path: root/make (unfollow)
2000-01-10Added pc486 and pc586 as aliases of pc386 with proper cpu flags.Joel Sherrill3-1/+26
2000-01-10Missed cleanup from Ralf Corsepius.Joel Sherrill2-8/+10
2000-01-10Removed reference to Radstone PPCN.Joel Sherrill1-6/+0
2000-01-10Fixed comment.Joel Sherrill1-2/+2
2000-01-07Renaming mcp750 to motorola_shared since that is the basis for bothJoel Sherrill2-5/+5
the mvme2307 and mcp750 BSPs. In addition, it can support many Motorola PowerPC based VME and PCI boards.
2000-01-07Patch rtems-rc-20000104-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-3/+3
which is described below: This one is a (minor) patch in preparation of the upcoming patches. It actually is an excerpt of the upcoming patches and therefore is completely untested in this standalone form, but I don't expect it to break something. The essential changes in this patch are: * An update to rtems-polish.sh (Now can also be run in subdirectories) * A bug-fix for the libcpu/powerpc (A directory was missing from SUBDIRS in a Makefile.am) * An update to gensh2.cfg. * Cleanups/Enhancements to configuration files To apply: cd <srcdir> patch -p0 < rtems-rc-20000104-0.diff cvs rm -f c/src/lib/libbsp/Makefile.am.new
1999-12-21Patch rtems-rc-19991203-5.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
which cleans up and merges some Hitachi SH-2 modifications from John Mills <jmills@tga.com>.
1999-12-13*** empty log message ***Joel Sherrill1-4/+4
1999-12-02Merged of mcp750 and mvme2307 BSP by Eric Valette <valette@crf.canon.fr>.Joel Sherrill2-1/+2
As part of this effort, the mpc750 libcpu code is now shared with the ppc6xx.
1999-12-01Patch rtems-rc-19991123-rc-1.diff from Ralf CorsepiusJoel Sherrill1-1/+4
<corsepiu@faw.uni-ulm.de> which implements automake support for some score/cpu/<RTEMS_CPU> subdirectories and fixes a few minor configuration bugs. To apply: rm -rf c/src/exec/score/cpu/i960/wrap rm -rf c/src/exec/score/cpu/m68k/wrap rm -rf c/src/exec/score/cpu/sh/wrap rm -rf c/src/exec/score/cpu/sparc/wrap rm -rf c/src/exec/score/cpu/unix/wrap patch -p1 < rtems-rc-19991123-rc-1.diff ./bootstrap Known bugs: * "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does not handle recursion to subdirectories correctly (recurses too often). However, this issue is hardly visible and should be tolerable for the moment.
1999-11-30Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-4/+4
which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working)
1999-11-23Patch rtems-rc-19991117-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill4-9/+15
* the PACKHEX etc problem * prevents the *.rels being removed inside the build-tree * a typo which only shows for when MP is activated * Alters some custom/*cfg files
1999-11-23Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-6/+6
that are part of the Makefile.am conversion effort but were missed in the previous commits.
1999-11-22Removed need for START_BASE.Joel Sherrill14-42/+1
1999-11-22Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill8-19/+16
.. a major configuration cleanup ... major enhancement of automake support. ... and it contains a *major* breakthough: Automake support for libchip and libmisc *LEAF* directories. To implement this I have used several nasty tricks * The basical trick is to wrap an old Makefile.in's contents into a Makefile.am and still continue to use (i.e include) the old *.cfg files. * Replaced each INSTALL_IF_CHANGE and INSTALL_VARIANT with make dependencies * Add a gnu-make ifdef AUTOMAKE to main.cfg to avoid conflicts between automake and RTEMS make rules * Replaced each install:: and preinstall:: rule with make dependencies * Replaced SUB_DIRS with SUBDIRS in all Makefile.ins (Automake convention) * Removed each manually added autoconf substitution which automake performs automatically. This is not yet full automake support, because using the temporary installation directory, preinstallation in general and building variants are in contradiction to automake's basic working principles ... ... the new Makefile.ams work still somewhat clumsy ... nevertheless they work (quite well). WARNING: At first glance this patch is small, but * it affects the whole configuration system. * it opens the road to introducing automake to all Makefile.ins currently not being under automake control. JOEL> Does this remove or add any files? Both, all Makefile.ins below libchip and libmisc get replaced with Makefile.ams.
