path: root/make/target.cfg.in (follow)
* Patch from Aleksey (Quality Quorum <qqi@world.std.com>):Joel Sherrill1998-09-231-0/+1
| | | | | | | | | | | 1. Finally fixes raw interrupts for pc386 2. Makes some minor cleanup in console and startup 3. Makes rtems_termios_dequeue_characters() to return count of outstanding chars - it allows to simplify console isrs a little bit. 4. pc386 uart modified to be friendlier to termios parameter changes, to have minor performance improvement and to take advantage of of above termios modification.
* Patches from Eric NorumJoel Sherrill1998-08-201-1/+0
* FreeBSD stack compiles for the first time (except libc/strsep.c)Joel Sherrill1998-08-201-0/+1
* Monstrous patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. I haveJoel Sherrill1998-06-271-17/+11
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | made no attempt to divide the comments up and place them with just the appropriate files. Here is an excerpt from Ralf's email: Changes including comments on changes I made after cycling through all the targets: * Added ranlib support. Now all targets use "ranlib" instead of "ar -s" to build an index for a library. If ranlib isn't detected during configuration, check if ar -s is working and try "ar -s" instead of * Removed $(XXX_FOR_TARGET) from make/target.cfg.in, use $(XXX) instead now. * gcc-target-default.cfg: LINK_XXXX-defines reworked to solve the -l problem under posix (cf gcc-target-default.cfg) * rtems-glom replaced by Makefile-rules inside of the wrapup/Makefile.in that has been using rtems-glom until now. * Removed CCC and friends in gcc-target-default.cfg, as they have been breaking CXX support. * Removed CONFIG.$(TARGET_ARCH).CC lines from several custom/*.cfg files, because this is now set in custom/default.cfg. * Added aclocal/ar-s.m4, check whether "ar -s" is working * Added aclocal/cygwin.m4 and aclocal/exeext.m4. * Reworked aclocal/canonicalize-tools.m4: Added ar -s check; fixes for problems when XXX_FOR_TARGET is given via environment variables (didn't work for gcc until now), adding cygwin check, improved autoconf-cache handling. * Removed -l from make rule dependencies. LINK_LIBS is now allowed to contain -L and -l. LINK_OBJS and LINK_FILES must not contain -L or -l. gcc28 make-exe rules now link using $(LINK_OBJS) $(LINK_LIBS) => Almost all custom/*.cfg are modified. This is very likely to break something because of typos or having missed to edit a file. Open problems, known bugs, things I didn't do: * custom/p4000.cfg seems to be out of date and requires to be reviewed. (JRS NOTE: It is subordinate p4650 and p4600 -- both of which build ok after minor changes.) * custom/psim.cfg needs to be reviewed, I added some changes to it, I am insecure about. (JRS NOTE: psim had a minor problem endif/endef swapped but runs fine.) * rtems-glom.in can now be removed. * gcc*.cfg files "make depend" rules don't honor language specific flags (e.g CXXFLAGS is ignored for *.cc) - Nothing to worry about now, but may cause problems for hosts/targets not using gcc or rtems-add-ons that use external packages. * AFAIS, the no_bsp BSP can't be build anymore, i.e. configure refused to configure for it whatever I tried. * The toplevel and toplevel+1 README files are quite out-dated * cygwin.m4 isn't of much use for rtems. In most cases (cf. aclocal/*.m4) it is worked around by directly using $host_os. I think I'll remove it soon after the next snapshot * Before release the cygwin patch needs to be tested under cygwin. I may have broken/missed something (esp. the sed-pattern to convert \\ into / may be broken). * You should try to build/run the posix-BSP under solaris - I don't expect problems, but I am not 100% sure, esp. with regard to ranlib/ar -s. * You should consider to convert all make/compilers/*.cfg files into make/compilers/*.cfg.in files and let autoconf generate the *.cfg. This may help getting rid of some if/then/else statements and help hard-coding some defines into those files in future and shouldn't disturb now. * Not having installed libc.a/libm.a on a host may still break building rtems, esp. when using -disable-gcc28 as the gcc27-configuration scheme directly accesses libc.a and libm.a. The problem should not appear when using gcc28 because it references libc/libm only through -lc and -lm which may be static or dynamic (I didn't test this). * shgen is not yet included (I didn't yet have enough time to integrate it). * I know about a few more configure-probs (esp. cross-checking --enable-* flags). + warn/refuse to configure when --enable-libcdir and --enable-gcc28 are given. + force --enable-libcdir when --disable-gcc28 is given * Replaced KSHELL with @KSH@ in some shell scripts generated by configure.in. * Added a dependency to aclocal/*.m4 in the toplevel Makefile => configure and aclocal.m4 will now be rebuild when any aclocal/*.m4 file is changed * Some changes to aclocal/gcc-pipe.m4 and aclocal/gcc-specs.m4 * Replaced i[[3456]]86-unknown-freebsd2.[[12]] with i[[3456]]86-*freebsd2.* in configure.in, as I suppose there might exist a variety of valid vendors (2nd field of the name-tripple) * Disabled override MAKEFLAGS in toplevel Makefile.in - Potential side-effects are not really clear to me. * In mvme162.cfg, $(LINK_LIBS) is missing in the CC line in gcc28's make-exe rule (yet another one I missed to edit). Just append $(LINK_LIBS) to the "CC" line, like I hopefully did to ALL other custom/*.cfg files. * the problem with mvme162lx.cfg is a follow-up problem of the mvme162.cfg-bug. * mvme162/console and idp/console had variables named Buffer which conflicted with similarly named variables in some tests.
