c,v
./console/ns16550cfg.h,v
./console/vga.c,v
./console/vga_p.h,v
./console/z85c30.c,v
./console/z85c30.h,v
./console/z85c30_p.h,v
./console/z85c30cfg.c,v
./console/z85c30cfg.h,v
./include/Makefile.in,v
./include/bsp.h,v
./include/chain.h,v
./include/coverhd.h,v
./include/extisrdrv.h,v
./include/nvram.h,v
./include/pci.h,v
./include/tod.h,v
./network/Makefile.in,v
./network/amd79c970.c,v
./network/amd79c970.h,v
./nvram/Makefile.in,v
./nvram/ds1385.h,v
./nvram/mk48t18.h,v
./nvram/nvram.c,v
./nvram/prepnvr.h,v
./nvram/stk11c68.h,v
./pci/Makefile.in,v
./pci/pci.c,v
./start/Makefile.in,v
./start/start.s,v
./startup/Makefile.in,v
./startup/bspclean.c,v
./startup/bspstart.c,v
./startup/bsptrap.s,v
./startup/device-tree,v
./startup/genpvec.c,v
./startup/linkcmds,v
./startup/rtems-ctor.cc,v
./startup/sbrk.c,v
./startup/setvec.c,v
./startup/spurious.c,v
./startup/swap.c,v
./timer/Makefile.in,v
./timer/timer.c,v
./tod/Makefile.in,v
./tod/cmos.h,v
./tod/tod.c,v
./universe/Makefile.in,v
./universe/universe.c,v
./vectors/Makefile.in,v
./vectors/README,v
./vectors/align_h.s,v
./vectors/vectors.s,v
./wrapup/Makefile.in,v
./Makefile.in,v
./README,v
./STATUS,v
./bsp_specs,v
based board.
hack through some paths to check error checking paths without a network
driver.
of removal of unused function code found in newer binutils/egcs
snapshots. Early test with psim and hello.exe showed about a 13%
gain.
used in gcc.
Hello,
host :
- one for RTEMS it self,
- one for GDB-4.17.
1/ RTEMS patch
This patch adds 2 libraries :
- the Remote Debugger library
--enable-rdbg
rtems_rdbg_initialize ();
2/ GDB-4.17 patch
To connect to a target, use :
And... Debug ;)
it work.
I use the m68k/efi332 BSP together with a home made board. After some
time of debugging I found that the m68020 CPU is used to build rtems.
This is not correct, because the 68332 does not have some of the 68020
features (no separate int stack ...). It is necessary to change this to
mcpu32. After a clean/make everything works fine.
with libchip.
Please find attached a new i386ex.cfg. It has been altered to change
the files that get generated with the .nxe extension to .coff. This
change is necessary to align the file names generated by "make-exe" to
the those referred to in the GDB.HOWTO found in the
i386/shared/comm directory. It has been successfully tested on ticker (
without GDB), and base_sp( with GDB ) . I just set a breakpoint and
continue...
scripts (make/rtems.cfg)
Testing:
2. "make profile" doesn't work. It aborts when building host-tools
for embedded targets. I didn't yet have enough time to fix this
problem. AFAIS this problem is related to handling of
LDFLAGS_PROFILE[|_V] in gcc.cfg.in. For host applications, we use
gcc for linking host applications, too. With profiling enabled
CFLAGS_PROFILE_V contains -pg and is used to compile, but
LDFLAGS_PROFILE_V is empty, hence -pg will not be passed to the
linker causing gcc to fail to link, because it can't resolve some
symbols introduced by compiling with -pg.
I am not sure if I can provide a patch for this - Ether it is trivial
to fix or requires basic work on host configuration ;-
Fixing this one was trivial - But hard to trace.
LDFLAGS_PROFILE_V needs to contain the same flags as CFLAGS_PROFILE_V,
if gcc is used for linking (What else should have been expected ?,
:-). The same problem was present for *_DEBUG_V, but apparently wasn't
noticed by anybody, because things didn't break, but were silently
ignored.
I fixed these problems by setting these flags in configure.in whenever
gcc is reported to be the host-compiler. For non-gcc host compilers
"make debug" and "make profile" now becomes the same as an ordinary
"make". This is a hack and addressing this problen could be more
sophisticated, but I don't think it gives much sense to support
compile variants for any host program (Who will ever try to
profile/debug host tools?). Therefore I don't think it's useful
to invest more effort into this problem.
cosmetic things.
As mentioned in other mails before, there is are minor inconsistencies in the
posix custom/*cfg files.
Linux-posix.cfg sets RTEMS_BSP=posix
FreeBSD-posix.cfg sets RTEMS_BSP=posix
Solaris-posix.cfg first sets RTEMS_BSP=posix, later it sets
RTEMS_BSP=solaris2
1. Setting RTEMS_BSP=posix is redunant to settings in default.cfg
2. The solaris variant of setting RTEMS_BSP is merely non-functional.
The patch attached to this mail should clean up this issue.