1999-11-18Patch from "John M. Mills" <jmills@tga.com> with subsequent cleanup fromJoel Sherrill2-9/+93
Ralf Corsepius <corsepiu@faw.uni-ulm.de> that adds initial Hitachi SH-2 support to RTEMS. Ralf's comments are: Changes: ------ 1. SH-Port: * Many files renamed. * CONSOLE_DEVNAME and MHZ defines removed from libcpu. * console.c moved to libbsp/sh/shared, build in libbsp/sh/<BSP>/console applying VPATH. * CONSOLE_DEVNAME made BSP-specific, replacement is defined in bsp.h * MHZ define replaced with HZ (extendent resolution) in custom/*.cfg * -DHZ=HZ used in bspstart.c, only * Makefile variable HZ used in bsp-dependent directories only. 2. SH1-Port * clock-driver rewritten to provide better resolution for odd CPU frequencies. This driver is only partially tested on hardware, ie. sightly experimental, but I don't expect severe problems with it. * Polling SCI-driver added. This driver is experimental and completly untested yet. Therefore it is not yet used for the console (/dev/console is still pointing to /dev/null, cf. gensh1/bsp.h). * minor changes to the timer driver * SH1 specific delay()/CPU_delay() now is implemented as a function 3. SH2-Port * Merged * IMO, the code is still in its infancy. Therefore I have interspersed comments (FIXME) it for items which I think John should look after. * sci and console drivers partially rewritten and extended (John, I hope you don't mind). * Copyright notices are not yet adapted
1999-11-17Removed as part of patch rtems-rc-19991105-1.diff.gz from Ralf CorsepiusJoel Sherrill1-73/+0
<corsepiu@faw.uni-ulm.de>.
1999-11-16Patch rtems-rc-19991105-1.diff.gz from Ralf CorsepiusJoel Sherrill13-72/+26
<corsepiu@faw.uni-ulm.de> which does the following: This is the configuration cleanup patch: Main changes: * TARGET_ARCH removed * target.cfg.in moved to c/make/target.cfg.in (Only configured once for all BSPs of a target) * BARE_XXX variables appended to bsp.cfg.in * autogen renamed to bootstrap * removed stray variables from make/custom/*.cfg To apply: cd <source-tree> rm c/src/make/target.cfg.in cp autogen bootstrap mkdir c/make cp make/target.cfg.in c/make/target.cfg.in rm make/target.cfg.in rm autogen patch -p1 < rtems-rc-19991105-1.diff
1999-11-09This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1-0/+1
for RTEMS.
1999-11-05Eliminated references to stack checker related #defines.Joel Sherrill4-29/+0
1999-11-01Removed HAS_MP=no and commented out HAS_NETWORKING=no.Joel Sherrill1-8/+0
1999-10-28Patch rtems-rc-19991011-3.diff from Ralf Corsepius.Joel Sherrill1-2/+11
1999-10-27Updated to be more like cvme961.cfg.Joel Sherrill1-26/+10
1999-10-27The rxgen960 BSP and i960 RPM support was submitted by Mark BronsonJoel Sherrill1-0/+90
<mark@ramix.com> of RAMIX.
1999-10-26Removed all references to HOST_ARCH including the file gcc.cfg.in. AllJoel Sherrill6-243/+4
host programs are now compiled with automake generated rules. This was done after discussions with Ralf Corsepius and Eric Norum.
1999-10-25tch from Eric Valette <valette@crf.canon.fr> and Emmanuel RaguetJoel Sherrill1-1/+1
<raguet@crf.canon.fr> to fix bugs and make the mcp750 boot RTEMS running the GoAhead web server.
1999-10-25Changed to use interrupt driven console.Joel Sherrill1-1/+1
1999-10-11Switched to the C++ front end to gcc to link. This still did notJoel Sherrill1-1/+1
1999-10-06Added $(LINK_LIBS) to linking gcc command so paranoia would link.Joel Sherrill1-1/+1
1999-10-05Removed targets and configurations that are no longer functionalJoel Sherrill1-3/+0
and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP.
1999-10-05Removed targets and configurations that are no longer functionalJoel Sherrill4-215/+16
1999-10-05Minor corrections to get mvme2307 to compile.Joel Sherrill1-0/+1
1999-10-04Motorola MVME2307 BSP submitted by Jay Kulpinski <jskulpin@eng01.gdds.com>.Joel Sherrill1-0/+112
No modifications made.
