1999-02-18 | Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1 | -8/+0 | |
> 3) rtems-rc-19990131-2.diff > > This patch removes generating bsp_specs from leaf.cfg and generates > bsp_specs from inside of c/Makefile instead. > > The motivation behind this patch is to avoid "polluting" Makefiles by > unneccessary rules from included Makefile-fragments (*.cfg-files) and > try to handle files by explicit rules in Makefiles instead (FYI: > automake-1.4 physically includes Makefile fragments at the time > automake is run, not at the time make is run as RTEMS Makefile.ins do > now) > > Nevertheless, this patch is rather uncritical, almost cosmetical - If > you don't like it, then dump it ;-, however I doubt that subsequent > patches will apply then ;-. | |||||
1999-02-18 | Part of the targopts.h change in generation patch from Ralf Corsepius | Joel Sherrill | 1 | -51/+0 | |
<corsepiu@faw.uni-ulm.de>. | |||||
1998-11-23 | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1 | -0/+3 | |
it work. | |||||
1998-07-24 | Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1 | -1/+1 | |
<raguet@crf.canon.fr> to make their patches work together. | |||||
1998-05-21 | Added bare bsp from Chris Johns <cjohns@plessey.com.au>. | Joel Sherrill | 1 | -0/+5 | |
1998-03-24 | Added rule to transform hppa1.1 to hppa1_1 since hppa1.1 is not a | Joel Sherrill | 1 | -3/+12 | |
valid cpp symbol. | |||||
1998-01-20 | Removed PROJECT_HOME and CONFIG_DIR variables. | Joel Sherrill | 1 | -0/+169 | |
