1998-06-25 | Added definition of RTEMS__mcpu32p__ per patch from Robin Kirkham. | Joel Sherrill | 1 | -0/+1 | |
1998-06-18 | New file from Dario Alcocer <alcocer@connectnet.com>. | Joel Sherrill | 1 | -0/+100 | |
1998-06-13 | Added PPC_USE_DATA_CACHE. | Joel Sherrill | 1 | -3/+8 | |
1998-06-09 | Added rule for .cxx and .cpp per suggestion from Geoffroy Montel | Joel Sherrill | 1 | -0/+6 | |
<g_montel@yahoo.com>. | |||||
1998-06-03 | Changed spacing | Joel Sherrill | 1 | -2/+0 | |
1998-06-03 | Changed BSP name to posix. | Joel Sherrill | 1 | -0/+1 | |
1998-06-03 | Changed ppc to PowerPC in comments. | Joel Sherrill | 2 | -6/+6 | |
1998-05-30 | Updated to current source and removed warnings. | Joel Sherrill | 1 | -17/+18 | |
1998-05-30 | New file -- from rtems-LM-980406 based on a 12/97 RTEMS snapshot. | Joel Sherrill | 1 | -0/+112 | |
1998-05-27 | Changed invocation of bin2boot to match gcc 2.8 rule. | Joel Sherrill | 1 | -1/+1 | |
1998-05-27 | Added names for C++ compilers. | Joel Sherrill | 1 | -0/+7 | |
1998-05-22 | Now uses BSP specific configure variables and compiles for i486 and m68k. | Joel Sherrill | 1 | -1/+8 | |
1998-05-22 | Renamed bare BSP specific options to make the dependency obvious. | Joel Sherrill | 1 | -3/+4 | |
1998-05-21 | Added bare bsp from Chris Johns <cjohns@plessey.com.au>. | Joel Sherrill | 3 | -0/+60 | |
1998-05-21 | Per patch from Ralf Corsepius removed redundant lines. | Joel Sherrill | 1 | -23/+0 | |
1998-05-21 | Removed undesirable space in TARGET_ARCH assignment line. | Joel Sherrill | 1 | -9/+4 | |
Cleaned up command line macro definitions. Per patch from Ralf Corsepius UNIX ports always needs C++ for rtems-ctor.cc. | |||||
1998-05-21 | Per patch from Ralf Corsepius UNIX ports always needs C++ for rtems-ctor.cc. | Joel Sherrill | 1 | -4/+0 | |
1998-05-20 | Some patches in place from Brian Stevens which help the Solaris port | Joel Sherrill | 1 | -7/+10 | |
build. It does not link successfully for him. It does not compile for me locally. | |||||
1998-05-20 | Copied gcc 2.7.2 style make-exe rule to gcc 2.8 conditional. This | Joel Sherrill | 1 | -1/+6 | |
lets the makefile work in both cases. | |||||
1998-05-20 | Changed CPP rule per patch from Ralf Corsepius. | Joel Sherrill | 1 | -1/+1 | |
1998-05-18 | Added much stuff formerly in multiple compiler files. | Joel Sherrill | 1 | -0/+27 | |
1998-05-18 | Added conditional around TARGET_ARCH to prevent accidental overrides. | Joel Sherrill | 1 | -0/+2 | |
1998-05-18 | Switched to using shared gcc-target-default.cfg. | Joel Sherrill | 3 | -12/+10 | |
1998-05-18 | Added C++ rule. | Joel Sherrill | 1 | -1/+22 | |
Added CROSS_TARGET conditionals so unix port can share this file. | |||||
1998-05-18 | Added RTEMS_CROSS_TARGET. | Joel Sherrill | 1 | -0/+2 | |
1998-05-04 | Modified objcopy to remove extra sections. | Joel Sherrill | 1 | -3/+6 | |
Modified gcc 2.8 style link rule to provide start address correctly. | |||||
1998-04-30 | Changed default target architecture name | Joel Sherrill | 1 | -1/+1 | |