1999-10-04Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill4-15/+15
1999-10-04Removed Makefile.in generated from Makefile.amJoel Sherrill4-1085/+0
1999-10-04Regenerated.Joel Sherrill4-20/+24
1999-09-07Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill4-4/+4
Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files.
1999-08-30Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill2-11/+40
This patch addresses a few configuration issues and removes some duplicate configuration files. Background: * some files used in AC_INIT were not unique enough and can lead to problems if a user plays with configure scripts. * the Makefile templates are independent of the target/cpu and bsp, so the bsp dependent versions (c/src/make/Templates) are removed. To apply: patch -p1 < rtems-rc-19990820-3.diff rm -f c/src/make/Templates ./autogen ATTENTION: This patch removes several files and one directory :)
1999-08-23Removed need for use of separate include/networking directory.Joel Sherrill1-7/+3
1999-08-18 Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1-0/+1
Here is another fix, which addresses a few more or less severe bugs in configuration and unix/posix: * Configuration fix: c/src/lib/configure.in didn't handle RDBG correctly * Configuration fix: make depend was non-functional in c/src/lib/libc/Makefile.in * Configuration fix: stray comment removed from aclocal/target.m4 * RTEMS fix: termios support for unix/posix now uses the host's headers only (was completely broken). - Don't install RTEMS's newlib sys/termios.h for unix (sys/termios.h apparently is a newlib specific header) - To be able to compile RTEMS's termios.c with glibc2.1, glibc-2.1 needs __USE_MISC, which is a private define from gcc's features.h, being defined only when _BSD_SOURCE of _SVID_SOURCE is defined. RTEMS's termios apparently implements BSD, thus -D_BSD_SOURCE was added to Linux-posix.cfg. - Conflicting definitions for __USE_MISC and _BSD_SOURCE inside of RTEMS codes removed due to definition of _BSD_SOURCE on the toplevel. This fix has been tested with linux/posix (primary glibc2.1 native), linux/posix (secondary libc5 native), sh/gensh1, i386/pc386 and a couple of other bsp's/CPU. To apply: cd <srcdir> patch -p1 < rtems-rc-19990709-9.diff and aclocal -I aclocal && automake && autoconf cd c/src/lib; autoconf or ./autogen
1999-08-12Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill2-3/+3
After upgrading my linux box to the brand new SuSE 6.2 release, which is glibc-2.1 based, I came across a bug in RTEMS - IIRC, I even warned you about it about 1/2 a year ago, but nothing has been done since then :-. The *.m4 macros to check for SYSV/IPC are broken for linux/glibc2.1, because they assume that linux always defines union semun, which isn't true anymore for glibc2.1 (the manpage for semctl states _X_OPEN specifies it this way). Therefore I have tried to implement a more general approach for handling SYSV for unix/posix which checks for presence of struct semun, instead of trying to evaluate OS specific preprocessor symbols. This approach is a bit adventureous, because I only tested it with linux/glibc2.1 and linux/libc5, but not under other Unix variants RTEMS supports. I am quite confident it will work on other hosts, too, but who knows :-. [FYI: I think this might also is the cause of some problems with RedHat 6.X / Mandrake linux recently reported on the rtems list -- rtems-4.0.0 can not be build for posix on any glibc2.1 based host] Furthermore the patch below contains a couple of minor fixes and configuration cleanups, which IMO should be applied before releasing a new snapshot. To apply this patch: cd <source-tree> patch -p1 < rtems-rc-19990709-8.diff ./autogen
1999-08-11Patch from Tony R. Ambardar <tonya@ece.ubc.ca>:Joel Sherrill1-9/+7
I'm attaching a big patch for the ts_386ex BSP which adds and includes the following: 1) Conversion to ELF format + minor code cleanups + documentation. 2) An Ada95 binding to FreeBSD sockets, based on Samuel Tardieu's adasockets-0.1.3 package. This includes some sample applications. 3) Some Ada and C interfaces to add serial-port debugging to programs. Comes with examples, too; the Ada one shows how transparent adding the support can be. Note that Rosimildo sent me the original C code. The network stuff is not BSP specific, and could be added to your Ada code collection. The debugging stuff is specific to the i386. Right now, everything sits in my "tools" directory.