The patch was tested by building the posix bsp under
i686-pc-linux-glibc1/glibc2 and Solaris2.6 (I did not run any
rtems program, however) The HPUX9 and FreeBSD configuration files
were adapted in analogy to the solaris and linux configurations.
Here's a patch to get rid of the `#define RTEMS__mcpu32p__ 1' when
gen68360.cfg is being used as a companion for gen68360_040.cfg. The
old version worked because of the order of the conditional tests in
m68k.h (the check for __mc68040__ is before the test for
RTEMS__mcpu32p__) , but I think it might have been a little confusing
to others just getting started.
Finally I am through: I have found the last bugs that made RTEMS-
4.0-beta3 start on my ppc403 board from ROM. So now the '403
support is up to date again.
Roughly I have added the following features:
- support for the on-chip interrupt controller (in a separate module)
- interrupt support for the console device
- termios support for the console device
Since the BSP behaivour changed in some details (console no
longer is polling, other memory layout etc) I have created a new
BSP "helas403" rather than changing the "papyrus" BSP. The old
"polled" console driver still sticks around in "console.c.polled"
To get the BSP up and running, I had to create the new BSP files
(derived from papyrus). Besides that, the following source areas
have been changed:
- c/src/lib/libcpu/powerpc/ppc403: changes to console driver, small
changes to clock driver, new "ictrl" interrupt controller driver
- c/src/exec/score/cpu/powerpc/ppc.h: some small changes
(added ppc403 characteristics like a exception vector prefix
register, some special register definitions). I am quite sure, they
are compatible with the existing sources, although I did not check
- c/src/exec/score/cpu/powerpc/cpu.c: There is one severe
limitation in the exception entries: Due to the current code
arrangement, the "branch absolute" to the ISR handler may only
jump to the first 128MByte or the last 128MByte of the 4GByte
address range. When the ppc403 is running out of ROM, the ROM
functions are located in the last 128MByte (0xFFF00000 and up).
These addresses were not handled correctly (sign reduced) in
"install_raw_handler". The change I added should work on existing
ppc BSPs aswell...
- c/src/lib/libc/termios.c: During my tests, I added one change you
sent me, so this patch will already be incorporated in the current
source tree.
There are some smaller changes, see the attached diff file.
Concerning the GNU toolchain:
I tried several tool chains. Finally I almost succeeded with
egcs-1.0.3a with patch egcs-1.0.3-rtems-diff-19980527
I had to add the following lines to the egcs files. Without them
configure complaint that the cross compiler could not generate
executable output.
- additional lines needed in egcs distribution in file
gcc/config/rs6000/rtems.h:
+++ lines start
#undef STARTFILE_DEFAULT_SPEC
#define STARTFILE_DEFAULT_SPEC "ecrti.o%s"
#undef ENDFILE_DEFAULT_SPEC
#define ENDFILE_DEFAULT_SPEC "ecrtn.o%s"
++++ lines end
As far as I have seen in the Changelog of egcs, you have recently
sent two patches affecting the powerpc support, but they were
added in the wrong order.... :-(
egcs-19980628 with patch egcs-19980628-rtems-diff-19980707 does
not work!
I used binutils 2.9.1 with patch binutils-2.9.1-rtems-diff-19980515
(binutils 2.8.1 does not work, internal error in gas)
and newlib-1.8.0 with patch newlib-1.8.0-rtems-diff-19980707
Finally I had to poke a line in the "bit" script, since, on my LINUX
machine, the GNU make is only available as "make", not as
"gmake"...
For all the tools and newlib I selected configuration "powerpc-
rtems".
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: td@imd.m.isar.de
I found that my 68040/68360 test programs would not run even after
I fixed the `wrong BSP' problem.
It seems that there's a bug in the interrupt handling code for
processors with hardware interrupt stacks (e.g. 68040). The wrong
status register was getting pushed on the stack for the `return
from exception' to call _ISR__Dispatch. This ended up making
the context switch code run on the interrupt stack, so interrupt-driven
context switches would always fail.
I guess that no one has tried running any of the RTEMS-4.0 snapshots
on a 68040 machine!
Anyhow, here are the patches for
1) gen68360.cfg --- to fix the `wrong-BSP' problem.
2) m68k/cpu_asm.s --- to fix the hardware interrupt stack problem.
With these patches in place, the network demo programs run on my
68040/68360 system. The paranoia program runs with no failures,
defects nor flaws.
1. Finally fixes raw interrupts for pc386
2. Makes some minor cleanup in console and startup
3. Makes rtems_termios_dequeue_characters() to return count of
outstanding chars - it allows to simplify console isrs a little
bit.
4. pc386 uart modified to be friendlier to termios parameter changes,
to have minor performance improvement and to take advantage of
of above termios modification.