* Renamed bare BSP specific options to make the dependency obvious.Joel Sherrill1998-05-221-3/+4
* Added bare bsp from Chris Johns <cjohns@plessey.com.au>.Joel Sherrill1998-05-211-0/+4
* Added RTEMS_CROSS_TARGET.Joel Sherrill1998-05-181-0/+2
* Fixed MANAGERS_NOT_WANTED.Joel Sherrill1998-03-201-2/+2
* Patch from Ralf Corsepius <corsepiu@@faw.uni-ulm.de>:Joel Sherrill1998-02-171-8/+26
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Yep, I have a bunch of bug-fixes and additions pending (Yet another monster patch, ... I can hear you scream :-). 1) configure.in : one AC_CONFIG_HEADER(...) line too much. 2) configure.in: gcc28 support is enabled by default, i.e. if no --enable-gcc28 option is passed on the command line. I am not sure if this is intentional. IMO, AC_ARG_ENABLE for --enable-gcc28 should look like: AC_ARG_ENABLE(gcc28, \ [ --enable-gcc28 enable use of gcc 2.8.x features], \ [case "${enableval}" in yes) RTEMS_USE_GCC272=no ;; no) RTEMS_USE_GCC272=yes ;; *) AC_MSG_ERROR(bad value ${enableval} for gcc-28 option) ;; esac],[RTEMS_USE_GCC272=yes]) 3) At the end of c/src/exec/score/cpu/m68k/m68k.h > #ifdef __cplusplus > } > #endif > > #endif /* !ASM */ in my opinion these two statements should be swapped: > #endif /* !ASM */ > > #ifdef __cplusplus > } > #endif I didn't try to compile for m68k, but does't this give an error? Is it compensated somewhere else - or didn't I look carefully enough? 5) configure.in: --enable-cpp should probably be renamed to --enable-cxx, as gnu-programs use "cxx" to specify C++ specific configure options, while cpp is used for the preprocessor (e.g egcs uses --with-cxx-includedir, autoconf internally uses $CXX), 6) The macro files from aclocal/*.m4 contain the buggy sed-rules formerly contained in aclocal..m4, i.e. the sed/sort-bug fix to aclocal.m4 didn't make it to aclocal/*.m4. I think I should feel guilty for that - Obviously I submitted the contents of an old aclocal-directory last time. - Sorry. 7) For sh-rtems, we currently need to add additional managers to MANAGERS_REQUIRED (from inside of custom/*.cfg). Currently MANAGERS_REQUIRED is defined in make/compilers/*.cfg. This seems to prevent overriding MANAGERS_REQUIRED from custom/*.cfg files - Obviously the files are included in such a way that the settings from compilers/*cfg always override settings from custom/*.cfg files. Furthermore, I think, defining MANAGERS_* inside gcc-<target>.cfg files is not correct - MANAGERS are not gcc-variant-dependent, but depend on targets/bsps and therefore should be defined in a bsp/target dependent file, e.g. in custom/*.cfg or target.cfg.in. I think defining default settings for MANAGERS* in custom/default.cfg could be an appropriate location. But this requires all custom/*.cfg files to include default.cfg, which *-posix.cfg files don't seem to do. Therefore I would like propose to move MANAGERS* to target.cfg.in - they are included by all custom/*.cfg files. Perhaps we/you should use this opportunity to merge parts from custom/default.cfg into target.cfg.in. This ensures to have the setting included once per target makefile and will open the opportunity to have autoconf doing additional work on bsp-configurations. Peanuts sofar, ... but here it comes ... (:-) 8) I am preparing a major enhancement to autoconf support for gnutools/compilers. It is not yet finished, but usable and I'll therefore attach a preliminary version to this mail. Motivation: * Fix problems with --enable-gcc28, if target-cc is not gcc28 compatible * Fix -pipe problems * Fix problems with hard-coded paths in configuration files (esp. posix) * Fix consistency problems with explictly given gnutools and gcc's gnutools Currently included: * detection and checking of host and target compiler (gcc/g++) * checking if target gnutools are in path * checking if <target>-gcc -specs works (autodisabling gcc28 if not) * checking if <target>-gcc -pipe works Todo : * *posix.cfg files are not yet adapted => The hard-coded paths for these systems are still in use. * Check if the host compiler $CC is properly propagated to the Makefiles (I doubt it, but this should not matter) * Check if rtems' generic tools still work properly (It looks like, but who knows) * Integrate CXX support into default.cfg or gcc-target-default.cfg (It looks like C++ support is only used by posix BSPs) * Automatically handle RANLIB/MKLIB for targets * Plenty ... (:-) Open problems: * Untested for non-gcc compatible host and target compilers. This should be no problem if the tools are named follow gnutool's naming convention and are included in $PATH while running configure. * Intentionally using different tools than that gcc has been configured for, e.g. use a different assembler ? This should be still possible if XX_FOR_TARGET is hard-coded into custom/*.cfg. I don't see why anybody should want to do this, but who knows? I have tested this version on linux and solaris hosts, with gcc's directories mounted at weird non-standard mount points, using egcs (linux/sh-rtemscoff), gcc-2.7.2.2 using native tools (solaris), gcc-2.7.2.3 w/ gnutools (solaris/linux). I don't expect it to break anything, but of cause I can't promise it. It will break most/all *-posix.cfg configuration almost for certain, but not more as rtems' current *posix.cfg configurations already do (hard-coded configurations). I am not sure if this is ready to be included into the next snapshot or not. Perhaps you might try this on your systems and if it you don't notice serious bugs you might put it into the snapshot for public testing (I don't like this, but I don't see another possiblity to test generality). I enclose a patch for configure.in and some configuration files which comprizes fixes for all items mentioned except of #3 . Don't forget to run "aclocal -I aclocal; autoconf;" after applying the patch (:-).
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-301-4/+1
* Removed PROJECT_HOME and CONFIG_DIR variables.Joel Sherrill1998-01-201-0/+56