1999-08-10Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel RaguetJoel Sherrill1-2/+3
<raguet@crf.canon.fr>: - the dec21140 driver code has been hardened (various bug fixed) Emmanuel, - bug in the mcp750 init code have been fixed (interrupt stack/initial stack initialization), BSS correctly cleared (Eric V) - remote debugging over TCP/IP is nearly complete (berakpoints, backtrace, variables,...) (Eric V), - exception handling code has also been improved in order to fully support RDBG requirements (Eric V),
1999-08-06Patch rtems-rc-19990709-6-diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill35-260/+43
applied. This modified many Makefiles and custom files and makes many more settings (network, multiprocessing, etc) gnerated by autoconf.
1999-07-30 Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill9-38/+1
The main topic is replacing the hard-coded values for HAS_MP and HAS_RDBG in custom/*.cfg with per-bsp configuration-time autoconf checks (This is the patch I had mentioned before earlier this week). CHANGES * HAS_MP removed from custom/*.cfg, replaced with configuration time autoconf check * HAS_RDBG removed from custom/*.cfg, replaced with configuration-time autoconf check * NEW: c/src/make/bsp.cfg.in, takes configuration-time checked per-bsp values (i.e. HAS_MP, HAS_RDBG), gets installed as $(prefix)/<bsp>/make/bsp.cfg * NEW: default.cfg includes bsp.cfg - this change is backward compatible. * IMPORT_SRC: apply VPATH instead for ts_386ex/i386ex subdirectory Makefile.ins * HACK: a bug in acpolish mis-handles addtions to makefile variables which are enclosed in gmake conditionals: c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in * Apply inline_dir, HAS_MP and HAS_RDBG for avoiding configuration of unneeded subdirectories in various configure.in files. * Several minor changes in Makefile.ins and configure.ins, wrt. to the order of including *.cfg and defining Makefile variables APPLYING THE PATCH: patch -p1 < rtems-rc-19990709-4.diff ./autogen
1999-07-27Patch from Jay Kulpinski <jskulpin@eng01.gdds.com> to correctJoel Sherrill3-3/+3
definitions of CONSOLE_USE_POLLED to be !CONSOLE_USE_INTERRUPTS instead of ~CONSOLE_USE_INTERRUPTS.
1999-07-26 Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill9-94/+69
This patch is an addition to "The big-patch" CHANGES: * FIX: c/Makefile.am: bogus comment which changed the behavior of c/Makefile.am removed * FIX: make/custom/ts_i386ex.cfg did not set HAS_NETWORKING correctly (Me thinks it might have been me who added this bogus setting :-). * NEW: removing make targets get, protos, debug_install, profile_install * NEW: replacing clobber with distclean * NEW: Reimplement distclean and clean as reverse depth first make targets (adaptation to automake's behavior) * NEW: removing RCS_CLEAN from make distclean (tools/build/rcs_clean is still in - remove it?) * NEW: "$(RM) Makefile" added to make distclean (adaptation to automake's behavior) * NEW: "$(RM) config.cache config.log" to CLOBBER_ADDITIONS in [lib|exec|tests]/Makefile.in (adaptation to automake's behavior) * NEW: "$(CLEAN_PROTOS)" removed (Not used anywhere) * NEW: binpatch.c moved from i386 bsp tools to tools/build (AFAIS, binpatch is not specific to the pc386 BSP at all) * NEW: AC_EXEEXT added to all configure scripts which contain AC_PROG_CC (Cygwin support) * NEW/Experimental: An experimental implementation of temporary installation tree support in libbsp/i386/pc386/tools/Makefile.am, based on dependency tracking with make, instead of applying INSTALL_CHANGE. REMARK: * This patch is small in size, but changes the behavior of "make clean|distclean|clobber" basically. * This patch does not alter building/compiling RTEMS, ie. there should be no need to rerun all "make all" building tests. KNOWN BUGS: * make RTEMS_BSP="..." distclean in c/ runs "make distclean" in BSPs subdirectories passed through RTEMS_BSP and in "c/." only, but does not descend into other BSP subdirectories previously configured with different settings of make RTEMS_BSP="...". => Workaround: always use the same setting of RTEMS_BSP when working inside the build-tree. * "make [distclean|clean]" do not clean subdirectories, which have been configured at configuration time, but which are not used due to make-time configuration (e.g. macros/networking/rdgb subdirectories). This will problem will vanish by itself when migrating from make-time to configuration-time configuration APPLYING THE PATCH mv c/src/lib/libbsp/i386/pc386/tools/binpatch.c tools/build patch -p1 < rtems-rc-19990709-2.diff autogen