1998-04-30 | Modified objcopy invocation to ignore more sections. | Joel Sherrill | 1 | -3/+7 | |
1998-04-27 | Update from Pedro Romano <pmcnr@camoes.rnl.ist.utl.pt>. | Joel Sherrill | 1 | -17/+31 | |
1998-04-27 | Fixes from Ralf Corsepius: | Joel Sherrill | 4 | -45/+21 | |
* Posix BSP configuration: Moved some rules from make/custom/*-posix.cfg files to make/custom/posix.cfg, Removed references to stdc++ from *posix.cfg files (rtems doesn't use/need libstdc++) NOTE: Building Posix-BSPs should now work again for native compilation with gcc, i..e. linux using primary compiler and primary libc. All Posix-BSP configurations that don't use gcc as primary compiler or don't use the primary libc don't work, e.g. solaris, linux w/ egcs as secondary compiler won't be built correctly. | |||||
1998-04-27 | Removed forced enable of POSIX API. Now follow configuration flag. | Joel Sherrill | 1 | -3/+0 | |
1998-04-27 | Fixed bad CVS Id string. | Joel Sherrill | 1 | -2/+1 | |
Removed unnecessary definition of "ED". | |||||
1998-04-15 | Stack checker now enabled via initial set of user extensions. This | Joel Sherrill | 26 | -124/+0 | |
eliminates the need to build the entire application with the STACK_CHECKER_ON macro defined. | |||||
1998-04-14 | Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵ | Joel Sherrill | 1 | -1/+2 | |
gcc-target-default.cfg | |||||
1998-04-14 | Ralf Corsepius suggested a way to get rid of UNIX compiler files and use ↵ | Joel Sherrill | 3 | -66/+230 | |
1998-04-14 | Stack checker on | Joel Sherrill | 1 | -6/+1 | |
1998-04-14 | Updates from PPC refresh | Joel Sherrill | 1 | -3/+33 | |
1998-04-14 | new file | Joel Sherrill | 1 | -0/+122 | |
1998-04-06 | Purged references to STACK_CHECKER_REPORT_USAGE | Joel Sherrill | 2 | -6/+1 | |
1998-04-06 | Purged references to STACK_CHECKER_REPORT_USAGE | Joel Sherrill | 22 | -113/+1 | |
1998-04-06 | Reordered CFLAGS definition so CFLAGS_DEFAULT is before | Joel Sherrill | 2 | -4/+2 | |
CFLAGS_$(TARGET_VARIANTS). This makes sure that -Wall appears before any individual warnings are disabled during "debug" builds. | |||||
1998-04-06 | Changed CPU model to mcpu32. | Joel Sherrill | 1 | -1/+1 | |
1998-04-03 | Added test so the build procedure would stop if a directory did not exist. | Joel Sherrill | 1 | -0/+2 | |
This typically indicates a bug in a directory level Makefile or a configure scrip bug. | |||||
1998-03-31 | Fixed CUSTOM_FILES rule so it properly picked up files included from | Joel Sherrill | 1 | -2/+11 | |
make/custom files. | |||||
1998-03-30 | Made the POSIX API option follow the configure line. | Joel Sherrill | 1 | -3/+1 | |
1998-03-30 | Made the HAS_POSIX_API follow the configure line option. | Joel Sherrill | 1 | -5/+0 | |
1998-03-30 | Made the C++ option follow the configure option. | Joel Sherrill | 1 | -9/+0 | |
1998-03-30 | Made HAS_POSIX_API have a "no" definition when it is not enabled. | Joel Sherrill | 1 | -0/+2 | |
1998-03-30 | Made C++ follow the configure option. | Joel Sherrill | 1 | -4/+0 | |
1998-03-24 | Changed RTEMS cpu to hppa1.1. | Joel Sherrill | 1 | -2/+1 | |
