Update #3818.
* Makefile.am: Add compilers/*.
* compilers/Makefile.am: Remove.
* lib.cfg: Remove.
* directory.cfg: Remove.
* README: Remove.
* lib.cfg: include $(PROJECT_ROOT)/make/leaf.cfg
* main.cfg: Set PROJECT_RELEASE=$(exec_prefix)/$(RTEMS_BSP).
* host.cfg.in: Remove RM, make-script.
* ChangeLog: Remove bogus 2001-01-22 entry.
that contains:
* Removes MKLIB
handling)
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