1999-07-26This is part of a major patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill7-0/+824
to move RTEMS more to automake/autoconf and GNU compliance. Finally, here they are: the "big-patch" patches - merged into one big patch (~1.5MB). Sorry for the delay, but testing took much more time than I had expected - esp. reworking the acpolish script triggered many more tiny issues than I had expected (cf. below). At least, now you've got something to spend your weekend with :-. WARNINGS: * I've gone a little (??) further than I had announced before. * Several directories have been moved. * Several files have been added and removed * I have tested it with many BSPs/CPUs and a variety of permutiations of configuration flags, but not with all. * Most parts of the patch are automatically generated, however there are many tiny manual modifications. APPLYING THE PATCH: ./autogen -c mkdir tools mv c/src/exec/score/tools tools/cpu mv c/build-tools tools/build mv c/update-tools tools/update patch -p1 -E < rtems-rc-19990709-0.diff ./autogen If the patch doesn't apply to rtems-cvs, I would suggest that you should try to apply it brute-force and then to run tools/update/rtems-polish.sh -ac -am afterwards. A recursive diff between rtems-19990709 + patch and rtems-cvs + patch then should report only a few dozen significant changes to configuration files which need to be merged manually (IIRC, I did not change any source files). *** Attention: There are files to be removed, moved, copied and added in/to CVS! NEWS/CHANGES: 1. Configuration takes place in 3 stages: 1. per host (toplevel configure script), 2. per target (c/configure), 3. per bsp c/src/configure automatically triggered from ./configure and c/Makefile.am. 2. Building of subdirectory c/ takes place in c/$(target_alias) for cross-targets in c/ for native targets 3. Building of subdirectory c/src takes place in c/${target_alias}/<bsp> for cross-targets, c/<bsp> for native targets 4. c/build-tools moved to tools/build 5. c/src/exec/score/cpu/tools moved to tools/cpu (=cpu-tools split out) 6. c/update-tools moved to tools/update 7. New subdirectory c/src/make, handles files from make/ on a per BSP basis 8. Maintainer mode support: Ie. if configuring with --enable-maintainer-mode disabled (the default), then tracking of many dependencies will be disabled in Makefiles. Esp. many dependencies for auto* generated files will be switched off in Makefiles. Ie. if not using "--enable-maintainer-mode" many auto* generated files will not be updated automatically, i.e. normal users should not be required to have auto* tools anymore (untested). 9. Independent configuration scripts for / (toplevel), tools/build, tools/cpu, tools/update, c/, c/src/, c/src/exec, c/src/lib, c/src/tests, c/src/make 10. Automake support for all directories above and besides c/src 11. "preinstall" now is implemented as depth-first recursive make target 12. host compiled tools (exception bsp-tools) are accessed in location in the build tree instead of inside the build-tree when building RTEMS. 13. RTEMS_ROOT and PROJECT_ROOT now point to directories inside the build-tree - many tiny changes as consequence from this. 14. --with-cross-host support removed (offically announced obsolete by cygnus) 15. Changing the order of building libraries below c/src/lib/ 16. Former toplevel configure script broken into aclocal/*.m4 macros 17. Newlib now detected by configure macros, RTEMS_HAS_NEWLIB removed from *cfg. 18. sptables.h now generated by autoconf 19. Rules for "mkinstalldirs temporary installation tree" moved from c/Makefile to subdirectories. 20. Cpu-tools do not get installed. 21. FIX: Use ACLOCAL_AMFLAGS instead of ACLOCAL = -I ... in Makefile.ams which are in directories with own configure scripts. 22. Hardcoding BSP names into libbsp/.../tools to avoid RTEMS_BSP get overridden from the environment. 22. FIX: Handling of MP_PIECES in various Makefiles 23. FIX: Removing "::" rules from some Makefile.ins 24. FIX: File permission chaos: (-m 444 and -m 555 vs. -m 644 and -m 755) - Now all include files use -m 644. 25. Removed many gnumake-conditionals in Makefile.ins - Partially replaced with automake-conditional, partially replaced with conditionalized Makefile variables (... _yes_V) 26. Massively reworked acpolish: acpolish now parses Makefile.ins and interprets parts of the Makefile.ins. 27. FIX: Some $(wildcard $(srcdir)/*.h) macros removed / replaced with explicit lists of files in Makefile.ins. 28. FIX: Replacing MKLIB with RANLIB in Makefile.ins 29. HACK: Add preinstallation for pc386 specific $(PROJECT_RELEASE)/BootImgs directory ... many more details, I can't recall KNOWN BUGS: 1. make [debug|profile]_install do not do what they are promissing. "make [debug|profile] install" does what "make [debug|profile]_install" has been doing. Proposal: remove [debug|profile]_install 2. Dependencies between temporary installation tree and source tree are not yet handled correctly. 3. Dependencies between temporary installation tree and source tree are handled ineffencently (Using INSTALL_CHANGE instead of make dependencies) 4. RTEMS_ROOT, PROJECT_ROOT, top_builddir, RTEMS_TOPdir now are redundant. 5. The new configure scripts still are in their infancy. They contain redundant checks and might still contain bugs, too. 6. RTEMS autoconf Makefile.ins use a mixture of configuration information gathered in c/$(target_alias)/<bsp>/make and of information collected from their configure scripts. 7. make dist is not fully functional 8. Subdirectory host-/build-/target- configure options (--target, --host, --build) do not conform to Cygnus/GNU conventions. 9. Some RTEMS autoconf Makefile.in's makefile targets are not supported in automake Makefile.ams/ins (e.g. get, clobber). 10. Some automake standard targets are not propagated from toplevel and c/Makefile.am to autoconf subdirectories (eg. make dist). 11. rpcgen generated files are not part of the source-tree (Automake conventions favor supplying generated files inside the source-tree, however there is no support for rpcgen generated files in automake, cf. yacc/lex support in automake). 12. RTEMS_HAS_RDBG handling is flaky. make/*.cfg use RTEMS_HAS_RDBG per CPU, while librdb's sources can only be built per BSP. Raises the more general question whether librdbg located correctly in the source-tree. 13. All make/*cfg files are configured per cpu, currently there is no location to store per-bsp configuration information --> bsp.cfg, per aconfig.h? 14. "make install" without having run "make all" beforehand does not work. 15. handling of --enable-multiprocessing seems to be broken in make/custom/* 16. Makefile.ins still exploit many gmake features. 17. File permisson chaos on libraries (no explict -m for libraries/rels/etc). 18. mcp750 Makefiles are broken (Note: I *do* mean buggy - I am not talking about "not-conforming to conventions", here :-). 19. Dependencies between configure scripts are not handled, eg. aborting "make RTEMS_BSP=<bsp>" can leave the build-tree in an unusable state. 20. "make clean" does not delete <build-tree>/<bsp>. This is intentional for now, because rerunning "make" after "make clean" requires an explicit "make preinstall" afterwards now. This should be done automatically, but doesn't work in this case for now. To work around this problem <build-tree>/<bsp> is kept during "make clean" for now (HACK). TODO: 1. split out host-compiled bsp-tools 2. Use Cygnus/GNU standards for cross-compiling target-subdir (CC=CC_FOR_TARGET .. configure --host=${target_alias} --build=`config.guess'}), to be added to toplevel configure script after splitting out bsp-tools. 3. Exploit per cpu support directory (c/src/<cpu>)- Splitting out per-cpu libraries - Are there any? 4. Further automake support 5. Converting subdirectories into standalone / self-contained subdirectories (Esp. moving their headers to the same common root as their sources, eg. mv lib/include/rtems++ lib/librtems++/include/rtems++) - This is the main obstacle which prevents moving further towards automake. 6. Propagating values from *.cfg into Makefiles instead of propagating them at make time via Makefile-fragments (i.e. try to avoid using *.cfg). 7. Testing on cygwin host (I *do* expect cygwin specific problems). 8. The ARCH in o-$(ARCH)-$(VARIANT) build-subdirectories is not needed anymore. GENERAL ISSUES: 1. Temporary installation tree -- Ian and I seem to disagree basically. Though I think that I understand his argumentation, I do not share it. IMO, his way of using the buildtree is mis-using the build-tree, relying on an inofficial feature of RTEMS's current implementation, which doesn't even work correctly in the current build-tree, though it attempts hard to do so. From my very POV, it unnecessarily complicates the structures of the source- and build-trees. It is not supported by automake (No automatic generation for the necessary rules) and complicates the transition to automake significantly (Generating the rules with an enhanced version of acpolish could be possible). As Ian correctly pointed out, here a management decision is needed - though I don't see the need to draw this decision in short terms. 2. preinstallation generally is a sure means to spoil the structure of the source tree, IMHO (No ranting intended, I am completly serious about this one). eg. through tree dependencies. The worst problem related to this I have found in the meantime is bsp_specs. bsp_specs is part of libbsp, ie. there is *no* way to build *any* part of the source tree *without* having a BSP *preinstalled*. Note: This issue is related to issue 1., but is not identical - The difference is the change of the order make rules have to be triggered. While preinstallation triggers rules spread all over the source tree before a "make all" can be run, a temporary installation tree could also be installed by post "make all" hooks (all-local:, to be run after make all in a directory is completed) if the directories' dependencies would be a tree, 3. Stuctural dependencies between subdirectories. 4. Depth of the source tree (Prevents multilibbing and introduces many unnecessary configure scripts). 5. per cpu vs. per bsp configuration (There are no real per-cpu parts yets :-). 6. automake does not support $makefiles in AC_OUTPUT. Unlike before, we now should try to avoid RTEMS_CHECK_MAKEFILE and to hard-code as much paths to Makefiles as possible. 7. General redesign of the source tree 8. Main installation point - Changing it to ${prefix}/${target_alias}. ? Besides item 8. (which is a must, IMHO), as far as I see most of them can not be solved soon and will remain issues in the mid- to long-term :-. REMARKS: * You (as the maintainer) should always use --enable-maintainer-mode when building RTEMS to ensure that maintainer mode generated files (esp. those in c/src/make) will be updated when make/* files have changed. * Use @RTEMS_BSP@ in Makefile.ins and Makefile.ams below c/src/, $(RTEMS_BSP) or ${RTEMS_BSP} will be overridden from environment variables when using make RTEMS_BSP="....". * c/src/make is a temporary cludge until configuration issues are solved. At the moment it is configured per bsp, but contains per-target/cpu info only. Its main purpose now is to circumvent modifying make/*.cfg files, because I consider make/* to be frozen for backward compatibilty. * This patch should only affect configuration files. At least I do not remember having touched any source files. * To build the bare bsp you now need to mention it in --enable-rtemsbsp. Example: building gensh1 and sh1/bare simultaneously: ../rtems-rc-19990709-1/configure --target=sh-rtems \ --enable-rtemsbsp="bare gensh1" \ --prefix=/tmp/rtems \ --enable-bare-cpu-cflags='-DMHZ=20 -m1 -DCPU_CONSOLE_DEVNAME=\"/dev/null\"' \ --enable-bare-cpu-model=sh7032 \ --enable-maintainer-mode \ --enable-cxx make make install * The next steps in development would be to split out bsp-tools and then to change to Cygnus/GNU canonicalization conventions for building the c/ subdirectory afterwards (i.e. many standard AC_*.m4 macros could be used instead of customized versions) FINAL REMARK: The issues mentioned in the lists above sound much worser than the situation actually is. Most of them are not specific to this patch, but are also valid for the snapshot. I just wrote down what I came across when working on the patch over the last few weeks. I wouldn't be too surprised if you don't like the patch at the current point in development. I am willing to discuss details and problems, I also have no problem if you would post-pone applying this patch to times after 4.1, but rejecting it as a whole for all times would be a false management decision, IMHO. Therefore I would suggest that you, if your time constaints allow it, should at least play a little while with this patch to understand what is going on and before drawing a decision on how to handle this proposal. I know this patch is neither perfect nor complete, but I consider it to be a major breakthrough. Don't be anxious because of the size of the patch, the core of the patch is rather small, the size is mainly the side effect of some systematic cleanups inside the Makefiles (result of acpolish). Feel free to ask if you encounter problems, if you don't understand something or if you meet bugs - I am far from being perfect and am prepared to answer them. Ralf. -- Ralf Corsepius Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung (FAW) Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690 mailto:corsepiu@faw.uni-ulm.de FAX: +49/731/501-999 http://www.faw.uni-ulm.de
1999-07-26This is part of a major patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill15-125/+398
1999-07-09Patch from Jiri Gaisler <jgais@ws.estec.esa.nl>:Joel Sherrill1-0/+4
+ interrupt masking correction + FPU rev.B workaround + minor erc32 related fixes
